How much gunpowder does a rocket need?
  • Thread starter 168918791999
  • Tags
    Rocket
In summary, the conversation discusses the calculation of the amount of gunpowder needed to launch a rocket to a height of 75m. It mentions the equations and variables involved, such as the gravitational acceleration and the energy output of gunpowder combustion. The conversation also discusses the efficiency of rockets and the impact of drag on the rocket's speed and kinetic energy. It is suggested to find the exhaust velocity in order to accurately calculate the amount of gunpowder needed.
  • #36
F=m*Δv
3.8=0.1*Δv
Δv=38m/s2
  • #37
168918791999 said:
F=m*Δv
3.8=0.1*Δv
Δv=38m/s2
I don't know which post this is a reply to, but it makes no sense.
If F is supposed to be a force then the first equation is wrong. The right hand side would yield a momentum.
Or maybe Δv is supposed to be an acceleration?
Secondly, you seem to be rediscovering the initial velocity of the rocket. You previously calculated 38m/s as the initial velocity to reach the desired height, then multiplied by the mass to get the momentum. Dividing that by the same mass will just give you back the initial velocity.
You need to write down two equations with two unknowns. The unknowns are the mass of gunpowder and the exhaust speed of the gases. Write down one equation for the momentum of the exhaust gases and another saying that total KE equals energy produced by combustion.
  • #38
KE=2,7x106*mg
mg = Mass of the gunpowder
P=mg*v
P=mg*38
  • #39
168918791999 said:
KE=2,7x106*mg
P=mg*v
P=mg*38
P=mgvg. vg is unknown.
  • #40
However can you say the momentum (p) is 3.8 Ns?
And that the kinetic energy is
KE=0.5*mg*V2
KE=0.5*mg*38.362
Ke=735.7448*mg
  • #41
Bystander said:
Efficiency. There is an upper limit to the efficiency of about 1/3.
KE=0.5*mg*V2
KE=0.5*mg*38.362
Ke=735.7448*mg
That kinetic energy is irrelevant now. We used it to calculate the launch velocity of the rocket. We used the launch velocity of the rocket to calculate the launch momentum of the rocket. We used the launch momentum of the rocket to calculate the downward momentum of the exhaust gasses.
Back to post #34. Calculate the exhaust velocity.
  • #42
P=v/g
3.8=v/9.81
V=3.8*9.81
V=37.278 m/s
This is the only equation i could found
  • #43
Yes.
168918791999 said:
KE=0.5*mg*V2
KEg=0.5*mg*Vg2, and Vg is UNKNOWN.
Please try to follow the plan I laid out in the last paragraph of post #37.
  • #44
P=Mg*Vg
3.8=Mg*Vg
But how to calculate any of the unknowns?
  • #45
168918791999 said:
P=Mg*Vg
3.8=Mg*Vg
The way I described in the last paragraph of post #37: if the mass of gunpowder is mg, you can write down an expression for the energy in the gunpowder. If its exhaust speed is vg, you can write down an expression for the KE of the exhaust. Finally, total KE equals total available energy (though in practice a bit less). This will leave you with two equations, an energy equation and a momentum equation, involving two unknowns, mg and vg. Solve.
  • #46
Eg=Mg*2.7x106
KEg=½*Mg*Vg
  • #47
KEg=P2/2mg
KEg=3.82/2mg
KEg=14.44/2mg
Can you say KEg=Eg?
Or is KEg+KEr=Eg?
  • #48
168918791999 said:
KEg=P2/2mg
KEg=3.82/2mg
KEg=14.44/2mg
Can you say KEg=Eg
Yes. It is a reasonable assumption that essentially all of the original chemical energy (Eg) in the gunpowder turns into kinetic energy (KEg) of the exhaust gasses.
[The assumption rests on the nozzle being ideal, the exhaust stream being much faster than the rocket among other idealizations]
  • #49
Keg = Eg
KEg = 0.5*Mg*Vg2
Eg = 2.7x106*mg
0.5*Vg2 * mg= 2.7x106*mg
0.5*Vg2 = 2.7x106
Vg2 = 5.4x106
Vg = 2323.79 m/s = 8365.644 km/h
Would this not be too fast?
  • #50
It is in the right ballpark. Liquid oxygen/liquid hydrogen manages 4462 m/s. Nitrogen tetroxide/hydrazine manages 3369.
