How to show that a transverse intersection is clean, but not conversely?
In summary, a transverse intersection between two manifolds inside another manifold means that their tangent spaces span the big tangent space. If the intersection between the two manifolds is also an embedded manifold, it is considered clean. The proof for this statement is found in Guillemin and Pollack's book, specifically in chapter 1 on page 27. However, the link provided contains false statements, making the validity of the forward statement questionable.
huyichen
29
definitions please? i assume you are discussing two manifolds inside another manifold, and that transverse means the two tangent spaces span the big tangent space.
so what does clean mean?
If K and L are embedded manifold of M, and T_p(K intersect L)=T_p K intersect T_p L and K intersect L is again a embedded manifold , then we say K intersect L is clean
then the proof seems trivial. i.e. the converse statement is trivial, and the truth of the forward statement seems to be the implicit function theorem.
see guillemin and pollack, chapter 1, page 27 ff..
Related to How to show that a transverse intersection is clean, but not conversely?
1. How do you define a transverse intersection?
A transverse intersection is a type of intersection between two objects, where the objects intersect at a right angle or perpendicular to each other. In other words, the intersection occurs in a "clean" or non-tangled manner without any overlapping or tangential points.
2. What is a clean intersection in terms of transverse intersections?
A clean intersection in the context of transverse intersections refers to an intersection where the tangent spaces of the two objects at the intersection point are distinct and span the entire space. This means that the two objects are not "sticking" or overlapping at the intersection point, and there are no tangential directions between them.
3. How do you show that a transverse intersection is clean?
To show that a transverse intersection is clean, you can use the definition of a clean intersection and check if the tangent spaces of the two objects at the intersection point are distinct and span the entire space. This can also be demonstrated by examining the Jacobian matrix of the intersection equation, which should have full rank at the intersection point.
4. Can a transverse intersection be clean but not conversely?
Yes, it is possible for a transverse intersection to be clean but not conversely. This means that the intersection is clean, but the converse may not hold true. In other words, the objects may intersect cleanly, but their tangent spaces may not be distinct and span the entire space. This can happen when the objects have a tangential direction at the intersection point, but it is not significant enough to cause tangling or overlapping.
5. What are some applications of understanding clean transverse intersections?
Understanding clean transverse intersections is important in various fields of science and mathematics, such as differential geometry, topology, and physics. It is particularly relevant in studying critical points and singularities, as well as in applications like robotics, computer graphics, and computer vision.
  • Differential Geometry
  • Computing and Technology
