Does Quantum Entanglement Suggest a Fake Universe?
In summary: There are theories that “explain” it, but this is a bit of a loaded question. For example, the theory of quantum mechanics explains it, but that is a tautology that doesn’t really engage with what you are asking. So, the theory of quantum mechanics can be taken to explain it in the sense that it predicts its existence and behavior (and is consistent with all empirical evidence). The theory does not explain it in the sense that it provides an intuitive understanding of why it should be so in terms of more familiar and intuitive physical concepts. So the answer depends on what you mean by “explain”.In summary, the conversation discussed the concept of entanglement and non
You’ll need to understand superposition before you’ll be able to make sense of entanglement.
We have many older threads about how superposition works, but you might be better off with a more organized presentation of what QM is all about. There’s no substitute for a real textbook, but if you don’t have the math background (at least two years of college-level calculus) for that, Giancarlo Ghirardi’s book “Sneaking a look at god’s cards” will be way more helpful than any of the links in your post.
I'm not going to lie, I'm really only asking this question because I'm kinda having an existential crisis. I guess a more appropriate question would be, is entanglement and non locality some magical weird feature of the universe, or does it have theories that explain it?
Entanglement SEEMS weird 'til you get it straightened out but there is absolutely NOTHING "magical" about it. It's a well understood phenomenon of particles. "Non-locality" is a bit of a loaded term since some people get confused early on and think it means entanglement can send FTL communication (it can't)
My knowledge may be out-of-date.
Is it understood - in the sense that we have an explanatory model - or is it still in the "shut up and calculate stage"?
Well, I'm an engineer so I may have overstated the "explained" because to me if there's a working model that makes predictions (see Bells Theorem) then it's explained.
Likes weirdoguy and Dale
Entanglement is a feature of quantum theory. And why are you having an existential crisis? I suspect more of a psychological issue than a genuine physics question.
That makes sense but I'm still confused about some of the "weirdness" the articles I posted talk about. Mostly this one: https://www.google.com/amp/s/www.sc...ird-wait-til-you-check-out-entangled-time/amp
That's a pop-sci presentation so I didn't bother to read it. If you want to understand superposition and entanglement you just can't get it from pop-sci presentations, you have to buckle down with a real textbook.
Likes DrChinese
Neither.
It’s not a magical weird feature of the universe, it is a surprising consequence of the physical laws that describe how the universe works. The surprise is because we have lived our entire lives interacting with objects large enough that quantum effects are unnoticeably small so we don’t naturally include them in our thinking (Imagine trying to explain to Aristotle’s contemporaries that when they throw a ball to the left the Earth under their feet will move to the right as a consequence of momentum conservation). So it’s not magic, but it is counterintuitive and requires unlearning some stuff that we’ve accepted without question.
But there’s also no explanation deeper than: These physical laws describe how the universe works but not why it works that way. No matter how deeply we probe for an explanation, eventually we”ll have to settle for “because that’s the rules”. Quantum mechanics is not unusual in this way; we’re comfortable with Newton’s law of gravity even though it doesn’t explain why masses attract but only quantitatively describes the fact that they do.
Likes phinds
I started to research it a little bit more and traveled down the relativity and time dilation rabbit hole. Is there a simplier explanation for this? I hate to repeat this term again but it once again feels like magic in a way, was hoping there was a more logical explanation.
Sources: https://www.google.com/amp/s/www.space.com/amp/29859-the-illusion-of-time.html
https://www.dummies.com/education/science/physics/string-theory-unifies-space-and-time/
https://newatlas.com/space/stars-twisting-dragging-spacetime/
What do relativity and time dilation have to do with quantum entanglement?
Sources
None of these (or indeed any of the references you have given in this thread) are textbooks or peer-reviewed papers. You should not expect to be able to actually learn the physics from sources like these. You need to start with the basics, which means an introductory textbook. I personally think Ballentine is a decent one for QM, but there are plenty of others.
