Crate pushed down an incline.
  • Thread starter Student3.41
  • Tags
    Incline
In summary: Therefore, in summary, the task at hand is to find the coefficient of static friction between a 219-kg crate and an inclined surface with an angle of 20.1°. Using the equations F net y = 0 and F net x = 0, and considering the forces in the y and x directions, we can solve for the normal force and plug it into the equation for the forces in the x direction to determine the coefficient of static friction.
Student3.41
71
A 219-kg crate rests on a surface that is inclined above the horizontal at an angle of 20.1°. A horizontal force (magnitude = 501 N and parallel to the ground, not the incline) is required to start the crate moving down the incline. What is the coefficient of static friction between the crate and the incline?
F=ma
Made the coordinate system in the direction of the acceleration.
Drew FBD. FN in the +y direction. mgCOS20.1 in the -y direction.
Fx(501N) in the +x direction. mgSIN21.0 in the +x direction and Fk in the -x direction.
So,
Fy=may ---> a=0
FN=mgcos20.1
Fx=max
-Fk+Fx+mgsin20.1 = ma
-Fk+501N+770N=219(kg)a
-Ukmgcos20.1+1270N = 219(kg)a
-Uk2010(N)=219(kg)a-1270N
This is where I am stuck I am unable to solve for the kinetic coefficient because I have two variables. How do I get ax?
Is the acceleration 501N/219kg since this is the required force to move the crate.
First of all, since we are looking for the coeff of static friction, not kinetic (U k).
You were correct in saying that F net y = 0 and F net x = 0. There is no need to worry about acceleration since these equal zero.
F net y = n - mg cos (theta) - F sin (theta) = 0
The force that pushes it horizontally can be divided into components.
F net x = F cos (theta) - static friction - mg sin (theta) = 0
solve for n, plug it into the equation for the forces in the x direction and only static friction's coeff will be left.
static friction = (static coeff) * normal
1. What is a crate pushed down an incline?
A crate pushed down an incline is a physics experiment where a crate or box is placed on an inclined surface and allowed to roll down due to the force of gravity.
2. How does the angle of the incline affect the speed of the crate?
The angle of the incline will affect the speed of the crate as it determines the component of the crate's weight that is acting parallel to the incline. A steeper incline will result in a greater component of the weight, leading to a faster acceleration and higher speed.
3. What factors influence the motion of the crate down the incline?
The motion of the crate down the incline is influenced by several factors including the angle of the incline, the mass and shape of the crate, and the coefficient of friction between the crate and the incline.
4. How can we calculate the acceleration of the crate down the incline?
The acceleration of the crate down the incline can be calculated using the formula a = gsinq, where a is the acceleration, g is the acceleration due to gravity (9.8 m/s²), and q is the angle of the incline.
5. What is the purpose of conducting a crate pushed down an incline experiment?
The purpose of this experiment is to demonstrate the principles of motion and force, specifically the effects of gravity and incline angle on an object's acceleration. It also allows for the calculation and verification of these principles through experimental data.
12K
