Distance between real numbers
In summary, the distance between two real numbers a and b in an ordered interval of numbers, for example a<x_{1}<...<x_{n-1}<b, is given by |a-b| when there are in actual fact |a-b|+1 numbers within this range due to the inclusion of the endpoints. This is because we are measuring the distance between two numbers by counting the number of unit intervals between them, and there will always be one less unit interval than the range of numbers between them. This distance is an intrinsic property and does not depend on how we partition the interval between the two numbers. The notion of counting the numbers between two real numbers to determine a distance is not well-defined, as the answer would depend
  • #71
PeterDonis said:
I see the word "units" used, and drawings using number lines, but I don't see anywhere that defines the real numbers in terms of "units" and number lines the way you have described in previous posts. So I don't think these references are examples of an "elementary perspective". They are just making use of a convenient expression and visualization when talking about derived concepts.
Note, for example, that in your third reference, top of page A2, it says:
It does not say that real numbers are defined in terms of the number line. The number line is a convenient graphical representation. That's all.
I think the wires got a bit crossed in my previous posts, apologies for that.
I never meant that real numbers are defined in terms of the real number line (I realize that they are defined abstractly in terms of a set), merely that a one-to-one correspondence exists such that one can identify real numbers with points on a geometric line, the so-called "real number line". With this graphical representation, upon defining the distance between two real numbers as ##d(x,y)=\lvert x-y\rvert##, we see from this graphical representation that any real number ##x## can be viewed as being a distance ##d(x,0)=\lvert x\rvert## from ##0##. If one then one considers the unit length ##d(1,0)=1## as a "unit of length" along the real number line, then in this graphical representation, one can view a given real number ##x## as being a distance of ##\lvert x\rvert## units from the origin, and in general, any two real numbers ##x## and ##y##, as being separated by a distance of ##\lvert x-y\rvert## units.
In the abstract, without using such a graphical representation, one then simply has that, for example, the distance between 8 and 3 is ##d(8,3)=\lvert 8-3\rvert =3## (with no units of any kind attached).
In the abstract sense, why is ##d(x,y)## referred to as the distance between two elements of a set? Is it because originally the notion was abstracted from the physical concept of distance between objects?
Mathematics news on Phys.org
  • #72
Because the function ##d(x, y)## defines a metric on the set (a metric is another abstract concept with an abstract definition independent of any graphical representation on a line, plane, etc.), and "distance" is the standard term for the number that is output by a metric ##d(x, y)## on a set when you plug in two elements ##x## and ##y## of the set.
Probably, but that's a question about history and terminology, not math.
  • #73
Ok, fair enough.
Is what I wrote in the second and third paragraphs of my last post (#73) correct at all?
  • #74
Typo: d(8, 3) = |8 - 3| = 5, not 3
  • #75
Frank Castle said:
Ok, fair enough.
For me, the second paragraph in #71 does not say much of anything. It would help if you defined some terms so that one could distinguish between, for instance, "measured distance" between points on the geometric line, "defined distance" between real numbers as given by the metric and "derived distance" between points on the geometric line based on metric and the mapping you propose.
  • #76
Frank Castle said:
Is what I wrote in the first paragraph of my last post (#73) correct at all?
Do you mean this?
I think the above still has issues. The main one is that none of what you say depends on the graphical representation; you're just restating what a "metric" or "distance function" is. A "unit" is just the result of applying the function ##d(x, y)## to the two members ##x = 1## and ##y = 0## of the set of real numbers. The statement ##d(x, 0) = |x|## is just a special case of the statement ##d(x, y) = |x - y|##, with ##y = 0##. All of this is true independently of any one-to-one correspondence between real numbers and points on a line.
  • #77
Whoops, sorry. Yes, it should've been 5.
Ok.
Let ##\mathbb{R}## be the set of real numbers with the Euclidean metric defined on it, such that the distance between any two real numbers ##x,y\;\in\mathbb{R}## is ##d(x,y)=\lvert x-y\rvert##.
