Fuel Cell, Etn, Er and polarizations
In summary, a fuel cell is an electrochemical device that converts chemical energy into electricity by combining a fuel and an oxidant. Etn and Er are both elements on the periodic table, with the main difference being their atomic number. A fuel cell generates electricity through an electrochemical reaction, and polarization refers to the decrease in efficiency and performance that can occur over time. This can have a significant impact on the lifespan of a fuel cell, but regular maintenance and monitoring can help mitigate its effects.
4220Fox
Can anyone help me explain the elements of the fuel cell polarization curve. Please be sure to include Etn, Er, and the various polarizations. I am interested by the use of thermodynamics as well... Thank you-
Hi All in the community!
Any ideas on the elements of the fuel cell polarization curve? Thank you,
OK - How about some basics on the Etn, Er and the various polarizations WRT fuel cells? Thank you,
1. What is a fuel cell?
A fuel cell is an electrochemical device that converts chemical energy from a fuel, such as hydrogen or methanol, into electricity. It works by combining the fuel with an oxidant, typically oxygen from air, and passing them over two electrodes separated by an electrolyte. This process produces electricity, heat, and water as byproducts.
2. What is the difference between Etn and Er?
Etn and Er are both elements on the periodic table, with Etn standing for Element 118 and Er standing for Element 68. The main difference between them is their atomic number, or the number of protons in their nucleus. Etn has an atomic number of 118, making it the heaviest element known, while Er has an atomic number of 68.
3. How does a fuel cell generate electricity?
A fuel cell generates electricity through an electrochemical reaction, where the fuel and oxidant are combined at the anode and cathode electrodes. The fuel, which is usually hydrogen, is oxidized at the anode, releasing electrons. These electrons then flow through an external circuit to the cathode, where the oxidant, typically oxygen, is reduced. This flow of electrons creates a current, which can be used to power electronic devices.
4. What is polarization in a fuel cell?
Polarization in a fuel cell refers to the decrease in efficiency and performance that can occur over time due to various factors such as electrode material, operating conditions, and fuel impurities. It can result in a decrease in the cell's voltage output and a decrease in its overall efficiency. To combat polarization, fuel cells often require maintenance and monitoring to ensure optimal performance.
5. How do polarizations affect the lifespan of a fuel cell?
Polarizations can have a significant impact on the lifespan of a fuel cell. The decrease in efficiency and performance can lead to premature wear and tear on the cell's components, shortening its lifespan. In addition, if not properly managed, polarizations can cause irreversible damage to the cell, reducing its overall lifespan. Regular maintenance and monitoring can help mitigate the effects of polarizations and extend the life of a fuel cell.
  • Electrical Engineering
  • General Engineering
  • Materials and Chemical Engineering
  • Nuclear Engineering
  • Atomic and Condensed Matter
