Does oxygen in water have an sp3 orbital structure?
In summary, the bond angles of H2O and ammonia are 104.5° and 107° respectively. The angles between 2 p-orbitals and 2 sp3 hybrid orbitals are 90° and 109°28', with the latter being referred to as the tetrahedral angle. The bond angle of water is greater than predicted due to a lessening of repulsion between hydrogen nuclei. This is due to the assumption that maximum electron density will be transferred to the binding region. However, this assumption is not entirely accurate and hybridization is a better explanation for the observed bond angle in water. Professor Bader's discussion on this topic suggests that the valence bond theory may not fully describe chemical bonding.
edguy99
28
The angle of the water H2O molecule is 104.5°, the angle of ammonia H3N is 107°.
The angle between 2 p-orbitals is 90°, the angle between 2 sp3 hybrid orbitals is 109°28', the tetrahedral angle.
Why is it assumed that water is a "greatly" expanded p-orbital angle, rather then a "slightly" contracted sp3 orbital?
Chemistry news on Phys.org
Please explain to me what you mean by a 'greatly' expanded p-orbital angle for water and who told you or where did you see this?
chemisttree said:
...expanded p-orbital angle for water?
from "An Introduction to the Electronic Structure of Atoms and Molecules"
Dr. Richard F.W. Bader, Professor of Chemistry / McMaster University / Hamilton, Ontario
http://www.chemistry.mcmaster.ca/esam/Chapter_6/section_4.html
"The actual bond angle in the water molecule is 104.5°. The opening of the angle to a value greater than the predicted one of 90° can be accounted for in terms of a lessening of the repulsion between the hydrogen nuclei."
OK, let's look at his entire discussion relative to the point.
The actual bond angle in the water molecule is 104.5°. The opening of the angle to a value greater than the predicted one of 90° can be accounted for in terms of a lessening of the repulsion between the hydrogen nuclei. The assumption we have made is that the maximum amount of electron density will be transferred to the binding region and hence yield the strongest possible bond when the hydrogen and oxygen nuclei lie on the axis which is defined by the direction of the 2p orbital. For a given internuclear separation, this will result in the maximum overlap of the orbitals. Because an orbital with l ¹ 0 restricts the motion of the electron to certain preferred directions in space, bond angles and molecular geometry will be determined, to a first rough approximation, by the inter-orbital angles.
You note he uses the word 'assumption' and 'to a first rough approximation' in his discussion. This suggests to you that the valence bond theory doesn't adequately describe what is observed (although the professor never explicitly states that)
He then goes on to describe hybridization which better describes what is observed but with different examples. He is a poor teacher, that's all.
The point is that the energy difference between s and p orbitals in oxygen is fairly large, so that s-p hybridization is energetically unfavorable in water.
In fact, valence bond theory gives an exceedingly accurate description of H2O:
http://dx.doi.org/10.1016/0166-1280(88)80277-X
I don't think that Baader is a bad teacher. It is more the other way round: Most introductory chemistry text try to give a "one fits it all" description of chemical bonding in terms of hybrids which is often not physically correct.
1. What is an sp3 orbital structure?
An sp3 orbital structure refers to the arrangement of atoms in a molecule where the central atom is surrounded by four other atoms, creating a tetrahedral shape. This arrangement is a result of the central atom bonding with four other atoms through single bonds.
2. How does oxygen contribute to the sp3 orbital structure in water?
In water, oxygen is the central atom and is bonded to two hydrogen atoms through single bonds. This creates a tetrahedral arrangement around the oxygen atom, with each bond pointing towards the corners of a tetrahedron.
3. Why is the sp3 orbital structure important for water?
The sp3 orbital structure of water is important because it allows for the molecule to have a bent shape, which is essential for its unique properties such as surface tension, high boiling point, and ability to dissolve many substances.
4. Can oxygen have a different orbital structure in water?
No, oxygen in water will always have an sp3 orbital structure. This is because the bonding in water is covalent, meaning the electrons are shared between atoms, and the sp3 orbital structure is the most stable arrangement for oxygen to achieve a full outer shell of electrons.
5. How does the sp3 orbital structure of water affect its reactivity?
The sp3 orbital structure of water makes it a highly reactive molecule. The bent shape allows for polar covalent bonding, making it a good solvent for polar substances. It also allows for hydrogen bonding, which gives water its unique properties such as high surface tension and the ability to moderate temperature.
10K
42K
23K
