Find in terms of ##h## when ##P## comes instantaneously to rest
chwala
351
See attached.
Mechanics- Pulleys.
I need insight on the highlighted part;
Total height ##= 2h + h + H##
In my understanding, the displacement on either side would be the same, that is ##=h##m given the condition (assumption) that ##a=0##.
and was this part adding any value to the working to solution?
we know that upwards acceleration = downwards acceleration and using
##v^2=u^2+ 2gh##
with ##u=0##.
I shall have,
##\left(\dfrac{2×3gh}{7}\right)^2 =(2gH)^2##
##\dfrac{2×3gh}{7} =2gH##
##\dfrac{3gh}{7}=gH##
##H=\dfrac{3h}{7}##.
##H## should be how far P travels upward after Q hits the ground.
Likes MatinSAR and chwala
When ##Q## hits the ground, the distance travelled by ##P## is ##h+H## and not ##H##.
chwala said:
It is ##h+H## and not only ##H##.
I’m not sure what you are saying. P starts at height ##2h## above the ground. It accelerates for a bit obtaining some initial velocity ( which you must figure out with kinetics) at the moment Q hits the ground. What is P’s position and initial velocity at that instant? Then, P continues to travel upward a further distance ##H## (under the influence of gravity alone) until it instantaneously comes to rest before beginning to descend.
I can't make heads or tails of your supposed solution. I see the books solution... I agree with the books solution... How you got to ##H## is nothing short of a miracle in my opinion. You've shown almost no work, and what you have shown is all mixed up.
Likes Lnewqban
Wrong. When Q hits the ground P has traveled how far from its initial position( of 2h)? What is its height relative to the ground? You are to consider how far Q has traveled, and the inextensible rope criterion.
Learning point for me. So you are implying that ##P## will continue travelling upwards after ##Q## hits the ground? A distance ##h##? let me check that out.
No , it will travel up a distance ##H## after Q hits ground. Not ##h##. You have to figure that out based on p’s initial velocity the instant Q hits. Once Q hits ground the rope goes slack, and the only force left acting on P is gravity. It becomes a projectile motion problem at that point. But it is a kinetic problem ( Newton’s second law) prior to that point.
Likes Steve4Physics and Lnewqban
after ##Q## hits the ground, ##P## will travel,
##0 = -8.4h + 2(4.2)h## distance,
##8.4h =8.4h##
##h=1##
now if this is correct, doe imply that,##h=1##? metres. Cheers.
How i got ##H##? working is shown in my post ##2## it is similar to what they have in the textbook. The textbook or rather the ms jumped the step on taking square roots...
I would like insight on the h part. This prompted my post.
##8.4h =8.4h##
##h=1##
Not correct. The datum is moved to this new point and the standard kinematic equations apply for a projectile acting under gravity. ##H## needs to come out as a function of ##h## on this step.
The equation you came up with shows you are just equation grabbing, and not giving thought to the parts of that need to be put together (or the function of the equations).
Personally, I think we need to start at very beginning.
First step to solve this problem…just first step…What is it?
I’ll show you my first step after.
Likes Steve4Physics
erobz said:
Not correct. The datum is moved to this new point and the standard kinematic equations apply for a price tile acting under gravity. ##H## needs to come out as a function of ##h## on this step.
The equation you came up with shows you are just equation grabbing, and not giving thought to the parts of that need to be put together.
I need your guidance here;
after ##Q## hits the ground then the initial velocity for particle ##P## is ##u =\sqrt{8.4h}## and final velocity is ##v=0## that is my start point.
Let me recheck my steps...
after ##Q## hits the ground then the initial velocity for particle ##P## is ##u =\sqrt{8.4h}## and final velocity ##v=0## that is my start point.
That is near the end of the problem. Show me how you start the problem. I want to go though it all. I’m having doubts how you could have possibly gotten to the step you are on given the equations you are coming up with for the last step… let’s please start from the very beginning. Show how you started.
erobz said:
That is near the end of the problem. Show me how you start the problem. I want to go though it all. I’m having doubts how you could have possibly gotten to the step you are on given the equations you are coming up with for the last step… let’s please start for on the very beginning. Show how you started.
##(T-2mg)+ (5mg -T) = 2ma +5ma##
##3mg = 7ma##
##a=\dfrac{3g}{7}##.
##v^2=u^2+ 2gh##
with ##u=0##.
I shall have,
##\left(\dfrac{2×3gh}{7}\right)^2 -(2gH)^2 = 0##
##\left(\dfrac{2×3gh}{7}\right)^2 =(2gH)^2 ##
just a minute
##3mg = 7ma##
##v^2=u^2+ 2gh##
with ##u=0##.
I shall have,
just a minute
Has anyone ever told you don’t listen very well? My first step was updating the diagram to show the various stages of the problem with the variables I needed to figure out at the end of each stage, while labeling a coordinate system, and giving some some lengths of rope a variable names. That is almost always where any physics problem begins. It is a necessity for clearly communicating your intentions to others, and yourself.
##3mg = 7ma##
That is my first step. Let me now check the steps after this. Considering particle ##Q## motion to the ground, i shall use
##v^2 =u^2 +2as##
##v^2= 0 + 2×\dfrac{3gh}{7}##
##v^2= \dfrac{6gh}{7} =\dfrac{6×9.81h}{7} =8.4h##
Considering particle ##P## motion to the ground, i shall use,
##V^2=u^2 +2gH##
Noting that the acceleration and tension are the same at both sides,
##V^2=0 +2gH =2gH##
Therefore on equating the two,
##\dfrac{6gh}{7} =2gH##
##\dfrac{3h}{7} =H##
##3mg = 7ma##
The next step shows the position and velocity of mass p, and q on the ground.
