Why Do Resonance Structures for ClO- and ClO4- Differ in Formal Charges?
  • Thread starter MathewsMD
  • Tags
    Structures
In summary, resonance structures are calculated and used to illustrate the Lewis structures. The average bond order is 1.5 in ClO- and 7/4 in ClO4-.
MathewsMD
433
Hi,
When drawing the resonance structures for ClO-, two exist. One where the O has a formal charge of -1 and there is then a single bond. The other structure is Cl with -1 for formal charge. Why is this second structure an equal resonance structure (why does the Cl have a negative formal charge) when O has the higher electronegativity?
Also, my next question stem from the previous one. In ClO4-, you have 4 resonance structures where the negative formal charge alternates between the 4 oxygen atoms, and the average bond order is 7/4. Why does a fifth resonance structure not exist where the chlorine has the negative formal charge, and makes a double bond with EACH oxygen atom?
It seems like Cl can have a negative formal charge in ClO- and not ClO4-, and I would like an explanation for that, if possible.
Thanks!
Chemistry news on Phys.org
This are good questions. As resonance structures aren't observable experimentally, you have to rely on calculations. If you look at these, there is in fact no double bond between Cl and O and O is either neutral or carries a negative formal charge.
Ok. I understand the basics of resonance structures. I realize Lewis structures are used as visual aids, and are never in this form at any time, while the actual structure is only the hybrid. Just to confirm, you're saying the calculated average bond order is 1.5 for ClO- and 7/4 for ClO4-, and that is the reason the the other possible structures are not considered, right? Are there any other molecules like ClO- where the formal negative charge in the drawn Lewis structures goes to the less electronegative atom? How about for a positive formal charge on the more electronegative atom?
Also, do you mind shedding some light on how average bond order is actually calculated using a method besides Lewis structures?
No, I am saying that bonding has I high degree of ionicity in these compounds and that there are certainly no covalent double bonds between Cl and O in these compounds. Bonding in higher main group compounds is not that simple. A classic is the following article, which you may obtain via your library:
http://onlinelibrary.wiley.com/doi/10.1002/anie.198402721/abstract
I would like to address the questions raised about the structures of ClO4- and ClO-. The discrepancy between the formal charges of Cl and O in the two structures of ClO- can be explained by the concept of electronegativity. While oxygen is indeed more electronegative than chlorine, the overall stability of a molecule is determined not only by the electronegativity of its atoms, but also by their arrangement and distribution of electrons. In this case, the second structure with a negative formal charge on Cl is a valid resonance structure because it allows for a more even distribution of electrons and a more stable molecule overall, despite the higher electronegativity of oxygen.
Moving on to the question about the existence of a fifth resonance structure for ClO4-, it is important to note that resonance structures are not always equally likely to contribute to the overall structure of a molecule. In the case of ClO4-, the four resonance structures with alternating negative formal charges on the oxygen atoms are more stable and contribute significantly to the overall structure. The fifth proposed structure, with a double bond between Cl and each oxygen atom, would result in a formal charge of +1 on Cl and a formal charge of -1 on each oxygen atom. This distribution of charges is less stable and therefore, this fifth structure is not considered a significant contributor to the overall structure of ClO4-.
In summary, the existence and significance of various resonance structures is determined by a combination of factors including electronegativity, electron distribution, and overall stability. While it may seem counterintuitive that a negative formal charge can exist on Cl in one molecule and not in another, it is important to consider the other contributing factors in determining the most stable and accurate representation of a molecule's structure.
1. What is the difference between ClO4- and ClO- structures?
ClO4- and ClO- are both chemical compounds known as perchlorate and hypochlorite, respectively. The main difference between the two structures is the number of oxygen atoms bonded to the central chlorine atom. ClO4- has four oxygen atoms bonded to the chlorine atom, while ClO- has only one oxygen atom bonded to the chlorine atom.
2. Which structure is more stable?
ClO4- is more stable than ClO- due to the greater number of oxygen atoms bonded to the central chlorine atom. This results in a more symmetrical and balanced structure, making it less reactive compared to ClO-.
3. How do the structures affect the properties of the compounds?
The difference in structures affects the properties of ClO4- and ClO- compounds significantly. ClO4- is a strong oxidizing agent, while ClO- is a weaker oxidizing agent. ClO4- is also more stable and less reactive compared to ClO-, making it more useful in industrial and medical applications.
4. Can these structures interconvert?
Yes, ClO4- and ClO- structures can interconvert through a process called redox reactions. In this process, ClO4- can be reduced to ClO-, and ClO- can be oxidized to ClO4-. This is why both compounds are often used in redox reactions in various industries.
5. Are there any safety concerns with these compounds?
Both ClO4- and ClO- compounds can be hazardous to human health and the environment. ClO4- is classified as a toxic and corrosive substance, while ClO- can cause irritation to the skin, eyes, and respiratory system. It is important to handle these compounds with caution and follow proper safety protocols when using them.
  • Chemistry
