Cardinality of Functions Mapping Irrational Numbers to Rational Numbers
  • Thread starter trap101
  • Tags
    Cardinality
In summary, the cardinality of the set of all functions mapping the set {√2, √3, √5,√7} into Q is undefined.
trap101
342
Let S be the set of all functions mapping the set {√2, √3, √5,√7} into Q. What is the cardinality of S?
I have been stuck staring and trying to think of something to figure out this question. This is the idea i have:
let U = { all irrational numbers} V = {√2, √3, √5,√7}. Define a set T = {g: U--> Q} Now I think it might be easier for me to get the cardinality of T and since S would be a subset of that then perhaps go from there?
Now looking at it again I don't think it's as swell of an idea. But it's the only thing I got to try. With that, I'm still stuck in tyring to associate T with a cardinality I know (in this case I think it's going to be associated to the cardinality of Q).
Do I have to come up with a specific bijective function that would work?
The problem statement is ambiguous:
* Do we have functions f: R->R, with the constraint that ##f(\sqrt{2})##, ... are rational?
* Do we have functions F: {√2, √3, √5,√7} -> Q?
* Something else?
In the first case, do you know the cardinality of all functions f:R->R?
In the second case, it does not matter that you have 4 irrational numbers. It is just a set with 4 elements.
* Something else?
The closest thing I have in the first case is that I have proved the cardinality of the set of functions that map from N --> R. {f: N-->R }. There have been no constraints established.
In terms of the second case: There are no specific functions stated that F: {√2, √3, √5,√7} -> Q.
In thinking about the second case, I was wondering if I should be only considering the elements one at a time or can I combine the elements? I ask because I was thinking if I could create a function that could go from my set to the rationals. It would be easy if I only had to consider each element individually. But I don't think that is the case.
mfb was asking for clarification on what exactly the problem statement was because your approach seemed unnecessarily complicated if the problem statement was taken at face value. He wasn't asking you to discuss each case.
Suppose instead that the problem was asking you to consider functions from {1, 2, 3, 4} into Q. Would that change the cardinality of S?
No it wouldn't. But I still have to some how get the cardinality of that set. I suppose by comparing it to another set because there are an infinite amount of functions that could create that mapping.
If the type of object in the domain of the functions doesn't matter, why were you asking about the cardinality of the irrationals?
It is still unclear to me what exactly you are supposed to do. Based on the given problem statement, I would expect functions F: {√2, √3, √5,√7} -> Q, but then it is strange that those four roots were chosen for the problem.
If you did not give the exact problem statement in the first post, please post it here exactly as you got it.
1. What is the definition of cardinality of irrationals?
The cardinality of irrationals refers to the number of unique elements in the set of irrational numbers. It represents the size or magnitude of the set.
2. How does the cardinality of irrationals compare to the cardinality of rationals?
The cardinality of irrationals is greater than the cardinality of rationals. This means that there are more irrational numbers than rational numbers.
3. Can the cardinality of irrationals be represented as a real number?
No, the cardinality of irrationals cannot be represented as a real number. It is a concept used to describe the size of a set and cannot be expressed as a single numerical value.
4. How is the cardinality of irrationals determined?
The cardinality of irrationals is determined by using a mathematical concept called Cantor's diagonal argument, which shows that the set of irrational numbers is uncountable.
5. Why is the concept of cardinality of irrationals important in mathematics?
The concept of cardinality of irrationals is important because it helps us understand the infinite nature of numbers and sets. It also has implications in other areas of mathematics such as topology and analysis.
