Integral of squared univariate PDF
In summary: It isn't clear what ##\int F(x)df(x)## would mean in the notation of ordinary calculus.It means doing an integration by substitution. You can do the substitution ##z = f(x)## and transform the problem, but you can't simply substitute ##dz## in place of ##dx##. You must use the relation ##x = f^{-1}(z)## , ##dx = D_z f^{-1}(z) dz ##.
Kvad
Hi all,
I was trying to find an answer, but couldn't, what is the integral of the squared probability density function? It doesn't seem to be equal to the square of cumulative distribution function, but how to tackle it?
∫(f(x))2dx = ? Can we transform it into, say, ∫f(x)dF(x)? and then ∫F'(x)dF(x) may be used somehow? I am not a mathematician so just throwing out some ideas I had, would appreciate any help with it :)
The transforms you have are O.K., but I can't see where you can go from there. You might try some simple pdf's and see what happens.
It isn't clear what you mean by "an answer". What requirements do you want an answer to satisfy?
The integral can be expressed in various ways.
For example, ##\int (f(x))^2 dx = \int f(x) f(x) dx ##, so you could use integration by parts.
Also ##\int (f(x))^2 dx = \int (1)( (f(x))^2) dx## so you could use integration by parts on that product.
I am looking just for an analytical answer, If I do integration by parts correctly then I get this?
## F(x)f(x) = ∫f'(x)F(x)dx + ∫f(x)^2dx ##
Now ##∫f(x)^2dx=F(x)f(x)-∫F(x)f'(x)dx## and I am not sure about how to tackle the last integral?
Kvad said:
I am looking just for an analytical answer.
What do you mean by an "analytical answer"? - an expression without integral signs? - a polynomial whose terms involve only constants and the terms ##f(x)## and ##F(x)##? - a polynomial whose terms involve only constants and the terms ##F(x)##, ##f(x)##, and ##f'(x)## ?
Yes.
I'm not sure what kind of expression you are aiming for.
Something that will not have any integrals and derivatives, expressed in parameters and f(x) and F(x)...
I don't think that can be done (for an arbitrary f(x)) unless you use parameters that come from evaluating integrals and derivatives of f(x) at particular values of x.
For example, you can expand ##g(x) = (f(x))^2## in Taylor series about ##(x-a)## and you get a possibly infinite series of polynomial terms involving ##x## and constants, but the constants are computed by evaluating derivatives of ##g(x)## at ##x = a##. If you integrate that series term-by-term you get an answer that is a series with polynomial terms.
Well unfortunately I am interested only in the general case... But maybe if I rewrite ##∫F(x)f'(x)dx## as ##∫F(x)df(x)## getting an integration of CDF by PDF, maybe this problem is known to have some solution or on the contrary unsolvable?
I tried to substitute ##f(x)=z## and then get an easy integral ##∫\frac{z^2}{2}dz##, but the solution does not match the first part if differentiated... is it wrong to do this type of substitutions?
It isn't clear what ##\int F(x)df(x)## would mean in the notation of ordinary calculus except that it denotes doing an integration by substitution. You can do the substitution ##z = f(x)## and transform the problem, but you can't simply substitute ##dz## in place of ##dx##. You must use the relation ##x = f^{-1}(z)## , ##dx = D_z f^{-1}(z) dz ##. If ##f## is not 1-to-1, you have to break up the integration into intervals where it is 1-to-1 so that ##f^{-1}## is defined on those intervals.
1. What is the definition of the integral of squared univariate PDF?
The integral of squared univariate PDF is the area under the curve of a probability density function (PDF) when the function is squared.
2. Why is the integral of squared univariate PDF important in statistics?
The integral of squared univariate PDF is important in statistics because it allows us to calculate the variance of a random variable, which is a measure of how spread out the data is. It also helps us to calculate various moments of a distribution, which can be used to describe the shape and behavior of the data.
3. How is the integral of squared univariate PDF calculated?
The integral of squared univariate PDF is calculated by taking the antiderivative of the squared PDF function and then evaluating it at the upper and lower limits of integration. This is done using techniques such as integration by parts or substitution.
4. Can the integral of squared univariate PDF be negative?
No, the integral of squared univariate PDF cannot be negative. The squared PDF function is always positive, and the integral represents the area under the curve, so it will always be a positive value.
5. How is the integral of squared univariate PDF related to the original PDF?
The integral of squared univariate PDF is related to the original PDF through the moment generating function. The moment generating function can be used to find the moments of a distribution, including the variance, which is calculated using the integral of squared univariate PDF. Therefore, the integral of squared univariate PDF is a useful tool for understanding and analyzing the behavior of the original PDF.
