Identifying Broken Connections on an Extensional Viscosity Measuring Instrument
  • Thread starter Thread starter watson.894
    Component
The discussion centers on identifying a component with two broken connections on an extensional viscosity measuring instrument, suspected to be a fuse chip or jumper block. Participants debate whether the component is a blown fuse or a programmable jumper, with indications that it may have overheated due to excessive current. Suggestions for finding replacement parts include searching for "8-pin fuse chips," although the exact nature of the component remains uncertain. The conversation highlights the importance of addressing the underlying issue that caused the fuses to blow before replacing them. Overall, the consensus leans towards the component being a jumper chip that was overloaded.
watson.894
What is this component in the middle with the two broken connections? It is on an instrument for measuring extensional viscosity that is not working. It looks like a power amp and a wire wound resistor on the same board got real hot. Don't know if there is any relationship to the two broken connections pictured.
It's a fuse chip with four fuses, two of which have blown
Likes billy_joule
Thank you very much! However, I am having a heck of a time finding similar parts on the internets. Do you have any suggestions on where to find it or how to search for it?
Regards,
Lucas
Regards,
Lucas
Really? What did you try? Googling for "8-pin fuse chips" got a TON of hits
In an event, the fuses blew for a reason. If you replace them before fixing the cause, the new fuses will probably blow also.
What Daz posted looked like an exact match. If it was a fuse, would the top blow off like that?
A Dil jumper was used as a low-cost alternative for a DIP switch. They were used for configuration settings that aren't expected to change after manufacture. You plug (or solder) the thing in and then punch or snip the straps as required.
Likes davenn, Averagesupernova and watson.894
very doubtful that it is a fuse.. it would be hard to make accurate current control in that structure
I believe that it t is a programable ( well one time) jumper block.
A cheaper version of a DIP switch
Likes Averagesupernova and watson.894
I assumed that it was topless so the fuses could be replaced, but it could be, as others have suggested, a jumper chip. If it IS a jumper chip then something REALLY drew too much current.EDIT: yeah, now that I look, I don't see any "topless" fuse chips so I guess it must be a jumper chip that really got overloaded.
Is it possible those two jumpers were cut at the factory when it was made?
Likes davenn
I would try tracing the circuit in that area. How thick are the PCB traces that connect to the jumpers?
The plastic looks melted under the two broken links, so that suggests probably not.
Why would jumpers narrow down to a thin bottleneck shape like that? If I was going to make a fuse out of foil, a shape like that would be perfect. You could fine tune the amp rating of the fuse by how narrow the bottleneck is.
My guess is that it is something that is one time programmable.
no, specific jumpers are cut to provide a certain function
and when used in this fashion, jumpers can always be rejoined and other combinations cut
I have used this method often in PLL radio systems where I want to set the n=counter number to give the correct frequency
there are many other uses :smile:
Dave
Likes watson.894
Dave
Oh, it looked to me like a blown fuse. Guess you're right, though.
Likes davenn
a trap for young players :wink::-p ( tease, tease knowing you are my senior )
What? I can't be more than 30 or 40 years older than you :smile:
hahaha --- one needs a sense of humour to survive this world
Thanks buddy :smile:
Friday is here and it's time to go home from the salt mine yipeee
here's part of one totally wrecked bit of gear I dealt with today ... $15,000 GPS receiver very wet and corroded
you can still see the water droplets on those ribbon cables
Well, just remember that Friday is POETS day.
Piss
On
Everything,
Tomorrow's
Saturday
Likes davenn
I assumed they were programming jumpers and were opened with a hot soldering iron.
