How do we get the relations?
  • MHB
  • Thread starter evinda
  • Tags
    Relations
In summary, we discussed the proof of a proposition involving the mean value of a function over a sphere and its relationship to a partial differential equation. We also looked at the computation of the normal vector to the sphere and the use of the divergence theorem. Finally, we explored a formula involving the Laplacian operator and the mean value of a function.
evinda
MHB
3,836
Hello! (Wave)
We set $L_k \equiv u_{tt}+\frac{k}{t}-\Delta u=0, k \in \mathbb{N}_0$.
I am looking at the proof of the following proposition:
We suppose that $g(x)$ is twice differentiable in $\mathbb{R}^n$. Then the mean value of $g(x)$ at the sphere with radius $t$ and center at $x$, which we symbolize with $M(t,x,g)$, is a solution of the problem
$L_{n-1} M=0, M(0,x,g)=g(x), M_t(0,x,g)=0$.
I am given the proof for $n=2$, but I have some questions.
For $n=2$ we have $M(t,x,g)=\frac{1}{2 \pi t} \int_{|x-\xi|=t} g(\xi) ds=\frac{1}{2 \pi} \int_0^{2 \pi} g(x_1+t \cos{\phi}, x_2+ t \sin{\phi}) d{\phi}$.
Let $\xi_1=x_1+ t \cos{\phi}$ and $\xi_2=x_2+ t \sin{\phi}$.
We have:
$$\frac{\partial{M}}{\partial{t}}=\frac{1}{2 \pi} \int_0^{2 \pi} (g_{\xi_1} \cos{\phi}+g_{\xi_2} \sin{\phi}) d{\phi}=\frac{1}{2 \pi} \int_0^{2 \pi} \nabla_{\xi}g \cdot (\cos{\phi}, \sin{\phi}) d{\phi}=\frac{1}{2 \pi t} \int_{|x-\xi|=t} \nabla_{\xi}g \cdot \mathcal{v} ds=\frac{1}{2 \pi} \int_{|x-\xi| \leq t} \Delta_{\xi}gd{\xi}$$
Could you explain to me how we get the last two relations? (Thinking)
The normal $\nu$ to the circle is the unit radial vector from the origin, so in coordinates it's $(\cos \phi, \sin \phi)$. Also, on the circle, the arc length parameter $s$ satisfies $s = t\phi$, and so $ds = t\, d\phi$, or $d\phi = \frac{1}{t}\, ds$. This is why, altogether, you get
$$\frac{1}{2\pi}\int_0^{2\pi} \nabla_\xi g\cdot(\cos \phi, \sin \phi)\, d\phi = \frac{1}{2\pi t}\int_{\lvert x - \xi\rvert = t} \nabla_\xi g \cdot \nu \, ds.$$
The last equation follows from the divergence theorem, since $\operatorname{div}(\nabla_\xi g) = \Delta_\xi g$.
Could you explain further to me why the coordinates of $\nu$ are $(\cos \phi, \sin \phi)$ ? (Thinking)
I see... (Nod)
Also, then it says the following:$$\frac{\partial}{\partial{t}} \int_{|x-\xi|\leq t} \Delta_{\xi}g d{\xi}=\lim_{\Delta t \to 0} \frac{1}{\Delta t}\int_{t<|x-\xi|<t+ \Delta t} \Delta_{\xi}g d{\xi}=\int_{|x-\xi|=t} \Delta_{\xi} g ds$$
First of all, why don't we have :
$$\frac{\partial}{\partial{t}} \int_{|x-\xi|\leq t} \Delta_{\xi}g d{\xi}=\lim_{\Delta t \to 0} \frac{1}{\Delta t}\int_{t<|x-\xi|\leq t+ \Delta t} \Delta_{\xi}g d{\xi}$$
Secondly, how do we get the following equality?
$$\lim_{\Delta t \to 0} \frac{1}{\Delta t}\int_{t<|x-\xi|<t+ \Delta t} \Delta_{\xi}g d{\xi}=\int_{|x-\xi|=t} \Delta_{\xi} g ds$$
And... does it hold that $\Delta M= \frac{1}{2 \pi} \int_0^{2 \pi} (g_{\xi_1 \xi_1} \cos^2{\phi}+g_{\xi_2 \xi_2} \sin^2{\phi}) d{\phi}$ ? (Thinking)
I made a slight error in my description of $\varphi$. What I meant to say is that for every point $\xi$ on your circle, $\nu(\xi)$ is the unit radial vector from the center of the circle (which is $x$) to $\xi$. Thus $\nu(\xi) = \frac{\xi - x}{\|\xi - x\|}$. Now $\xi = x + t(\cos \phi, \sin \phi)$ for some $\phi$, and so $\nu(\xi) = \frac{t(\cos \phi, \sin \phi)}{t} = (\cos \phi, \sin \phi)$.
