Icy slope, toboggan, find coefficient of friction
In summary: It's not to any use for anything, but it is the same as the acceleration that you get if you don't include the toboggan.It's not to any use for anything, but it is the same as the acceleration that you get if you don't include the toboggan.
marsten
A girl, with the mass m, slides down an icy slope at the time t1=τ. The slope is inclined at 30° below horizontal. The coefficient of kinetic friction between the girl and icy slope is μk. The girl notices that she can slide down the slope significantly faster if she sits on a toboggan. The time to slide down on a toboggan (which also has the mass m) proves to be t2=½τ. The friction between the toboggan and icy slope can be assumed to be negligible. Determine μk.
[itex]mgsin\alpha-f_k=ma_{x}[/itex]
[itex]n=mgcos\alpha[/itex]
[itex]f_{k}=μ_{k}n=μ_{k}mgcos\alpha[/itex]
I did a free-body diagram of the girl on toboggan.
Then I tried to solve ax with the equations above and got ax=4,9 m/s2 since the kinetic friction between the toboggan and surface is negligible.
Not sure what to do next or if I'm doing wrong from the beginning?
Thanks for any help!
/Marcus from Sweden
/Marcus from Sweden
That's good so far. Now that you have the time and acceleration, that might suggest using what other equations?
marsten said:
##mgsin\alpha-f_k=ma_{x}##
Please define ax. From the first equn above, it looks like it's the acceleration without the toboggan.
Id be inclined to add a value for m ( i assume g = 9.8) and maybe set it up on an excel spreadsheet, then you can quickly detemine if altering m alters the result.
It's not hard to see that the mass and g are both irrelevant. One way is through dimensional analysis. We are given two times and an angle. Suppose we have m and g as well. How could you combine those algebraically into an equation in which the dimensions (M, L, T) match up? There is no term with an M component to balance with m, and no term with a length component to balance that in g. Therefore m and g cannot feature in the equation.
Some equation to find the distance? Like:
[tex]s=v_0t+½a_xt^2=½a_xt^2[/tex]
Ahh, should I use 2m? Using the same equation gives me:
[itex]2mgsin\alpha-\mu_k2mgcos\alpha=ma_x[/itex]
[itex]a_x=2g(sin\alpha-\mu_kcos\alpha)[/itex]
[itex]a_x=2*9,81*sin(30)[/itex]
[itex]a_x=9,81 m/s^2[/itex]
Sure, but there are two different accelerations - one with friction and one without.
Please answer my question in post #3.
No, you don't know the mass of the toboggan and you don't care. If you increase the mass on the left of that equation you need to increase it on the right too. They will always cancel. The acceleration is obviously never as much as g!
Sorry. The acceleration that I first calculated must be the acceleration without friction and without toboggan.
So as long as I put [itex]\mu_k=0[/itex] I will always get the same result (4,91 m/s^2). Could this acceleration help me anywhere? Or is it not to any use for me?
That is useful. If you assume the distance is s then it allows you to write an expression for the time taken without friction. But please, don't put a numerical value for g, just leave it as 'g'.
Then repeat the exercise for the case where there is friction. Same s, same g, different acceleration, different time. Use different symbols for the two accelerations and times.
The different accelerations that I have come up with so far is:
Acceleration with friction: [itex]a_{x1}=g(sin\alpha-\mu_kcos\alpha)[/itex]
Acceleration without friction: [itex]a_{x2}=g(sin\alpha)[/itex]
And the given times:
Time with friction: [itex]t_1=\tau[/itex]
Time without friction: [itex]t_2=\frac{1}{2}\tau[/itex]
And by using the equation that I mentioned in #6, [itex]s=½a_xt^2[/itex], these are the two times that I've come up with:
Time with friction:
[itex]s=\frac{a_{x1}t_1^2}{2}⇔s=\frac{g(sin\alpha-\mu_kcos\alpha)\tau^2}{2}⇔2s=g(sin\alpha-\mu_kcos\alpha)\tau^2⇔\tau=\sqrt{\frac{2s}{g(sin\alpha-\mu_kcos\alpha)}}[/itex]
[itex]s=\frac{a_{x2}t_2^2}{2}⇔s=\frac{g(sin\alpha)\tau^2}{4}⇔4s=g(sin\alpha)\tau^2⇔\tau=\sqrt{\frac{4s}{g(sin\alpha)}}[/itex]
Then I put the times equal each other and solved for [itex]\mu_k[/itex] like this:
[tex]\frac{2s}{g(sin\alpha-\mu_kcos\alpha)}=\frac{4s}{g(sin\alpha)}[/tex]
[tex]2s(g(sin\alpha))=4s(g(sin\alpha-\mu_kcos\alpha))[/tex]
[tex]g(sin\alpha)=2g(sin\alpha-\mu_kcos\alpha)[/tex]
[tex]sin\alpha=2(sin\alpha-\mu_kcos\alpha)[/tex]
[tex]sin\alpha=2sin\alpha-2\mu_kcos\alpha[/tex]
[tex]2sin\alpha-sin\alpha=2\mu_kcos\alpha[/tex]
[tex]sin\alpha=2\mu_kcos\alpha[/tex]
[tex]\mu_k=\frac{sin\alpha}{2cos\alpha}[/tex]
Then put in the values
[tex]\mu_k=\frac{sin30}{2cos30}=0,29[/tex]Am I doing right? The result looks good to me.
##s=\frac{a_{x2}t_2^2}{2}⇔s=\frac{g(sin\alpha)\tau^2}{4}⇔4s=g(sin\alpha)\tau^2⇔\tau=\sqrt{\frac{4s}{g(sin\alpha)}}##
I think you lost a factor of 2 in there somewhere. The rest looks ok.
Ok, so it will be something like this?
[itex]s=\frac{a_{x2}t_2^2}{2}=\frac{g(sin\alpha)\tau^2}{2\cdot2^2}=\frac{g(sin\alpha)\tau^2}{8}[/itex]
[itex]\tau=\sqrt{\frac{8s}{g(sin\alpha)}}[/itex]
Yes.
haruspex said:
Yes.
The final answer will be [itex]\mu_k=0,14[/itex]
Thank you very much!
Nope, not the correct answer. Missed one thing. It's [itex]\mu_k=0,43[/itex]
Thanks again!
Thanks again!
Right, it's ##\frac 34 \tan(\alpha)##, yes?
Yep!
1. What is an icy slope?
An icy slope is a surface that is covered in a layer of ice, making it slippery and difficult to walk on.
2. What is a toboggan and how is it related to icy slopes?
A toboggan is a long, narrow sled that is commonly used for sliding down snowy or icy slopes. It is specifically designed for use on slippery surfaces and can be used on icy slopes for recreational purposes.
3. What is the coefficient of friction and why is it important on an icy slope?
The coefficient of friction is a measure of the resistance to motion between two surfaces in contact. It is important on an icy slope because it determines how much friction there is between the toboggan and the slope, which can affect the speed and control of the toboggan.
4. How can the coefficient of friction be calculated on an icy slope?
The coefficient of friction on an icy slope can be calculated by measuring the weight and normal force of the toboggan on the slope, and then using the formula μ = F/N, where μ is the coefficient of friction, F is the force of friction, and N is the normal force.
5. What factors can affect the coefficient of friction on an icy slope?
The coefficient of friction on an icy slope can be affected by factors such as the temperature of the ice, the texture of the ice, the weight and shape of the toboggan, and any external forces acting on the toboggan, such as wind or gravity.
