Finding the normal at the bottom of a curved track
  • Thread starter Thread starter sadpwner
    Normal Track
The discussion revolves around calculating the normal force exerted by the track on a sled sliding down a curved track. The sled's mass is 41 kg, with an initial speed of 1.3 m/s and a height of 4.3 m. The participants clarify that the centripetal force is not an applied force but rather the resultant of gravitational and normal forces. The correct approach involves using the equation N = W + Fc, where N is the normal force, W is the weight, and Fc is the centripetal force. Ultimately, the conversation emphasizes the importance of correctly interpreting the forces acting on the sled to determine the normal force accurately.
sadpwner
A boy slides on a sled on the curved track sketched (black line). (Treat the boy and sled as a particle.) His mass plus that of the sled is m = 41 kg. Friction and air resistance are negligible (I want a sled like that!). His initial speed is v0 = 1.3 m.s–1. The height h = 4.3 m. At the bottom, the track has a radius of curvature (grey circle) R = 3.2 m. At the bottom of the track, what is the normal force exerted by the track on the sled?
ac=v^2/r
W=mg
Ui+Ki=Uf+Kf
N+Fcentripetal=W
N=W-Fc
W=mg=-9.8*41
Ui+Ki=Uf+Kf
m*g*h+m*v0^2/2 =m*v^2
2*g*h+v0^2=v^2
2*-9.8*4.3+1.3^2=-82.59
I would plug this into the centripetal acceleration formula but v^2 shouldn't be a negative number so I am not quite sure if I got the right number.
ac=v^2/r
W=mg
Ui+Ki=Uf+Kf
N+Fcentripetal=W
N=W-Fc
W=mg=-9.8*41
Ui+Ki=Uf+Kf
2*g*h+v0^2=v^2
g=9.8 m/s2, and the potential energy at height h is mgh >0 . It was incorrect to take it negative.
Wow, I got it wrong somehow.
Continuing from where I left off:
2*9.8*4.3+1.3^2=85.97
41*9.8-41*85.97/3.2=-699.69N
The normal force is negative?
What are these numbers? How do you get the normal force?
N=W-Fc
=mg-mv^2/r
=41*9.8-41*85.97/3.2
=-699.69N
sadpwner said:
N=W-Fc
=mg-mv^2/r
That is not correct.
At what direction can the bottom of the track push the sled, upward and downward? What is the direction of the centripetal force? upward and downward?
Track pushes sled upwards. Centripetal is towards the centre so that is upwards as well.
sadpwner said:
N=W-Fc
This treats Fc as though it is an applied force, which it is not. It is that resultant of the applied forces necessary to achieve the curved path. Treat it much like the ma term in ΣF=ma.
Then,
N=W+Fc?
sadpwner said:
Then,
N=W+Fc?
If N is positive up and W is positive down, yes.
sadpwner said:
Then,
N=W+Fc?
The centripetal force is the resultant of the gravitational force (downward) and normal force (upward). It is better to write the equation for the forces as Fc =N-mg.
