High Temperature Flexible Seal
In summary, the moving object is moving linearly in a motion slot which is constructed on a sheet metal plate. But the surrounding temperature in this process is 500 C degree and there must be a flexible sealing element which does not let any particules or liquid material (oil etc.) to the behind of the sheet metal plate. Nathan found a flexible sealing element that allows the motion of the object, but it has to be thick enough to prevent the heat transfer between the hot chamber and the beside of the sealing element. The speed of the moving object is about 2.7 cm/s.
yanikomer
I am working on a project where I need a high temperature sealing element. You can see the system in the attachment.
My moving object is moving linearly in a motion slot which is constructed on a sheet metal plate. But the surrounding temperature in this process is 500 C degree and there must be a flexible sealing element which does not let any particules or liquid material (oil etc.) to the behind of the sheet metal plate. As you see in the photo, I want the clearance between moving object and the sealing element as small as possible.
Does anyone know such a flexible sealing element that I can use in such a high temperature level and it also allows the motion of the moving object?
Thanks
yanikomer
I don't see any attachment, but my best guess based upon your typed post would be some sort of Teflon curtain. That's all that I can think of with the given information.
Elastomeric sealing at high temperatures vs an oil is a delicate subject. Check out the Dupont Chemical Resistance Guide and you can get started there. As you'll see, volume swell, compression set, and other mech. properties will be represented as % losses. And those representations are fairly large brackets, like 10-15%. So, depending on the tolerance of your application, this may be a pain in the arse to work around. And of course, all the reference materials you'll find online clause themselves with lines like "performance subject to verification" or similar.
I can offer some tips, fill out these fields:
the Flowed media is:
the ambient temperature:
leakage spec:
flexible -- how flexible is flexible?:
Mode of sealing - dynamic, static, etc etc..
Oh, wow... that is totally not what I was expecting. So your part travels along between the sealing surfaces like the slider on a zipper? It has to seal ahead and behind, and keep up with the motion in real-time.
Nathan is obviously very knowledgeable in this subject, so I defer to his expertise. I'm just going to ask a couple of questions in order to increase my own education, if you don't mind. One is how thick this barrier must be. By that I mean that if you are looking at it from the viewpoint shown in your picture, how "deep" into the page would it go? Also, what is the smallest particulate size of the solids that must be excluded? How fast does your slider have to move? Sorry if I'm being a pest, but you've got me curious.
Thank you Danger for your answer.
Actually the thickness of the seal element is about the heat transfer between the hot chamber and the beside of sealing element. This is also important but the first thing here is to find such a flexible sealing which allows the motion of the object there.
For example the width of the red moving object in the picture is about 10 mm and we can assume the witdh of the channel in the on the sheet metal as 20 mm.
Actually the sealing is used here just because not to let the oil particules to the behind of the sheet metal part. But after working on some kind of flexible sealing elements, i see that it is not so easy to achieve this kind of sealing. So that the smallest particule size is not so important right now. I worked on some mechanical sealing systems by the way. But this flexible one will be simple and cheaper if i find one.
Thank you all.
I would recommend, seriously, that you consult with Brewnog and Fred Garvin. They both seem to have the most experience with sealing technology. I haven't seen Fred for a while, but Brewski is still here.
(Sort of reminds me of the old joke about the Inuit hunter who got trapped on an ice-floe with his snowmobile after he blew a seal... but I don't think that it's appropriate for PF Guidelines.)
1. What is a high temperature flexible seal?
A high temperature flexible seal is a type of sealant or adhesive that is designed to withstand high temperatures without breaking down or losing its effectiveness. It is commonly used in industrial settings where high temperatures are present, such as in engines, furnaces, or piping systems.
2. How does a high temperature flexible seal work?
A high temperature flexible seal works by creating a barrier between two surfaces, preventing any leaks or gaps from forming. It is able to withstand high temperatures due to its composition, which typically includes heat-resistant materials such as silicone, ceramic, or graphite.
3. What are the benefits of using a high temperature flexible seal?
Some of the benefits of using a high temperature flexible seal include its ability to withstand extreme temperatures, its flexibility which allows it to conform to different surfaces, and its durability which allows it to last for extended periods of time without needing to be replaced.
4. What are some common applications of high temperature flexible seals?
High temperature flexible seals are commonly used in a variety of industrial applications, such as in automotive engines, aerospace components, and in heating and cooling systems. They are also used in household appliances, such as ovens and grills, to create a heat-resistant seal.
5. Are there any safety precautions to consider when using a high temperature flexible seal?
Yes, it is important to follow the manufacturer's instructions and safety guidelines when using a high temperature flexible seal. This may include wearing protective gear, handling the product in a well-ventilated area, and avoiding contact with skin or eyes. It is also important to properly store the seal to prevent any potential hazards.
  • Mechanical Engineering
  • Materials and Chemical Engineering
  • General Engineering
11K
