Hydrogen spectrum calculations
In summary, the prominent red line in atomic hydrogen has a wavelength of 6.60 x 10-7 m and the energy of a photon with this wavelength is 3.0E-19 J.
catkin
218
This is from Advanced Physics by Adams and Allday, part 8 Modern Physics, Practice Exam Question 15.
  • The spectrum of atomic hydrogen contains a prominent red line having a wavelength of 6.60 x 10-7 m. Calculate the energy of a photon with this wavelength.
  • The ionisation energy of hydrogen is 2.18 x 10-18 J. The next allowed energy level above the ground state in hydrogen has an energy -5.40 x 10-19 J. Show by calculation that the lowest energy level cannot be involved in the production of the prominent red line in a.
E = h f
v = f λ
f = v / λ
E = h v / λ
= 6.63E-34 * 3.00E+8 / 6.60E-7
= 3.0E-19 J ct2sf (Book gives same answer. Calculated 3.013636364e-19)
A drop from the next allowed energy level above the ground state to the ground state would release 5.40E-19 J. This does not match energy calculated in a so this drop cannot be the one that produces the red line having a wavelength of 6.60E-7 m.
A free electron dropping to the next allowed energy level above the ground state would release 2.18E-18 - 5.40E-19 = 1.64E-18 J. This is more than the energy that produces the red line having a wavelength of 6.60E-7 m so I cannot, on the available data, show that some drop down to the next allowed energy level above the ground state does not produce the red line having a wavelength of 6.60E-7.
Hmm ... :confused:
I believe by lowest energy level the question means the ground state, since this is the lowest allowed energy level. If this is the case, then you can show that the observed emission line cannot possibly be cause by a transition to the ground state.
Ah! Thank you Hootenanny :smile:
Then an answer to b is:
The ground state is the lowest energy level. When an excited electron drops from the next allowed energy level to the ground state the energy given off is 2.18E-18 - 5.40E-19 = 1.64E-18 J. This is more than the energy calculated in a so this drop cannot be the one that produces the red line in a. Drops from other allowed energy levels to ground state give off more energy so also cannot produce the red line in a. Thus the lowest energy level cannot be involved in the production of the prominent red line in a.
Sounds spot on to me :approve:
Thanks :smile:
catkin said:
Thanks :smile:
A pleasure :smile:
Related to Hydrogen spectrum calculations
1. What is a hydrogen spectrum?
A hydrogen spectrum is a series of lines or bands of light produced when the energy levels of hydrogen atoms change. It is unique to hydrogen and is used to identify the element and its properties.
2. How is the hydrogen spectrum calculated?
The hydrogen spectrum is calculated using the Rydberg formula, which relates the wavelengths of the spectral lines to the energy levels of the hydrogen atom. This formula takes into account the charge of the nucleus, the mass of the electron, and the electron's energy states.
3. Why is the hydrogen spectrum important?
The hydrogen spectrum is important because it provides scientists with a way to study the energy levels and transitions of atoms. It also helps in understanding the structure of the atom and has been used in the development of quantum mechanics.
4. What information can be obtained from the hydrogen spectrum?
The hydrogen spectrum can provide information about the energy levels and transitions of hydrogen atoms, including the wavelengths of spectral lines, the energy differences between levels, and the probability of an electron transitioning between levels.
5. Can the hydrogen spectrum be used to identify other elements?
Yes, the hydrogen spectrum can be used to identify other elements as each element has its own unique spectral lines. However, the hydrogen spectrum is particularly useful in identifying hydrogen in other substances, such as in stars or gas clouds, due to its simplicity and distinct spectral lines.
10K
