Curved Conveyor Belt Rollers Motors Placement Airport
  • Thread starter Thread starter arehman1289
    Belt Conveyor
The discussion focuses on the placement of rollers and motors in the U-shaped section of curved conveyor belts used in airports. Proper angling of the rollers is essential to ensure they roll in the direction of motion, which helps maintain traction and keeps luggage in place. Participants are seeking links or images for better understanding. The importance of roller alignment in corner sections of conveyors is emphasized for effective operation. Visual resources are requested to aid in comprehending this engineering aspect.
arehman1289
does anyone know how the rollers and motors are place in the U-shaped part of a curved conveyor belt used in airports??
any links or pics would be appreciated ??
the curved part is so there is enough traction "contact" made with the luggage. or just helps keep it in place.
do u have any links or pics related to this stuff ??
Wait, are you talking about when conveyors go around corners? That's simply a matter of angling the rollers so they always roll in the direction of motion.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