Here is a proper explanation of entanglement across time:. 2 photons are entangled that have never existed at the same time. It is the source for one of the diagrams in the article you mention, and in fact is the original basis for the article.
https://arxiv.org/abs/1209.4191
"The role of the timing and order of quantum measurements is not just a fundamental question of quantum mechanics, but also a puzzling one. Any part of a quantum system that has finished evolving, can be measured immediately or saved for later, without affecting the final results, regardless of the continued evolution of the rest of the system. In addition, the non-locality of quantum mechanics, as manifested by entanglement, does not apply only to particles with spatial separation, but also with temporal separation. Here we demonstrate these principles by generating and fully characterizing an entangled pair of photons that never coexisted. Using entanglement swapping between two temporally separated photon pairs we entangle one photon from the first pair with another photon from the second pair. The first photon was detected even before the other was created. The observed quantum correlations manifest the non-locality of quantum mechanics in spacetime."
Note that entanglement across space and time is usually called "quantum non-locality" even though there can be a temporal component. Yes, quantum nonlocality operates somewhat differently than would be expected by classical or Einsteinian spacetime. However, there is no direct conflict (as their applicable domains are sufficiently different); and entanglement follows the normal rules of QM. Those rules have been around for about 90 years, and in fact Einstein co-authored a famous paper (nicknamed EPR) about entanglement in 1935.
Likes PeroK
So basically you're saying it's not some weird feature of the universe, it's easily explained?
Well, "easily explained" is best judged by the explainee, and the perceived weirdness of a phenomenon is generally inversely proportional to the perceiver's understanding of the physical theory behind that phenomenon...
But with that said, entanglement is not some bizarre supernatural phenomenon. It is predicted and accurately described (I will not say "explained" for the reason I gave in #11 above) by the laws of physics, and once you understand these laws well enough to apply them to this particular problem, it is no more weird and incomprehensible than the elliptical orbits of the planets once you understand the law of gravity.
Likes DrChinese, PeroK and Lord Jestocost
Nugatory is quite correct: "easily explained" and "weirdness" are in the eye of the beholder.
The point you might find useful is that entanglement was deduced as a consequence of the new quantum theory circa 1932, just 5 years in. That is quite an accomplishment, considering there was no experimental precedent for such phenomena. And in fact it took decades to put together a successful demonstration of entanglement, generally considered to have been in 1972. When theories make predictions that can be experimentally tested, and the tests confirm those predictions: well, that is great science!
https://www.rpi.edu/dept/phys/Courses/PHYS6510/FreedmanClauser.pdf
So is all this weird? I'd say most physicists see some angle that is hard to get a good handle on in their mind's eye. But they would likely say it is "well explained" by old fashioned quantum theory from nearly a century ago.
Likes EPR and PeroK
So there's no "weird" implications that stem from this? Like a creator or a fake universe or anything?
We have told you the physics. That's the only kind of question we can answer. Whether the physics seems "weird" to you is up to you. Questions about a "creator" or a "fake universe" are not physics questions and are off topic here.
I strongly suggest that you stop reading pop science articles and learn physics from textbooks and peer-reviewed papers.
This thread is closed.
1. What is entanglement?
Entanglement is a phenomenon in quantum mechanics where two or more particles become connected in such a way that the state of one particle is dependent on the state of the other, even when separated by large distances. This connection is known as quantum entanglement and it is one of the most puzzling and counterintuitive aspects of quantum physics.
2. How does entanglement occur?
Entanglement occurs when two or more particles interact in a way that their properties become correlated. This can happen through various processes, such as when particles are created together, or when they interact and exchange energy. Once entangled, the particles will remain connected even if they are physically separated.
3. What are the potential applications of entanglement?
Entanglement has potential applications in various fields, including quantum computing, quantum cryptography, and quantum teleportation. It has also been studied for its potential in improving communication and sensing technologies, as well as in understanding fundamental aspects of quantum mechanics.
4. Can entanglement be observed in everyday objects?
No, entanglement is a phenomenon that occurs at the quantum level and cannot be observed in everyday objects. It requires specialized equipment and techniques to detect and measure entanglement in particles.
5. What are the implications of entanglement for our understanding of the universe?
Entanglement challenges our understanding of the universe and the laws of physics. It suggests that particles can be connected in ways that go beyond our classical understanding of cause and effect. It also raises questions about the nature of reality and the role of observation in shaping the behavior of particles.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