##3mg = 7ma##
##v^2 =u^2 +2as##
##v^2= \dfrac{6gh}{7} =\dfrac{6×9.81h}{7} =8.4h##.
Step 2 looks good. On to the third and final step.
Likes chwala
This is just but a repitition of my earlier post...but i understand that without the schematic diagram then it is not easy for viewers to follow.
No it really isn’t. What you are doing now is a logical progression with equations that make sense. Your first post was not.
Likes chwala
now my problem is here; when the rope is slack, after ##Q## hits the ground we have particle ##P## travelling the extra distance given by the equation,
##v^2 =u^2+2(-g)h## and noting that ##u=\sqrt{8.4h}##,
##0 = 8.4h -2gS##
##0 = \dfrac{6gh}{7} -2gS##
##2gS=\dfrac{6gh}{7}##
##2S=\dfrac{6h}{7}##
##S=\dfrac{3h}{7}##
Aaaaaaaaaaaah! I can see it now! The distance from ground will now be given by ##2h + h + S= 2h + h +\dfrac{3h}{7}##
Likes erobz
Step 3 is good!
Now let's go over why I believed you were talking out of your backside in your first few posts:
1) No diagram labeling conventions.
2) No visible application of newtons 2nd law - just an answer from the book was presented
3) This quote:" In my understanding, the displacement on either side would be the same, that is ##=h##m given the condition (assumption) that ##a=0##."
What would a= 0 have to do with the displacements? The displacements are tied to the inextensible string condition.
4) You ask if v or v^2 adds any value to the solution with this post!!!
chwala said:
5) You use the variable ##h## as a general statement! Its a variable specific to the problem. Don't Do That!
##v^2=u^2+ 2gh##
6) You square ##v^2## and square 2gH, just to unsquare it in this part!
chwala said:
I shall have,
7) In a subsequent post you reveal that you didn't realize P keeps traveling up after Q hits the ground!
How do you solve the problem without understanding this...It is simply not possible!
8) Then This: You set ##v = v##.
##8.4h =8.4h##
##h=1##
So there is absolutely no reason for you to make the statement:
Do we understand each other yet?
Likes Lnewqban, MatinSAR, Steve4Physics and 1 other person
erobz said:
Step 3 is good!
That is true i did not know that. It is a learning point for me.
Likes Lnewqban
My point is that you can't have possibly solved the problem prior to knowing it. So you were just presenting your (poorly constructed) rendition of the books solution. I think your ego is getting in the way of you actually learning. Please allow yourself to "not know" for a while, ask some questions, and think for a bit more before running to the book. Trust me...you're not the only one who glosses over a solution in the book and says " it's easy...I understand it"... The book makes everything look easy.
erobz said:
My point is that you can't have possible solved the problem prior to knowing it. So you were just presenting your (poorly constructed) rendition of the books solution. I think your ego is getting in the way of you actually learning.
Agreed, i used the wrong equations to try and get the slack distance. I am learning slowly. Cheers.
Likes erobz
Where is this diagram?
Where is what diagram?
The updated diagram you referred to.
post ##16##
That was my own. I was telling them how I started the problem, instead of just writing down random equations.
If you are requesting to see my diagram I’m on my phone, I don’t have it with me currently. But his updated diagram is in post #16.
  • #31
OK. All I saw was the one posted by @chwala in Post #16.
@erobz : You have done an excellent job with Thread, showing great patience.
Likes Lnewqban, Steve4Physics and erobz
  • #32
Thanks @SammyS(that means a lot), sometimes I can hold it together…🥳
Likes Lnewqban and Steve4Physics
  • #33
@erobz, I concur with @SammyS's compliment!
@chwala, it may be worth noting that the question can be quickly/easily solved using conservation of energy. Use ##\Delta (KE) + \Delta(GPE) = 0##. There is no need to find the tension and acceleration.
Try it for yourself first. Here’s my version:
Between release and Q hitting the ground, Q drops a distance ##h## so P rises a distance ##h##. P is now a distance ##2h+h=3h## above the ground. Both P and Q are then travelling with the same speed, ##v##.
Applying conservation of energy, with a little care we can immediately write:
##\frac 12(2m)v^2 +\frac 12 (5m)v^2 + (2m)gh + (5m)g(-h) = 0##
A little simple algebra gives ##v^2 = = \frac {6gh}7##
The string is now slack so P becomes a vertical projectile with initial vertical velocity ##v##, rising a further distance ##S## (from a height of ##3h##). Applying conservation of energy to P gives:
##-\frac 12(2m)v^2 + (2m)gS = 0## (or we could just use a simple kinematics equation)
Substituting ##v^2 = \frac {6gh}7## in the above equation and a little simple algebra gives ##S =\frac 37 h##.
So P’s final height is ##3h + \frac 37 h = \frac {24}7 h##.
Likes Lnewqban, chwala and SammyS
  • #34
Thank You!
  • #35
This looks nice! interestingly, the MS did not envisage this approach. Does a student get full marks by using this approach? This question is from As level Mechanics Paper.
  • Other Physics Topics
