Gradient of a scalar function
In summary: In that case, the differential dx can be either positive or negative depending on the velocity of the curve gamma as it passes through point c.
kidsasd987
143
Hi, I am looking for a proof that explains why gradient is a vector that points to the greatest increase of a scalar function at a given point p.
http://math.stackexchange.com/quest...always-be-directed-in-an-increasing-direction
I understand the proof here. But.. the idea here is del(f)*dl = df is maximized when del(f) and dl point to the same direction, and that maximizes df. Then we have to first consider the direction of dl to verify where del(f) points to.
If we assume that there is a multivariable function f(x1, x2, x3, . . . xn)
and let's say that the derivative with respect to xj is a negative value at p0.
(also derivatives with respect to other variable x1, x2, x3 . . . xn are positive)
which indicates that the peak is at the left of the graph (at the negative direction with respect to point p0)
then, del(f)*dl = df will be maximized when df/dxj*(-dxj) because it would give positive incremental df, since the derivative is negative at p0.
also, we can do this because dl is a vector quantity so we can define its direction as we want it to be.
But, total differential doesn't take this into account. It just multiplies a small increment of each variable, dxi. and they all have the same sign.
I think this is a contradiction.
I think what's confusing you is the use of ## dx_{j}##. In this context, it doesn't mean a small positive infinitesimal quantity, as it would in the context of integrating over an area, as in ##dA = dx dy##. In this context, ##dx_{j}## is meant to represent a displacement (be it positive or negative) in the ##x_{j}## coordinate. The author of the post you linked likely uses this notation because it agrees with the theory of differential forms. This works if you always remember that the dx's aren't the fundamental changes and treat them instead as parametric differentials. In other words, let ## (c_{1}, . . ., c_{n}) ## be the point you want to take the gradient of ## f(x_{1},...,x_{n}) ## (which must be smooth and non-critical at the point ##c##). Consider an arbitrary smooth regular curve through ##\vec{c}## given by ## \gamma (\epsilon) ## defined over a closed interval ##-a \leq \epsilon \leq +a ## where ##\gamma(0) = \vec{c}##. For an infinitesimally small increment ##d\epsilon## in the curve parameter ##\epsilon##, the displacement of the point ##\vec{c}## along the curve is given by the differential ##d\vec{\mathcal{l}} = \sum_{i} \dot{\gamma_{i}}(0) \vec{e}_{i} d\epsilon##. In that sense, each component differential ##dx{i} = \dot{\gamma_{i}}(0) \vec{e}_{i} d\epsilon## can be either positive or negative depending on the velocity of the curve ##\gamma## as it passes through point ##\vec{c}##.
Thank you for your reply.
But it seems still unclear to me somehow. well, i maybe asking you stupid questions but everything gets suspicious when I think too much of something.
1.
I thought that each incremental dxi should be all positive or all negative because that would give maximum df.
It is obvious that incremental df is dependent on the direction of increment hv at a given point p0.
if we look at the graph of f vs xj, because the derivative is negative, it should increase to the negative direction.
For each coordinate x1 to xn, we are free to choose the direction(either negative or positive) to increase the total differential sum of dl.
But the differential dxi has to have the same sign to maximize dl.
2.
Do you mean the parametrized differential dx by dx = lim(eps->0)|eps|?
In a very simplistic approach, ## df=\nabla f \cdot ds ## where ## ds=dx \hat{i} +dy \hat{j} +dz \hat{k} ##. This implies ## df=|\nabla f| |ds| \cos \theta ## where ## \theta ## is the angle between ## \nabla f ## and ## ds ##. The maximum occurs when ## \theta=0 ##.
1. What is the definition of gradient of a scalar function?
The gradient of a scalar function is a vector that represents the direction and magnitude of the steepest increase of the function at a specific point in space. It is also known as the vector derivative of the function.
2. How is the gradient of a scalar function calculated?
The gradient of a scalar function is calculated by taking the partial derivatives of the function with respect to each variable and combining them into a vector. The resulting vector will have the same number of components as the number of variables in the function.
3. What is the significance of the gradient of a scalar function?
The gradient of a scalar function is significant because it provides important information about the behavior of the function at a specific point. It tells us the direction of steepest increase and allows us to determine the rate of change in that direction.
4. How is the gradient of a scalar function used in practical applications?
The gradient of a scalar function is used in many practical applications, such as optimization problems, physical simulations, and machine learning algorithms. It helps us find the maximum or minimum value of a function, predict the behavior of a physical system, and improve the performance of AI models.
5. Can the gradient of a scalar function be negative?
Yes, the gradient of a scalar function can be negative. This simply means that the function is decreasing in that direction. The magnitude of the gradient represents the rate of decrease, and the negative sign indicates the direction of decrease.
  • Calculus
  • Differential Geometry
