I completely agree. It's not something 'obvious', but something that requires explanation. I think it was a good question that the textbook failed to properly address.kcdodd said:I think strictly speaking, jessicaw is being diligent. Momentum is clearly not conserved between the two masses in "normal" coordinates. The forces are not equal and opposite, they're just equal both in the up direction. What it is really assuming is that they will have the same change of momentum; not that momentum is conserved. i.e pf - pi = (-mV) - (-mv) = (MV) - (0); because M has V and m has -V (-v initially).
Correct. As you noted, the forces are not equal but opposite. They are equal and non-opposite. So there should be no expectation that momentum is conserved (and it is not conserved). One way to resolve this is to come up with an analog that simplifies and unfolds the system so that the forces are equal but opposite. The attached explanation did not do that, however.kcdodd said:I think strictly speaking, jessicaw is being diligent. Momentum is clearly not conserved between the two masses in "normal" coordinates. The forces are not equal and opposite, they're just equal both in the up direction.
As a scientist, my job is to use evidence and logical reasoning to determine if there is an error in the notes or if there is a misunderstanding. I will thoroughly review the notes and compare them to other reliable sources to verify their accuracy. Additionally, I will ask clarifying questions to better understand your understanding of the notes.
I use a variety of sources, including peer-reviewed scientific articles, reputable textbooks, and expert opinions, to verify the accuracy of the notes. I also rely on my own knowledge and expertise in the subject matter to spot any potential errors or inconsistencies.
Yes, I have a systematic process that I follow when verifying errors in notes. This includes reviewing the notes, comparing them to other sources, researching the topic, and seeking clarification from the individual who provided the notes.
The time it takes for me to determine if there is an error in the notes can vary depending on the complexity of the subject matter and the availability of reliable sources. However, I make sure to thoroughly review and verify the accuracy of the notes before coming to a conclusion.
As a scientist, I have come across errors in notes numerous times. One example is when I was reviewing a research paper and noticed that the data presented did not match the conclusions drawn by the authors. Through further analysis and cross-checking with other sources, I was able to identify a miscalculation in the data, leading to a correction in the paper.
