Difference between Lyapunov and linear stability criteria
In summary: Therefore, in order to accurately determine the stability of a system with feedback, it is necessary to consider the functions of energy and the passivity criteria. In summary, modal analysis fails in stability determination because it does not take into account the feedback present in the system, and instead, passivity criteria and Hamiltonian systems should be considered in the Lyapunov stability analysis.
Alejandro11
Dear all,
Consider the connection of two electrical circuits. Both circuits, Z1 and Z2, are stable and only one of them is non-passive. I.e., the eigenvalues are located in the LHP but Re{Z2(jw)}<0 in a frequency range.
For studying the closed-loop stability, you represent the linear system by its ODEs and find the solution of the characteristic equation det(A-λI)=0. In this specific case, you might obtain all the eigenvalues λ of the equations of motion in the LHP and thus thinking the system is stable.
However, when checking the system stability in the sense of Lyapunov, the system might be unstable due to the feedback connection of both circuits:
[ tex ] Z= \frac{Z1}{1+\frac{Z1}{Z2}} [ /tex ]
is non-passive in one region, Re{Z(jw)}<0, and oscillatories instabilities will happen when the system becomes non-passive, Re{Z(jw)}=0 or the Hamiltionian presents pure imaginary eigenvalues.
I want to know why modal analysis fails in the stability determination, and instead of looking at the equations of motion we need to look at the functions of energy to which Hamiltonian systems and passivity criteria are related.
Thank you very much in advance for your replies!
Modal analysis fails in the stability determination because it does not take into account the feedback present in the system. In other words, modal analysis only considers the dynamics within each of the two circuits individually, without taking into account the interactions between them. The Lyapunov stability analysis, on the other hand, takes into account the feedback present in the system by considering the full system state, which includes the interactions between the two circuits. This is why passivity criteria and Hamiltonian systems are related to the Lyapunov stability analysis. Passivity criteria are used to ensure the stability of a system, while Hamiltonian systems are used to analyze the behavior of a system in terms of energy.
1. What is the main difference between Lyapunov and linear stability criteria?
The main difference between Lyapunov and linear stability criteria is that Lyapunov criteria is based on the concept of a Lyapunov function, which is a mathematical function used to prove the stability of a system. On the other hand, linear stability criteria is based on the eigenvalues of a linearized version of the system's equations.
2. How do Lyapunov and linear stability criteria differ in terms of applicability?
Lyapunov criteria is applicable to both linear and nonlinear systems, while linear stability criteria is only applicable to linear systems. This means that Lyapunov criteria can be used to analyze a wider range of systems compared to linear stability criteria.
3. Which criterion is more commonly used in practical applications?
In practical applications, both Lyapunov and linear stability criteria are commonly used. However, linear stability criteria is more commonly used for linear systems, while Lyapunov criteria is more commonly used for nonlinear systems.
4. How do the stability regions differ between Lyapunov and linear stability criteria?
The stability regions in Lyapunov criteria are typically larger compared to those in linear stability criteria. This means that Lyapunov criteria is more robust and can provide a wider range of stability guarantees for a system.
5. Can Lyapunov and linear stability criteria be used together?
Yes, Lyapunov and linear stability criteria can be used together to analyze a system. In fact, using both criteria can provide a more comprehensive understanding of the stability of a system. Lyapunov criteria can be used to prove the stability of a nonlinear system, while linear stability criteria can be used to analyze the stability of a linearized version of the system.
  • Differential Equations
  • Classical Physics