If one the defines an injective map ##S:\mathbb{R}\rightarrow E##, such that ##S(x)=p=x## (where ##E## is the one dimensional Euclidean space). We require that the mapping maps integers to equally spaced points in ##E## (I have to admit, I'm not sure how to do this?!), with the positive and negative integers equally spaced on either side of the chosen origin ##\mathcal{O}\equiv 0##. Furthermore, we define the distance in ##E## by the same Euclidean metric: ##d(p,q)=\lvert p-q\rvert##, where ##p,q\;\in E##. As such, under the identity map, ##S## we have that ##d(p,q)=d(S(x),S(y))=d(x,y)##.
Given this, the unit length in ##E## is defined as the distance of the interval between ##0## and ##1##, ##d(1,0)=1##, which we refer to as a "unit". As such, under this mapping, any real number ##x## can be interpreted as being a distance of ##d(x,0)=\lvert x\rvert## units from ##0##, and indeed, the distance between any two real number, ##x## and ##y##, as being ##d(x,y)=\lvert x-y\rvert## units.
Would this be any good?!
  • #78
PeterDonis said:
Do you mean this?
Yes.
That is true.
I've tried to improve things in the above post (#77)...
  • #79
You have just defined the "one-dimensional Euclidean space".
This is just the identity map, i.e., it is superfluous given what you've already defined. See above.
Your definition of ##\mathbb{R}## already does it; once you have the real numbers with the Euclidean metric, that automatically ensures that the distance ##d(x, y)## between any two consecutive integers ##x## and ##y## is the same.
  • #80
Ah ok. Is this because the Euclidean metric is translation invariant?
What I'm really trying to justify is, as mentioned in a couple of the links that a put in post #69, why they refer to a number being ##\lvert x\rvert## units from ##0##?!
  • #81
I suppose that would be one way of looking at it, yes. But the fact that ##| x - y |## is the same for any two consecutive integers ##x## and ##y## is provable from the set theoretic construction of the integers and the definition of subtraction and absolute value, plus the definition of what "consecutive" integers are. (And all of the properties of the integers, including this one, are preserved once we construct the reals and view the integers as a subset of the reals.)
At this point I'm not sure what you would consider a justification. To me it's just a matter of how you want to define the term "unit"; it has nothing to do with the actual math, it's just a matter of how you want to use ordinary language.
Likes jbriggs444
  • #82
How straightforward is it to prove these properties? (Do you know of a good set of notes that discusses this in detail?)
Also, how does one define what "consecutive" integers are, does one define a function that recursively maps from ##0## to consecutive integers?!
Ah ok. So it is then simply a matter of choice that one refers to the distance between ##0## and ##1## as a "unit", and then since all integers are equally spaced (when the Euclidean metric has been chosen), one can say that any integer ##n## is "##n## units" from ##0## and then, for any real number, one can think of it as being "##\lvert x\rvert## units" from ##0##, or two real numbers being "##\lvert x-y\rvert## units" apart?! (I guess this can be an appealing way to look at things when one uses the geometric notion of a number line, since it acts as a kind of basis to compare distanc)
  • #83
Two distinct integers ##x## and ##y## are consecutive if there is no integer ##z## between them, i.e., no ##z## such that ##x < z < y## or ##y < z < x##.
The property to be proven is that, if two integers ##x## and ##y## are consecutive, as defined above, then ##| x - y | = 1##. Here is a sketch of a proof:
(1) Since for any ##x## and ##y##, we have ##| x - y | = | y - x|##, we can restrict attention to the case ##y < x##, so ##| x - y | = x - y## (i.e., we can drop the absolute value operation).
(2) For the case ##x = 1##, ##y = 0##, we have ##x - y = 1 - 0 = 1##.
(3) Any pair of consecutive integers ##x## and ##y## with ##y < x## can be expressed as ##x = 1 + w##, ##y = 0 + w##, where ##w## is an integer. (Can you see why?)
(4) Thus, for any pair of consecutive integers ##x## and ##y##, we have ##x - y = (1 + w) - (0 + w) = 1 - 0 = 1##.
