Ashley Leong
- 2
How does air resistance change the maximum height of a projectile ?
Ashley Leong said:How does air resistance change the maximum height of a projectile ?
Ashley Leong said:Ohh ok thanks !
The drag force acting on a projectile is a resistive force that opposes its motion. As a result, it reduces the velocity of the projectile as it travels through the air. This decrease in velocity ultimately leads to a decrease in the maximum height that the projectile can reach.
The drag force on a projectile is influenced by several factors, including the shape and size of the projectile, the density of the air, the speed of the projectile, and the roughness of the projectile's surface.
The angle of launch can significantly affect the drag force and maximum height of a projectile. A projectile launched at a higher angle will experience a greater drag force and therefore reach a lower maximum height, while a projectile launched at a lower angle will experience less drag force and reach a higher maximum height.
No, drag force will always decrease the maximum height that a projectile can reach. The only way for a projectile to reach a higher maximum height is by increasing its initial velocity or reducing the effects of drag force through aerodynamic design.
Air resistance and drag force are often used interchangeably, and both refer to the force that opposes the motion of a projectile through the air. However, air resistance is a more general term that also includes other types of resistive forces, such as skin friction and form drag. Drag force specifically refers to the resistive force caused by the air colliding with the surface of the projectile.
