Is the Theory of Everything necessarily deterministic?
In summary, the theory of everything would be deterministic because the observer can only see the linear coordinate of the vector field. The theory would be probabilistic because the free motions of the singularities are arbitrary.
SEYED2001
51
Hi
I am aware that QM isn't deterministic. Should a theory of everything be deterministic to be a theory of everything, and if yes, then how can it be when QM as a part of it is not deterministic?
Thanks in advance
Seyed
SEYED2001 said:
Should a theory of everything be deterministic to be a theory of everything?
Why should it?
PeroK said:
Why should it?
Maybe because it must predict everything to be a theory for them? That's what theories do, to predict don't they?
Maybe they predict probabilities.
A classical heuristic is that there is no fundamental difference between deterministic and probabilistic theories, in the sense that one could see the most fundamental theory as deterministic, with the probabilistic theories arising due to our inability to fully know the state of all variables in the fundamental deterministic theory. The variables whose state one does not know can be considered "hidden variables" of the probabilistic theory.
It is unclear at the moment whether hidden variables can be constructed for quantum theory. Bohmian mechanics is one well known proposal for hidden variables for non-relativistic quantum mechanics. It is not well understood whether hidden variable theories can be constructed for other types of quantum theory.
Great. I see what you mean. If probabilities are the only things out there then a theory of everything is a theory for no more than probabilities. Thanks.
Thank you for your reply. Is any relation between the existence of hidden variables and existence of a theory of everything ever established?
I asked this since I think I can establish one and so wondering if is worth spending time on.
Deterministic hidden variables and theories of everything are usually considered attempts to solve different types of problems.
Usually, by a theory of everything, we mean a quantum theory of everything. Whether a quantum theory of everything is possible is a matter of research. String theory is a research area that attempts to construct a quantum theory of everything.
Deterministic hidden variables are usually discussed with respect to attempts to solve the "measurement problem" present in all quantum theories (including string theory, if it were to succeed). A good description of the "measurement problem" of quantum theory is John Bell's article Against 'measurement'.
Thank you!
Here you can reason from the opposite and refer to the next example. Suppose we have a theory of everything that describes the dynamics of a vector field on an infinite cylinder. Moreover, the dynamic laws of motion of the singularities of the vector field (prototypes of particles) are both deterministic, since they follow from some integral variational equation, and probabilistic, since the free motions of the singularities are arbitrary in the choice of speed and direction. Now imagine that the feature of the vector field, which serves as the prototype of the particle, is the streamline of the vector field, outlining the defining circle on the cylinder, and the observer can only see the linear coordinate of the cylinder (straight or helical line). Now what can we say about the dynamic behavior of "particles" on the line of the observer, is it deterministic or not?
The point that a theory which predicts only probabilities is not a theory of everything given that there exist, in reality, also actual values, is a nice one. But one should not forget that "theory of everything" has a slightly different established meaning - simply a theory which covers all the particles and fields observed up to now, that means, at least all those of the SM together with gravity. In this sense, even an obviously incomplete theory could count as a "theory of everything", once it covers everything observed up to now.
Similarly, the most fundamental theory may be probabilistic, and deterministic theories may appear on the large scale for averages.
No, that's clear. De Broglie-Bohm theory works for relativistic field theory too. The classical reference for this is Bohm.D., Hiley, B.J., Kaloyerou, P.N. (1987). An ontological basis for the quantum theory, Phys. Reports 144(6), 321-375
Likes Demystifier
1. The theory of everything does not necessarily need to be deterministic.
2. Some formulations of QM, such as Bohmian mechanics, are deterministic.
3. Even if we accept that QM is not deterministic, the theory of everything may be deterministic by saying that QM is emergent, very much like classical statistical mechanics (which is probabilistic) emerges form deterministic classical mechanics.
Likes mattt
It's quite clear to me that Bohmian mechanics works for relativistic QFT as well. See e.g. my non-technical lecture http://thphys.irb.hr/wiki/main/images/3/3d/QFound5.pdf
SEYED2001 said:
... a theory of everything is a theory for no more than probabilities. Thanks.
And why is that necessarily a bad thing?
As an aside: This is certainly outside my comfort zone, but this paper[1] discusses QFT without the insistence that we must be able to define a quantum state evolving unitarily through spacelike surfaces (which, sans some fancy theory like string theory, runs into problems if there is a topology change induced e.g. by a black hole). Hartle seems to be happy to drop that condition, and compute amplitudes via a sum-over-histories approach (see eq 4.2). He argues that even though information might appear lost on specific spacetime surfaces, it is still present throughout spacetime.
I.e. A unitarily evolving quantum state is desirable even if a probabilistic interpretation is adopted. But even this might not be necessary, or at least not enforced by the formalism.
There might be a million things wrong with this, or it might just be a project that has generated little scientific interest (only 8 citations)
[1] https://arxiv.org/abs/gr-qc/9808070
For a similar approach see also my
http://de.arxiv.org/abs/0905.0538
http://de.arxiv.org/abs/0912.1938
Likes Morbert
See this ScienceX News article for a general audience explanation as to why we must obtain probabilistic results for Bell states.
1. Is the Theory of Everything proven to be deterministic?
No, the Theory of Everything is still a theoretical concept and has not been proven to be true. It is a proposed framework that aims to explain all physical phenomena in the universe, including the laws of nature. Whether or not it is deterministic is still a topic of debate and has not been definitively answered.
2. What is determinism and how does it relate to the Theory of Everything?
Determinism is the philosophical concept that all events, including human actions, are ultimately determined by causes external to the will. In the context of the Theory of Everything, determinism refers to the idea that the laws of nature are fixed and predetermined, and that everything in the universe can be explained by these laws.
3. Are there any arguments against the Theory of Everything being deterministic?
Yes, there are some arguments against the Theory of Everything being deterministic. Some scientists and philosophers argue that the uncertainty principle in quantum mechanics suggests that the behavior of particles is not completely predictable, making determinism impossible. Others argue that human consciousness and free will cannot be explained by deterministic laws.
4. How would a deterministic Theory of Everything impact our understanding of the universe?
If the Theory of Everything were proven to be deterministic, it would mean that every event in the universe, including human actions, is predetermined and can be explained by the laws of nature. This could have significant implications for our understanding of causality, free will, and the nature of reality.
5. Can the Theory of Everything ever be proven to be deterministic?
It is currently impossible to definitively prove whether or not the Theory of Everything is deterministic. As our understanding of the universe and its laws continues to evolve, it is possible that new evidence or theories may shed light on this question. However, it may ultimately remain a philosophical and theoretical debate rather than a proven fact.
  • Quantum Interpretations and Foundations
11K