  • #84
Yes.
  • #85
PeterDonis said:
(Can you see why?)
Is this simply because ##0+w=w< w+1## and there is no integer ##z## such that ##w<z<w+1## since ##w<w+1\Rightarrow 0<1## and there is no integer between ##0## and ##1##?!
PeterDonis said:
Yes.
Is the reasoning a gave for this choice correct - by choosing this "basis length" one can then refer to the distance between and two real numbers in terms of this unit length (since any two integers will be a "unit" distance apart, and any other real number will be inbetween two integers and so will be some amount of "units" distance from ##0##, or any other real number). However, it is important to bear in mind that it is not a "unit of distance" as in the physical sense, it is simply a "book-keeping" device to enable one to intuitively think of distances between real numbers as lengths along a number line. In general, for example, the distance between ##6## and ##1.5## is ##4.5## and one does not need to refer to a unit length (as in "##4.5##" units), it is simply ##d(6,4.5)=4.5##, nothing more, nothing less?!
  • #86
Frank Castle said:
Is this simply because ##0+w=w< w+1## and there is no integer ##z## such that ##w<z<w+1## since ##w<w+1⇒0<1## and there is no integer between ##0## and ##1##?!
Basically, yes.
To me it doesn't look like "reasoning"; it looks like you're just restating the same thing over and over again in different words.
There is no "choosing the basis length" as a separate step. The "basis length" is just ##d(0, 1)##; as I said before, it's just a special case of ##d(x, y)## with ##x = 0## and ##y = 1##. There is no need to define that special case in order to give meaning to ##d(x, y)## in general; in fact it's the other way around, you define ##d(x, y)## in general and then, if you must, use the word "unit" to refer to ##d(0, 1)##.
  • #87
PeterDonis said:
Basically, yes.
Would there be a better way to explain why?
You're right, I think I'm massively over thinking it on this point. I just wanted to clarify that it is a valid choice (and why one might choose it, as some of the notes in the links a gave have done)?!
  • #88
Only if you want a mathematician's level of rigor. :wink:
  • #89
I'd be keen to see it if that's ok?!
One last thing about the unit length ##d(1,0)##. If one chooses to refer to this as a "unit", then is the reason why one can then speak of a given real number ##x## being ##\lvert x\rvert## "units" from ##0## because one can write ##d(x,0)=\lvert x\rvert d(1,0)=\lvert x\rvert\text{ ''units"}##, or is it simply by noting that there is a "unit" distance between each consecutive integer, and so for integers ##n##, it must be that if ##1## is a "unit" from ##0##, then ##n## is ##d(n,0)=\lvert n\rvert## "units" from ##n## (since there are ##n## consecutive integers between ##0## and ##n##, each separated by a "unit"). Then, more generally, for any real number we have that it will be somewhere within the interval between two consecutive integers so it will always be some multiple of "units" away from ##0## (for example, ##1.17\in\left[1,2\right]## and as such is a distance ##d(1.17,0)=1.17## "units" from zero).
  • #90
I'm not a mathematician so I won't try to give that level of rigor. :wink: You would probably need to consult a textbook on analysis.
Frank Castle said:
is the reason why one can then speak of a given real number ##x## being ##\lvert x\rvert## "units" from ##0##...
You're continuing to overthink this. "Unit" is just a word. We choose to apply it to a certain number, the number obtained by evaluating ##d(1, 0)##, the metric ##d## applied to the real numbers ##1## and ##0##. Once we have made that choice, we can observe that all other numbers ##d(x, y)## bear a certain relationship to the number ##d(1, 0)## that we are calling a "unit". That's all there is to it. There isn't any more. All you're doing is continuing to say the same thing over and over again in different words. You aren't adding any new understanding.
I strongly suggest that you take a step back and think about the above before posting again on this subject. At this point I'm going to close this thread since it has clearly run its course. If you have a genuinely new question after thinking things over, you can start a new thread.
Likes PeroK
  • #91
Completely agree.
  • General Math
  • General Math
  • Math POTW for Graduate Students
  • Calculus