  • #51
p=mg*vg
3.8=mg*2323.79
mg=0.00163525964 Kg
mg=1.63525964 gr
Do you still have to multiply it by 10 because a rocket is on average only 10% efficient?
Because then you get 16.35 gr and that would be more realistic than 1.6 gr
  • #52
What is the temperature of the exhaust gases? How much chemical energy goes into heating the exhaust gases?
  • #53
168918791999 said:
mg=1.63525964 gr
A figure of 10% for rocket efficiency is unfounded. Before such a figure could even make sense, one would need to come up with a measure of efficiency. One such measure is the fraction of chemical energy which goes into accelerating the payload. That measure depends on how fast the rocket is going already. When rocket velocity is equal to exhaust velocity, 100% efficiency can be approached. When rocket velocity is zero, 0% efficiency always results.
Edit: However, it scores few points with the instructor to object that a given of the problem is wrong. Let us try to make it meaningful. Assume that the 10% is a measure of how much of the chemical energy in the propellant is divvied up as kinetic energy going to the rocket and to the bulk of the exhaust stream. Then the remaining 90% would be lost as waste heat, sound, vibration and kinetic energy in the expanding exhaust cloud.
For a suitably ideal nozzle operating in vacuum, the exhaust gas temperature can become negligible. Adopting realistic assumptions for this seems to be out of scope for the problem at hand.
Edit: Possibly the "realistic assumption" is the 10% figure from the problem statement.
  • #54
However thank you for your help!
  • #55
Using your method from your original post and an efficiency of 0.6% will give you a reasonable answer.
This efficiency is derived from data on Estes model rocket performance.
  • #56
No, that would mean we needed:
1.63525964 / 0.6 *100 = 272.543273333 grams of gunpowder
That would mean that we needed more gunpowder than the rocket itself is
  • #57
What is 1.63... and why multiply 0.6 times 100?
  • #58
1.6 is the mass of the gunpowder
so if it is 0.6% efficient that would mean:
1.6 gr | 0.6%
Mr | 100%
  • #59
Do you mean "at 100% efficiency"? If so, redo your calculations.
  • #60
First, define 100% efficiency.
  • #61
100% efficiency = all gunpowder energy ends up as mgh energy.
  • #62
That is an incorrect definition of rocket efficiency.
  • #63
I believe this is the OP's definition and a useful one here if defined as such.
  • #64
okay to calculate the amount of gunpowder we need in total (at 100%)
i assumed that the 1.6 grams is the amount of gunpowder we needed only to fly up to 75 meters
because it is only 0.6% efficient it means that if i have an amount of gunpowder (100%) only 0.6% goes into flying the rocket and that is the 1.6 grams we needed.
so if 1.6 = 0.6%
272.5 grams = 100%
  • #65
Show calculation to get 1.6 grams.
  • #66
Given the numbers we have come up with for exhaust velocity and rocket velocity at burnout, a figure of 10% as given in the problem statement cannot possibly be compatible with the definition that you propose.
The definition that you propose is extremely sensitive to rocket velocity at burnout. That makes it exeedingly unreliable to pick a figure up from the Internet and try to plug it into an arbitrary problem. Suppose, for instance, that we double the amount of gunpowder burned. We double velocity at burnout and we achieve a high point with roughly four times the energy according to E=mgh. We have doubled the efficiency of our rocket motor without doing anything to the rocket motor. That is not a good thing to see in an efficiency metric.
  • #67
Where did I say a figure of 10% is compatible? I said 0.6%.
Anyway, so what answer did you get?
  • #68
Your figure of 0.6% is not compatible either. No number is.
Edit: The homework forums are not a place for answers to be posted. The calculation of the 1.6 gram figure has been shown. The calculation of the exhaust velocity has been shown.
  • #69
168918791999 said:
Keg = Eg
KEg = 0.5*Mg*Vg2
Eg = 2.7x106*mg
0.5*Vg2 = 2.7x106
Vg2 = 5.4x106
Doesn't this calculation assume all the chemical energy ends up as mechanical energy of the exhaust?
Oops, just reread #48; never mind.
So, how much energy is being used to heat the exhaust and push back the atmosphere?
(Space shuttle exhaust from the main engines is at 1600oC.)
  • #70
A fascinating thread.
I would love to see the OP post the "official" correct answer.
