Ferromagnetic hysteresis loop
In summary, for a ferromagnetic material in the hysteresis loop, increasing the field from H=Hc will result in saturation of its magnetization (M). However, decreasing the field will cause M to decrease clockwise according to the loop. One way to return the material to its initial state (H=0, M=0) is to use a "degaussing" technique, which uses a damped oscillatory magnetic excitation to alternate the magnetization in opposite directions with decreasing magnitude. This is commonly used, but some materials have a high TN and may require a different practical method.
jackychenp
28
For a ferromagnetic material in the hysteresis loop, when increasing field from H=Hc, its magnetization (M) will saturate. But if we decrease field instead, will M decreases clockwise according to the loop?
How can we make the ferromagnetic material back into the initial state (H=0, M=0)? One way is to go through TN, but some material's TN is very high. Is there any other practical method?
I'm not sure about your first question, but for the 2nd paragraph, it is common to use a "degaussing" technique to remove the residual magnetization. Degaussing uses a damped oscillatory magnetic excitation to alternately magnetize the material in opposite directions, but with a decreasing magnitude on each excursion:
http://en.wikipedia.org/wiki/Degaussing
Thanks.
What is a ferromagnetic hysteresis loop?
A ferromagnetic hysteresis loop is a graphical representation of the relationship between the magnetization of a ferromagnetic material and the applied magnetic field. It shows the behavior of the material as it is magnetized and demagnetized.
What causes the loop to form?
The loop is formed due to the phenomenon of hysteresis, which is the tendency of a material to retain its magnetic properties even after the applied magnetic field is removed. This is due to the alignment of magnetic domains within the material.
How is the loop affected by the material's composition?
The shape and size of the loop can vary depending on the composition of the material. Different types of ferromagnetic materials have different hysteresis loop shapes, which can be influenced by factors such as the type and amount of alloying elements present.
What is the significance of the loop in material science?
The hysteresis loop is an important tool in material science and engineering as it provides information about the magnetic properties and behavior of ferromagnetic materials. It is also used to determine the coercivity and remanence of a material, which are important factors in applications such as magnetic storage devices.
How can the loop be manipulated for practical applications?
By understanding and controlling the shape and size of the hysteresis loop, it is possible to manipulate the magnetic properties of a material for practical applications. For example, by adjusting the composition and processing of a material, engineers can create materials with specific magnetic properties suitable for use in different devices and technologies.
  • Atomic and Condensed Matter
  • Materials and Chemical Engineering
  • DIY Projects
  • Electromagnetism
