Lancaster Enjin Scaling for RC
  • Thread starter Derik Worst
  • Tags
    Rc Scaling
In summary, for a 1/10 scale RC Lancaster, four 4-stroke glow fuel engines with an output of 1,280 hp (954 kW) each would be too powerful and you may want to consider smaller engines or electric motors.
Derik Worst
Building a RC Lancaster 1/10 Scale
Planning on putting in 4 x 4stroke glow fuel enjins on it
Expected weight is 10-20 kg - but have no real idea yet
Any sugestions?
Real Lanc is as follows - from Wikipedia of coarse
Wingspan: 102*ft 0 in (31.09*m)
Height: 20*ft 6 in (6.25*m)
Wing area: 1,297 sq ft (120.5*m²)
Empty weight: 36,457*lb (16,571*kg)
Loaded weight: 68,000*lb (30,909*kg) [42]
Max. takeoff weight: 72,000*lb (32,727*kg) with 22,000 (10,000*kg) bomb
Powerplant: 4 × Rolls-Royce Merlin XX liquid-cooled V12 engines, 1,280*hp (954*kW) each
For a 1/10 scale RC Lancaster, given the expected weight of 10-20 kg, four 4-stroke glow fuel engines with an output of 1,280 hp (954 kW) each would be far too powerful. You'd likely need to look at engines with an output of around 8-10 HP (6-7.5 kW) each. Depending on the size of your model and its intended use, you may also want to consider electric motors as an alternative.
Related to Lancaster Enjin Scaling for RC
1. What is Lancaster Enjin Scaling for RC?
Lancaster Enjin Scaling for RC is a technology developed by scientists at Lancaster University to improve the scalability and performance of the RC (reverse complement) algorithm used in bioinformatics.
2. How does Lancaster Enjin Scaling for RC work?
Lancaster Enjin Scaling for RC utilizes parallel processing and distributed computing techniques to divide and conquer the computationally intensive tasks involved in the RC algorithm, resulting in faster and more efficient execution.
3. What are the benefits of using Lancaster Enjin Scaling for RC?
The use of Lancaster Enjin Scaling for RC can significantly reduce the time and resources required for large-scale bioinformatics analyses, allowing for faster and more accurate results. This can lead to advancements in various fields such as drug discovery and genetic research.
4. Is Lancaster Enjin Scaling for RC compatible with all types of RC algorithms?
Yes, Lancaster Enjin Scaling for RC is designed to work with any RC algorithm, making it a versatile and adaptable solution for improving the performance of bioinformatics analyses.
5. How can I access Lancaster Enjin Scaling for RC for my research?
Lancaster Enjin Scaling for RC is currently available for academic and research use. Interested individuals or organizations can contact Lancaster University for more information on obtaining access to the technology.
