How to Determine the Equation of a Circle from Given Diameter Coordinates?
  • MHB
  • Thread starter mathdad
  • Tags
    Circle
In summary, an elephant tramples a car when someone asks for help solving a math problem and then someone else helps before the original poster has a chance to give feedback.
mathdad
1,283
Determine the equation of the circle in standard form, given the coordinate of the diameter PQ.
P(-4, -2) and Q(6, 4)
Midpoint is (5, 3).
d = sqrt{(6-(-4))^2 + (4-(-2))
d = sqrt{(10)^2 + (6)^2}
d = sqrt{100 + 36}
d = r = sqrt{136}
Let d = distance = radius
(x - h)^2 + (y - k)^2 = r^2
(x - 5)^2 + (y - 3)^2 = [sqrt{136}]^2
(x - 5)^2 + (y - 3)^2 = 136
Correct?
Mathematics news on Phys.org
Midpoint is (5, 3).
d = sqrt{100 + 36}
d = r = sqrt{136}
Correct?
Let's graph your circle and the points P and Q as a check:
Hmmm...looks like the radius and center points aren't correct.
Can you spot the errors you made in applying the mid-point formula, and in determining the length of the radius?
On my way to work now. I will work out the math later this evening. I like the geometric picture. I would like to see more like it when answering questions involving algebra and geometry.
So you are given the coordinates of the endpoints of the diameter PQ.
Midpoint is (5, 3).
No, the midpoint is ((-4+ 6)/2, (-2+ 4)/2)= (1, 1).
d = sqrt{100 + 36}
d = r = sqrt{136}
No, the diameter is not the radius! The radius is half the diameter, [tex]\sqrt{136}/2= \sqrt{34}[/tex]
Correct?
No, it is not.
(x - 1)^2 + (y - 1)^2 = sqrt{136}/2
(x - 1)^2 + (y - 1)^2 = [sqrt{34}]^2
(x - 1)^2 + (y - 1)^2 = 34
Correct?
MarkFL said:
...Can you spot the errors you made in applying the mid-point formula, and in determining the length of the radius?
No, it is not.
What is the connection between my reply and the angry elephant picture?
I asked you to spot the errors you made, and then another person came along and obliviously answered the entire problem...this is called "trampling" and is against MHB's rules.
MHB Rule #14 said:
Do not explain hints prematurely. When you see someone already helping a member and waiting for the original poster to give feedback, do not give more hints or a full solution. Wait at least 24 hours for the original poster to respond.
Thus, I posted a picture of an elephant trampling a car as a humorous way to object to having my help trampled.
Thanks for explaining the picture to me. I will continue to post from the David Cohen precalculus textbook until I receive my Michael Kelly precalculus Quick Review book in about two weeks.
1. What is the equation of a circle?
The equation of a circle is (x - h)^2 + (y - k)^2 = r^2, where (h,k) is the center of the circle and r is the radius.
2. How do you find the center of a circle from its equation?
The center of a circle can be found by setting the x and y terms equal to 0 and solving for h and k. The resulting point (h,k) will be the coordinates of the center.
3. Can the equation of a circle be written in other forms?
Yes, the equation of a circle can also be written as (x - a)^2 + (y - b)^2 = c^2, where (a,b) is the center of the circle and c is the radius.
4. How is the radius of a circle related to its equation?
The radius of a circle is equal to the square root of the number on the right side of the equation. For example, in the equation (x - 2)^2 + (y + 3)^2 = 25, the radius would be 5.
5. Can the equation of a circle be used to graph a circle?
Yes, the equation of a circle can be used to graph a circle by plotting the center point and then using the radius to plot points around the center. The points should be spaced out evenly and connected to form a circle.
  • General Math
  • General Math
  • General Math
