Few electromagnetics questions
In summary, the first question involves finding the E field at a ground below a vertical dipole and the distance on the ground where the E field is 0. The second question involves calculating the capacitance per unit length for a coaxial cable with 2 dielectrics. The third question involves using the method of images to find the electric field components for a small dipole centered at the origin.
Cairrd
Just doing an exercise and I am stuck on the following questions. Any help would be appreciated:
1) A vertical dipole, with charge +40C at 10km high, and -40C at 6km high, what is the E field at the ground directly below (ground assumed perfect conductor). And at what distance on the ground will the E field be 0?
2) A coaxial cable is constructed using 2 dielectrics. Dielec 1 occupies 1/6th of the total area between the conductors who's radii are 1 and 7mm. Relatice Perm. of E1 = 5, E2 = 3. Calculate capacitance per unit length.
3) A small dipole centered at the origin, has components (0,0,p). By differentiating the expression for potential at (x,y,z) find the electric field components of x, y and z for (x^2 + y^2 + z^2) >> d^2
where p = dq, q is the charge and a is the seperation
Think I have the others sorted, just these left. Thanks, David.
You need to show some of your own work on these in order for us to help you. What have you done on -1- so far?
You can do the first part of a), right?
The second part sounds more difficult. You need to know how the conductor below react (i.e. how charges will arrange themselves on the surface). But this is a classic problem used to illustrate the mthod of images. If you've seen the method of images, you know how to do this.
When I have used the Method of Images it has only ever been with 1 point charge, how does it work with a dipole?
Good question. Would the effects simply be additive? Intuitively, it seems reasonable, but how to justify it?
In the case of a single point charge, the induced surface charge density at the surface of the conductor is a result of the field of that charge. If you have two charges, the resulting field is the sum of the individual fields, hence the resulting induced charge is the sum of the individual ones.
Or you can see it this way. First there was the void. Then bring the ground from infinity to its final position. Then bring the first charge from infinity to its final position. This induces a surface charge that maintains the potential at 0 at the conductor. And you know how to calculate that. Then bring the second charge from infinity to its final position. This also induces a surface charge on the conductor in order to keep it at 0 pot. The net surface charge is the sum of the two (one is a positive density, the other is a negative, but the resulting will be positive become the negative charge in the dipole is closer to the ground)
Related to Few electromagnetics questions
1. What is electromagnetics?
Electromagnetics is a branch of physics that deals with the study of the interaction between electric and magnetic fields. It explains how these fields can generate and transmit energy through space.
2. What are the fundamental equations of electromagnetics?
The fundamental equations of electromagnetics are Maxwell's equations, which describe the relationships between electric and magnetic fields, electric charges, and electric currents. They are the basis of understanding the behavior of electromagnetic waves and the principles of electricity and magnetism.
3. What are some practical applications of electromagnetics?
Electromagnetics has numerous practical applications, including telecommunications, power generation and distribution, medical imaging, and electronic devices such as computers and smartphones. It also plays a crucial role in the functioning of motors, generators, and other electrical equipment.
4. What is the difference between electric and magnetic fields?
Electric fields are created by electric charges and exert forces on other charges in their vicinity. Magnetic fields, on the other hand, are caused by moving electric charges and can also exert forces on other charges. Electric fields are responsible for the flow of electricity, while magnetic fields are essential for generating and transmitting energy.
5. How does electromagnetics relate to other branches of physics?
Electromagnetics is closely related to other branches of physics, including classical mechanics, quantum mechanics, and thermodynamics. It provides a foundation for understanding the behavior of matter and energy at the atomic and subatomic level and is essential for many technological and scientific advancements.
  • Electromagnetism
