How Does Climbing Stairs Compare to Lighting a Bulb in Energy Use?
In summary, the amount of energy used by a typical person running up a flight of stairs is much less than the energy required to light a 100 W light bulb for 1 hour.
kirsten_2009
137
[/B]
Compare the amount of metabolic energy used by a typical person running up a flight of stairs to the energy required to light a 100 W light bulb for 1 hour.
Assumptions: A “typical person” in this situation is being arbitrarily defined as a 578.26 N (130 lb) person and the vertical height of a “flight of stairs” as 4m and the time to climb these stairs as 5 seconds (as per the textbook on pg. 130).
The energy needed by this person to go up this flight of stairs:
Work = weight * height = 578.26 N * 4m = 2313 J /5 sec. = 462.6 J/s (W) = 27,756 J/hr
The energy needed to light a 100W light bulb for 1 hour:
If one watt = 1 J/s then 100W =100 J/s x 3600s/1 hour = 360,000 J/hr
So, a person utilizes relatively a small amount of energy while going up a flight of stairs compared to running a light bulb for 1 hour?
It seems like you multiplied by 60 instead of 3600 to convert J/s to J/hr for going up the stairs.
work = weight x height = 2313J ... you can stop there: you are comparing the energy needed, not the power.
note: you wrote W=...=2313J/5s This is incorrect.
The work is 2313K, the power is 2313J/5s.
That is likely what you meant to write but you should actually write it.
running the bulb for the same time would use 500J of energy - but you are not runnig it for the same time.
in fact running the bulb for much more that 23s will consume more energy.
the work done climbing stairs is the gravity part only - not the "total metabolic energy consumed" in the process ... which includes energy that goes to heat and increased respiration and accelerating at the bottom and decelerating at the top and so on.
Hello,
Thanks for replying. I am a little confused with this one. I understand what you are saying about power not being the same as energy since I guess power is sort of how fast work can be done? But, isn't energy "the capacity to do work"? so wouldn't the person's energy to climb a flight of stairs be 2313 J in those 5 seconds that it took him/her to go up the stairs? In calories= 2313 J x 1cal / 4.184J = 552.82 cal (I understand that this is not the "metabolic" energy but I don't believe there is enough information provided to actually calculate the person's total metabolic energy)...?
And then...may I ask how you reached the number 500J for the light bulb? Isn't it that a light bulb with a power rating of 100W would consume 360 kJ for 1 hour? = 360,000 J...? Thanks for all your help and time, it's really appreciated!
500J was for 5 secs.
Lets not compare apples and oranges. The work to climb the stairs was 2313 J, irrespective of the amount of time it took. The energy to run the light bulb for 1 hour was 360000 J.
Chet
Likes kirsten_2009 and RUber
So...I would be correct in saying that the light bulb does require a considerable larger amount of energy to run for an hour than the energy it takes an "average" person to go up a flight of stairs? are my numbers correct? Thanks for your help! :)
Oh I see...totally understand. Thanks!
Yes. Have you ever been to a museum where they have a electro-mechanical setup where you turn a crank to power a light bulb? Try doing that for an hour.
Thanks for your help! No, I've never...but it sounds like a workout.
1. What is energy?
Energy is the capacity of a physical system to do work. In simpler terms, it is the ability to cause change or do work.
2. What are the different forms of energy?
There are several forms of energy, including kinetic energy (energy of motion), potential energy (stored energy), thermal energy (heat), chemical energy (stored in chemical bonds), and electromagnetic energy (energy of light and other electromagnetic radiation).
3. How is energy measured?
Energy is measured in joules (J) in the International System of Units (SI). Other common units of energy include calories and kilowatt-hours (kWh).
4. What is work in relation to energy?
Work is the transfer of energy from one object or system to another. It is the result of a force acting over a distance, and it can be positive (when the force and displacement are in the same direction) or negative (when they are in opposite directions).
5. How can energy be conserved?
Energy conservation refers to the practice of reducing energy consumption and finding more efficient ways to use and produce energy. This can be achieved through various methods, such as using renewable energy sources, improving energy efficiency in buildings and vehicles, and reducing energy waste.
14K
14K