Your equation is correct, but so is the author's. Note the domain of integration in your integral differs from the domain of integration of the authors by a null set.
Switch to polar coordinates centered at $x$. At some point you'll compute the limits
$$\lim_{\Delta t \to 0} \frac{1}{\Delta t} \int_t^{t+\Delta t} \nabla^2 g(x_1 + r\cos \phi, x_2 +r\sin \phi)\, r\, dr,$$
which evaluate to $\nabla^2 g(x_1 + r\cos \phi, x_2 + r\sin \phi)\,t$ by the fundamental theorem of calculus.
How did you derive this formula?
A ok... (Nod)
I see...
Switching to polar coordinates we get the limit $\lim_{\Delta t \to 0} \frac{1}{\Delta t} \int_{t<|r|<t+\Delta t} \Delta_{\xi} g r dr$, which is equal to that what you wrote , right?
Then from the fundamental theorem of calculus, we have that:
$$\lim_{\Delta t \to 0} \frac{1}{\Delta t} \int_t^{t+\Delta t} \Delta_{\xi} g r dr=\lim_{\Delta t \to 0} \frac{1}{\Delta t} \left[\Delta_{\xi}g(x_1+(t+\Delta t) \cos{\phi}, x_2+ (t+\Delta t)\sin{\phi})(t+\Delta t)-\Delta_{\xi}g(x_1+t \cos{\phi}, x_2+t \sin{\phi})t\right]$$
Right? How do we continue?
I don't remember how I got this.
Do we have:
$$\Delta M=\frac{1}{2 \pi t} \int_{|x-\xi|=t} \Delta_{\xi}g d{\xi}$$
although $\xi$ appears at the limit of integration? (Thinking)
No. It should be
$$\lim_{\Delta t\to 0} \int_0^{2\pi} \int_t^{t + \Delta t} \nabla^2g(x_1 + r\cos \phi, x_2 + r\sin \phi)\, r\, dr\, d\phi$$
Do we have:
The $d\xi$ should be $ds$. Otherwise, the formula is correct.
Euge said:
No. It should be
Could you explain further to me how you got this?
Having $ds$ instead of $d\xi$ , in respect to which variable do we integrate?
The region $t < \lvert x - \xi \lvert < t + \Delta t$ is an annulus centered at $x =(x_1,x_2)$ with inner radius $t$ and outer radius $t + \Delta t$. So the radial variable $r$ ranges from $t$ to $t + \Delta t$ and the polar variable $\phi$ ranges from $0$ to $2\pi$. This leads to the double integral representation
$$\int_{t < \lvert x - \xi \rvert < t + \Delta t} \Delta_\xi g\, d\xi = \int_0^{2\pi}\int_t^{t + \Delta t} \nabla^2g(x_1 + r\cos \phi, x_2 + r\sin \phi) \,r\, dr\, d\phi$$
The integration is done with respect to arclength; the integral over the circle $\lvert x - \xi\rvert = t$ is a line integral. If you use $d\xi$ instead, the integral would be zero because the circle is a null set in the plane.
1. How do we determine cause and effect in relationships?
In order to determine cause and effect in relationships, scientists typically use controlled experiments where they manipulate one variable (the independent variable) while keeping all other variables constant. The resulting changes in the dependent variable can then be attributed to the manipulated variable, helping to establish a cause and effect relationship.
2. What methods do scientists use to study relationships?
Scientists use a variety of methods to study relationships, depending on the specific research question and the type of relationship being studied. Some common methods include surveys, experiments, observational studies, and statistical analyses.
3. How do we measure the strength of a relationship?
The strength of a relationship is often measured using statistical techniques such as correlation coefficients or regression analyses. These methods can help determine the degree of association between two variables and whether the relationship is positive, negative, or neutral.
4. How do we account for other factors that may impact relationships?
In order to account for other factors that may influence relationships, scientists may use control groups, statistical controls, or other methods to isolate the effects of the variables they are interested in studying. Additionally, scientists may conduct multiple studies or meta-analyses to help determine the consistency and robustness of relationships across different contexts.
5. Can we generalize relationships to larger populations?
In order to generalize relationships to larger populations, scientists often use random sampling techniques to select a representative sample from the population of interest. This allows them to make inferences about the larger population based on the relationships observed in the sample. Additionally, scientists may conduct replication studies to test the generalizability of relationships across different samples and populations.
  • Differential Equations
  • Differential Geometry
