Continuity of a two variable function
In summary, Wolfram alpha tells me that the limit doesn't exist at (0,0), but the graph clearly shows that it does. The fact that the limit exists at every point is not a sufficient condition for continuity.
eptheta
65
I have a function in x and y, and I was trying to figure out if it was continuous or not.
[itex]f(x,y)=\frac{x^2-y^2}{(x^2+y^2)^2}[/itex]
As far as I know, the only problematic point in the domain is (x,y)=(0,0) so I tried to use the [itex] \epsilon,\delta [/itex] definition.
My proposed limit at (0,0) being 0,
[itex]\frac{|x^2-y^2|}{(x^2+y^2)^2} < \epsilon [/itex]
when [itex]\sqrt{x^2+y^2}<\delta[/itex]
The epsilon term [itex]< \frac{|x^2|+|y^2|}{(x^2+y^2)^2}
=\frac{x^2+y^2}{(x^2+y^2)^2}
=\frac{1}{(x^2+y^2)} = \frac{1}{\delta^2}[/itex]
therefore, take [itex]\delta=\frac{1}{\sqrt{\epsilon}}
[/itex] and the definition is fulfilled.
1.Wolfram alpha tells me the limit doesn't exist, the plot clearly shows me the graph tends towards infinity at (0,0), so there's something wrong with my concepts.
Could someone point out what ?
2.Is the fact that the limit exists at every point a sufficient condition for continuity?
Thanks.
Change to polar coordinates.
Suppose you let (x,y) approach (0,0) along the x-axis, so that y=0.
f(x,0) = x2/x4 = 1/x2.
limx→0(1/x2) = +∞ .
By the Way, f(x,y) can't be continuous at (0,0), if it's not defined at (0,0).
Understood, thanks.
A more general way to look at this is with polar coordinates.
x = r cos(θ), y = r sin(θ) .
x2 + y2 = r2
[itex]\displaystyle \frac{x^2-y^2}{(x^2+y^2)^2}=\frac{r^2(\cos^2(\theta)-sin^2(\theta))}{(r^2)^2}=\frac{\cos(2\theta)}{r^2}[/itex]
When y = ±x, cos(2θ) = 0. So approaching (0,0) along a line of slope ±1, gives a result of zero.
Approaching (0,0) along any other line gives a result of +∞.
Try approaching (0,0) along the curves: y = x ± 2x3 .
therefore, take [itex]\delta=\frac{1}{\sqrt{\epsilon}}[/itex] [\QUOTE]
Should be [itex] \frac{1}{(x^2+y^2)}>\frac{1}{\delta^2} [/itex]
since a>b implies [itex] \frac{1}{a}< \frac{1}{b} [/itex] when a,b ±0
2.Is the fact that the limit exists at every point a sufficient condition for continuity?[\QUOTE]
Limit as xn→x should equal f(x).
Sorry, I don't know how to correct quotes.
Related to Continuity of a two variable function
1. What is the definition of continuity for a two variable function?
Continuity for a two variable function means that the function is unbroken or uninterrupted at all points within its domain. This means that the function has a consistent output as the input values approach a given point.
2. How do you determine if a two variable function is continuous?
To determine if a two variable function is continuous, you must check for three conditions: 1) the function must be defined at the given point, 2) the limit of the function as the input values approach the given point must exist, and 3) the limit must be equal to the value of the function at the given point.
3. Can a two variable function be continuous at a point but not on an interval?
Yes, a two variable function can be continuous at a point but not on an interval. This means that the function is unbroken at a specific point, but there may be other points within the interval where the function is not continuous.
4. How do you prove that a two variable function is continuous?
To prove that a two variable function is continuous, you must show that it satisfies the three conditions for continuity: 1) the function is defined at the given point, 2) the limit of the function as the input values approach the given point exists, and 3) the limit is equal to the value of the function at the given point.
5. Can a two variable function be discontinuous at every point?
Yes, a two variable function can be discontinuous at every point. This means that the function is not continuous at any point within its domain and there are breaks or jumps in the function's graph.
