Can Integration by Parts Solve This Integral Problem?
In summary, the line integral along the curve C represented by the equations x = 2t, y = 3t^2 (0 ≤ t ≤ 1) can be evaluated using the substitution t = (1/3)sinh(u). This will simplify the integral and make it easier to solve.
Knissp
75
[tex]\int_0^1 (6t^2 (1+9t^2)^{1/2} dt) [/tex]
[tex]\int u dv = u v - \int v du [/tex]
[tex]=6 * \int (t^2 (1+9t^2)^{1/2} dt)[/tex]
[tex]= 6 * \int (t * t (1+9t^2)^{1/2} dt)[/tex]
Let [tex]u = t [/tex]; let [tex]dv = t (1+9t^2)^{1/2} dt [/tex];
then [tex]du = dt[/tex]; and [tex]v = \int t (1+9t^2)^{1/2} dt[/tex]
(using w-substitution:
[tex] w = 1+9t^2[/tex],
[tex] dw = 18t dt[/tex];
[tex] dw/18=dt[/tex];
[tex] \int t (1+9t^2)^{1/2} dt [/tex]
=[tex] 1/18 \int w^{1/2} dw = 1/18 * 2/3 w^{3/2} = w^{3/2} / 27 = (1+9t^2)^{3/2}/27 [/tex]
[tex] v = [(1+9t^2)^{3/2}/27 [/tex]
[tex] \int(u dv) = u v - \int (v du) [/tex]
[tex] = t * (1+9t^2)^{3/2}/27 - \int ((1+9t^2)^{3/2}/27 dt)[/tex]
now i need help integrating [tex] (1+9t^2)^{3/2}/27 [/tex].
Hi Knissp! :smile:
Knissp said:
oooh, that's horrible! :cry:
Hint: start again, and make the obvious substitution at the beginning. :wink:
Can you use trig-sub or are you required to solve it by int. by parts?
I can use any method, I just thought by parts would be easiest. What trig subst. would I use?
and Tim: would the obvious substitution be u=t^2 and dv = sqrt(1+9t^2) dt? Then I have to integrate sqrt(1+9t^2) dt...
[tex]t=3\tan\theta[/tex]
[tex] t=3\tan\theta [/tex]
[tex] dt = 3\sec^2\theta d\theta [/tex]
[tex] \int (6t^2 (1+9t^2)^{1/2} dt) [/tex]
= [tex] \int (6(3\tan\theta )^2 (1+9(3\tan\theta)^2)^{1/2} 3\sec^2\theta d\theta) [/tex]
=[tex] \int (54 \tan^2\theta (1+81 \tan^2\theta)^{1/2} 3\sec^2\theta d\theta) [/tex]
=[tex] 162 \int (\tan^2\theta (1+81 \tan^2\theta)^{1/2} \sec^2\theta d\theta) [/tex]
Should I keep going from here?
OMG! I'm so sorry ... lol
First, you have to simplify it ... to find what your "a" should be.
hmm... I think rocomath meant to say [itex]3t=tan(\theta)[/itex] ;0)
[tex]1+9t^2[/tex]
Dividing by 9, [tex]\sqrt{9\left(\frac 1 9+t^2\right)}=3\sqrt{\frac 1 9+t^2}[/tex]
[tex]t=\frac 1 3\tan\theta[/tex]
Now I have
[tex] \int 2/9 \tan^2\theta \sec^3\theta d\theta [/tex]
which is
[tex] \int 2/9 \frac{\sin^2\theta}{\cos^5\theta} d\theta [/tex]
Try Integration by parts now (don't forget that your limits of integration are [itex]tan^{-1}(0) \rightarrow tan^{-1}(3)[/itex] now)
Knissp said:
Now I have
[tex] \int 2/9 \tan^2\theta \sec^2\theta d\theta [/tex] …
Hi Knissp!
(have a theta: θ and a squared: ² and a cubed: ³ and an integral: ∫ :smile:)
Isn't it tan²θsec³θ?
I have tried several ways none of which worked, too much to post it all. Just a little more help needed: would it be best to use the identity 1+tan²θ = sec²θ before integrating by parts? edit: just to add, in case anyone wanted to know where this problem is from,
Let C be the curve represented by the equations
x=2t, y=3t² (0≤t≤1) dx/dt=2, dy/dt=6t
Evaluate the line integral along C: ∫(x-y)ds
ds = √((dx/dt)^2+(dy/dt)^2) dt = √(4+36t^2) = 2√(1+9t^2) dt
∫(x-y)ds = ∫((2t-3t^2)*2√(1+9t^2) dt = ∫((4t√(1+9t^2) dt - ∫((6t^2)√(1+9t^2) dt
I was able to solve the ∫((4t√(1+9t^2) dt part using u-substitution, but I got stuck on ∫((6t^2)√(1+9t^2) dt which is why I originally asked for help. Question: Is my way of attempting this problem the most efficient, or is there a better way so I can avoid this integral which involves trig-substitution entirely?
Use the Identity [itex]sin^2(\theta)=1-cos^2(\theta)[/itex] to break the integral into two parts (sec^3 and sec^5). Then use integration by parts with [itex]u=sec(\theta)[/itex] and [itex]dv=sec^2(\theta)d\theta[/itex]...you will have to use by parts twice for the sec^5 term...you'll also need to look up the integral of [itex]sec(\theta)d\theta[/itex]
tan²θsec³θ = (sec²θ-1)sec³θ = [tex]\sec^5\theta - \sec^3\theta[/tex]
Looking at the sec^3 part, let u = secθ, dv=sec²θ dθ; du=secθtanθ, v=tanθ.
uv-∫vdu = secθtanθ - ∫tan²θsecθ dθ
Is that right so far? because then I have to make another u-sub...
looks fine so far; now there is a trick you need to use...
-∫tan²θsecθ dθ =∫(1-sec²θ)secθ dθ =∫secθ dθ-∫secθ^3 dθ
=> 2 ∫secθ^3 dθ=secθtanθ+∫secθ dθ
Aaahhh I get it now. :bugeye: Sorry that so long. Thank you all for your help!
hyperbolic trig substitution
hmm … when you have a square, there's always the choice of a trig substitution, or a hyperbolic trig substitution …
in this case, either t = (1/3)tanθ, or t = (1/3)sinhu …
using the tan worked, but it was rather complicated.
Try it again, using the sinh instead! :smile:
Related to Can Integration by Parts Solve This Integral Problem?
1. What is integration by parts?
Integration by parts is a method used in calculus to find the integral of a product of two functions. It is based on the product rule for differentiation and can be used to evaluate integrals that cannot be solved by other methods.
2. When should integration by parts be used?
Integration by parts should be used when the integral contains a product of two functions with one of them being difficult to integrate. It is also helpful when using substitution and other integration techniques are not applicable.
3. What is the formula for integration by parts?
The formula for integration by parts is ∫u dv = uv - ∫v du, where u and v are the two functions being multiplied together and du and dv are their respective differentials.
4. How do you choose u and dv in integration by parts?
To choose u and dv in integration by parts, use the acronym LIATE: Logarithmic, Inverse trigonometric, Algebraic, Trigonometric, Exponential. The function that comes first in this list should be chosen as u and the other as dv.
5. What are some common mistakes made in integration by parts?
Some common mistakes in integration by parts include choosing the wrong u and dv, forgetting to add the constant of integration in the final answer, and not simplifying the integral before applying the formula. It is also important to pay attention to the signs and make sure to distribute them correctly.
