Find volume of solid elliptic paraboloid using polar coordinates
In summary, the conversation discusses how to calculate the volume of an elliptic paraboloid that lies above a given disc. The solution involves setting up polar coordinates for x and y and using cylindrical coordinates to describe the volume.
chris_usyd
39
a elliptic paraboloid is x^2/a^2+y^2/b^2<=(h-z)/h, 0<=z<=h. Its apex occurs at the point (0,0,h). Suppose a>=b. Calculate the volume of that part of the paraboloid that lies above the disc x^2+y^2<=b^2.:confused:
2. The attempt at a solution
We normally do the questions that ask to find the volume of a cylinder. the polar coordinates are straight, which is x=rcos(), y=rsin();
but in this question, i don't how to set up the polar coordinates for x and y..:frown:
Your equation for the elliptic paraboloid appears to be:
[tex]\frac{x^2}{a^2}+\frac{y^2}{b^2}\le \frac{h-z}{h}[/tex]
Make z the subject of the equation to get the upper limit, as z varies from z = 0. The rest should be easy enough, as you are expected to use cylindrical coordinates to describe the volume.
thanks :)) sharks
Related to Find volume of solid elliptic paraboloid using polar coordinates
What is a solid elliptic paraboloid?
A solid elliptic paraboloid is a three-dimensional shape that resembles a bowl or a dish. It is formed by rotating an ellipse around its minor axis.
How do you find the volume of a solid elliptic paraboloid using polar coordinates?
To find the volume of a solid elliptic paraboloid using polar coordinates, you can use the formula V = ∫∫∫ r^2 sinθ dr dθ dz, where r is the radius, θ is the angle, and z is the height.
What are polar coordinates?
Polar coordinates are a system of coordinates that uses a point's distance from the origin (r) and its angle from a fixed reference line (θ) to specify its location in two-dimensional space.
Why is it useful to find the volume of a solid elliptic paraboloid using polar coordinates?
Using polar coordinates to find the volume of a solid elliptic paraboloid can be useful because it simplifies the calculations and can be more efficient than using rectangular coordinates.
Can you explain the process of finding the volume of a solid elliptic paraboloid using polar coordinates?
To find the volume of a solid elliptic paraboloid using polar coordinates, you first need to determine the limits of integration for each variable (r, θ, and z). Then, you can plug these limits into the formula V = ∫∫∫ r^2 sinθ dr dθ dz and evaluate the triple integral to get the volume.
