How Does Doppler Shift Explain the Beats Heard from a Moving Car?
In summary, the conversation discusses using the Doppler Shift equations to solve for the speed of a car based on the frequency of a pure tone heard by a stationary listener. One equation is for a stationary receiver and receding emitter, while the other is for an approaching emitter. By setting these equations equal to each other, the value of VE, the speed of the car, can be solved for.
zylaxice
[SOLVED] Doppler Shift and Beats
A car horn sounds a pure tone as the car approaches a wall. A stationary listener behind the car hears an average frequency of 250Hz, which pulsates (beats) at 12 Hz. What is the speed of the car?
The speed of sound is assumed to be 331 m/s
f_beat = f1 - f2
f[tex]_{'}[/tex]=f [1 / (1+ VE/V)] Doppler Shift for Stationary Receiver, Receding Emitter.
There must be two noises overlapping if the stationary listener is hearing a pulsating beat. If the average frequency heard is 250Hz, then (f1+f2) = 500. Plugging this into f_beat=f1-f2=12Hz, you find that the frequencies must be 244Hz and 256Hz. One of these frequencies is the result of the doppler shift as the listener receives the noise from the receding car. The other I assumed to be the noise that the listener received after it bounced off the wall (which the car is approaching). As far as I can tell, there must then be two equations in regards to the doppler shift for each sound, which share two common variables: f, the tone emitted by the car as if it wasn't moving, and VE, the speed of the car. One of these equations should be 244Hz = f[1 / (1 +VE/ 331m/s)], but I'm not sure how to go about calculating the other equation, or whether or not I'm on the right track in solving this.
Any help would be greatly appreciated.
One equation is stationary receiver, receding emitter, and the other is for a approaching emitter (should just me a minus sign difference).
Which frequency is the one corresponding to the emitter going away from you?
Which frequency is the one corresponding to the emitter approaching the wall (which is then relayed to you by the wall)?
This gives you the 2 equations with 2 variables.
So the equation for the frequency heard after bouncing off the wall is just the same as if the wall was a stationary receiver with the approaching emitter? That would give the 2 equations
f1 = f( 1 / (1 + VE/V) receding
and
f2 = f(1 / (1 - VE/V) approaching
Approaching emitters generate a higher frequency, so you would have
256 = f( 1 / (1 - VE/V), so f= 256 - 256VE/V, which makes the other equation f1=244= (256-256VE/V) * (1/ (1 + VE/V)). Which makes (244 + 244VE/V) = (256-256VE/V), thus 500VE/331 m/s = 12, making VE = 7.94 m/s
Assuming my algebra skills are more or less in tact. Thanks, that cleared up a lot. I guess I was trying to make the frequency of the echo heard by the listener different than the frequency "heard" by the wall, even though the formula in front of me said it shouldn't be because both were stationary.
That looks completely right.
It is a little weird, but the wall does essentially perfectly convey to you what it "hears."
1. What is the Doppler effect?
The Doppler effect is a phenomenon in physics where there is a change in frequency and wavelength of a wave due to the relative motion between the source of the wave and the observer.
2. How does the Doppler effect apply to sound waves?
The Doppler effect can be observed in sound waves when there is a relative motion between the source of the sound and the observer. This causes the perceived frequency of the sound to change, resulting in a shift in pitch.
3. What is the difference between a positive and negative Doppler shift?
A positive Doppler shift occurs when there is a relative motion between the source and the observer towards each other, resulting in an increase in frequency and a higher pitch. A negative Doppler shift occurs when there is a relative motion away from each other, resulting in a decrease in frequency and a lower pitch.
4. How are beats related to the Doppler effect?
Beats occur when two waves with slightly different frequencies interfere with each other. The Doppler effect can cause a change in the frequencies of these waves, resulting in a change in the number of beats produced.
5. How is the Doppler effect used in real life?
The Doppler effect has many practical applications, such as in radar and sonar systems, where it is used to detect the motion and location of objects. It is also used in medical imaging techniques, such as Doppler ultrasound, to measure blood flow and detect abnormalities in the body.
  • Astronomy and Astrophysics
