Estimating engine parameters
In summary, the mean piston speed and the maximum piston speed are both 6.667 m/s. The maximum charge velocity in the intake port is 10.79626 m/s. The time occupied by one engine operating cycle, the intake process, the compression process, the combustion process, the expansion process, and the exhaust process are all about 4.2 seconds. The average velocity with which the flame travels across the combustion chamber is 53.98 m/s. The length of the intake system (the intake port, the manifold runner, etc.) which is filled by one cylinder charge just before the intake valve opens and this charge enters the cylinder (i.e., how far back from the intake valve, in centimeters, one cylinder
dboozer
Several velocities, time, and length scales are useful in understanding what goes on inside engines. Make estimates of the following quantities for a 1.6-liter displacement four-cylinder spark-ignition engine, operating at wide-open throttle at 2500 rev/min.
a. The mean piston speed and the maximum piston speed.
b. The maximum charge velocity in the intake port (the port area is about 20 percent of the piston area).
c. The time occupied by one engine operating cycle, the intake process, the compression process, the combustion process, the expansion process, and the exhaust process. (Note: The word process is used here not the word stroke.)
d. The average velocity with which the flame travels across the combustion chamber.
e. The length of the intake system (the intake port, the manifold runner, etc.) which is filled by one cylinder charge just before the intake valve opens and this charge enters the cylinder (i.e., how far back from the intake valve, in centimeters, one cylinder volume extends in the intake system).
f. The length of exhaust system filled by one cylinder charge after it exits the cylinder (assume an average exhaust gas temperature of 425ºC).
You will have to make several appropriate geometric assumptions. The calculations are straightforward, and only approximate answers are required.
[itex]\bar{S_p}=2LN[/itex]
[itex]\frac{S_p}{\bar{S_p}}=\frac{\pi}{2}\sin\theta \left( 1+\frac{\cos \theta}{(R^2+\sin^2\theta)^{1/2}}\right)[/itex]
For flat topped pistons,
[itex]{V_d}=\frac{c \pi B^2 L}{4}[/itex], where c is the number of cylinders.
Assuming a stroke length of .08 m, the bore diameter is .0799 m.
If the connecting rod length is 0.15m,
[itex]R = \frac{2l}{L} = \frac {2 \bullet 0.15m}{0.1 m} = 3.
75[/itex].
Using L = 0.08 m and N = 2500 rpm, the mean piston speed is
[itex]\bar{S_p} = 6.667[/itex] m/s.
Using graphing software, the max speed occurs at [itex]\theta[/itex] = 1.33732 and is 10.79626 m/s.
I'm not sure how to begin the 2nd part of the question. I'm thinking it has something to do with
[itex]\rho v A = k[/itex], where k is a constant.
It makes sense that the faster the piston moves down, the faster the air is drawn into the chamber.
Assuming a constant density,
[itex]v_1=v_2 \frac{A_2}{A_1}= \frac{10.796 m/s}{20\%}=53.98 m/s[/itex]
I think I got most of it... by looking at a valve timing diagram, I should be able to use the rpm to get an idea of how each process is. This will answer parts c and d. I think I can use the diagram to answer e and f, but I'm not 100% sure on that.
http://www.crazyengineers.com/forum/mechanical-automobile-engineering/43144-engine-valve-timing-diagram.html
1. How are engine parameters estimated?
Engine parameters can be estimated through a combination of experimental measurements and mathematical modeling. First, the engine's physical properties and performance are measured through tests and data collection. Then, mathematical models are used to analyze this data and estimate the engine's parameters.
2. What are some common engine parameters that are estimated?
Some common engine parameters that are estimated include power output, fuel consumption, air-fuel ratio, compression ratio, and engine efficiency. These parameters give insight into the engine's performance and can help improve design and functionality.
3. Why is it important to accurately estimate engine parameters?
Accurate estimation of engine parameters is crucial for the development and optimization of efficient and high-performing engines. It also helps in troubleshooting and diagnosing any issues that may arise during the engine's operation.
4. What are some challenges in estimating engine parameters?
One of the main challenges in estimating engine parameters is the complexity and variability of engines. Each engine is unique and may have different operating conditions and characteristics, making it difficult to accurately estimate parameters. Additionally, factors such as temperature, humidity, and fuel quality can also affect the accuracy of estimates.
5. How can the accuracy of estimated engine parameters be improved?
The accuracy of estimated engine parameters can be improved through continuous testing and data collection, as well as refining mathematical models through validation and calibration. It is also important to consider all relevant factors and sources of error in the estimation process.
  • Mechanical Engineering
19K
  • Other Physics Topics
