Combinations and Committees
In summary, the conversation is discussing how to choose a dance committee from a group of 5 student representatives, where 3 will be chosen to work on the committee and one will be chosen as the chairperson. The correct way to calculate the number of possible committees is by using the formula _5C_3 _3C_1, which is equal to 30. Trying to use the formula _5C_2 _5C_1, which chooses a combination of two followers and one leader, is incorrect because it counts the possibility of one person being chosen as both a member and the chair, resulting in only 2 members on the committee instead of 3.
lacrotix
Hi there. I have a question about combinations at the Math 12 Principles level.
From a group of 5 student representatives, 3 will be chosen to work on the dance committee. Also, each committee must have a chairperson. How many committees are possible?
So I solved this question with
5 nCr 3 x 3 nCr 1 = 30
In which the first part of the equation finds all the possible committees that can be made, and the second part of the equation lists how many different leaders can be chosen from the sub-committee of three I just made.However, I don't see why I can't use this:
5 nCr 2 x 5 nCr 1 = 50
Where the first part chooses a combination of two followers and the second part chooses a combination of one leader for the sub-committee of three people.
Any ideas?
Instead of trying to use a formula think of it this way: There are, initially, 5 people to choose the first person from so there are 5 ways to do that. After the first person is chosen there are 4 people left to choose from so 4 ways to choose the second person. Finally, there are 3 people left to choose from. There would be 5(4)(3)= 60 ways to do that. However, we can count the first person as the chairman so the order in which the last two are chosen is not important. There are 2!= 2 ways that the same 2 people could has been chosen different orders so divide by 2.
As for the formulas, that is the same as
[tex]\frac{5(4)(3)}{2!}= \frac{5(4)(3)(2)(1)}{2!2!}= \frac{5!}{2!2!}[/tex]
which is the same as
[tex]\frac{5!}{2!3!}\frac{3!}{1!2!}= _5C_3 _3C_2[/tex]
as you say.
Your error is that you are choosing two people out of 5 to be "members" and then one of the same 5 people to be chair. That makes it possible that one of the two chosen before will also be chosen chair, leaving the committee with only two members. Instead, you want to chose 2 "members" from the 5 people, then one chair from the remaining three people who were not already chosen. That gives
[tex]_5C_2 _3C_1= \frac{5!}{3!2!}\frac{3!}{2!1!}= \frac{5!}{2!2!}= _5C_3 _3C_2[/tex]
as before.
Thanks for the quick response HallsofIvy.
However, my question relates to the last paragraph of my question. I do understand how to get it your way, but I don't understand how my original thinking is wrong.
Yes, while you were reading I was editing my answer. You say
"one leader for the subcommittee of three people" would be [itex]_3C_1[/itex]
not [itex]_5C_1[/itex]
Thanks. That does help a whole lot!
What is a combination?
A combination is a grouping of items in which the order does not matter. In mathematics, combinations are used to determine the number of ways to select a subset of items from a larger set.
How do you calculate the number of combinations?
The formula for calculating the number of combinations is nCr = n! / (r!(n-r)!), where n is the total number of items and r is the number of items in the subset. This formula is also known as the combination formula.
What is the difference between a combination and a permutation?
While combinations and permutations both involve selecting items from a larger set, the main difference is that order matters in permutations. In combinations, the order of the items does not matter.
What is a committee?
A committee is a group of people who are chosen to come together to make decisions or take action on a specific issue or topic. In mathematics, committees are often used to represent combinations of items from a larger set.
How are combinations and committees related?
Combinations and committees are related in that both involve selecting subsets from a larger set. In mathematics, committees are often used to represent combinations, and the number of possible committees can be calculated using the combination formula.
