Lift Force Generated by a Wing
In summary, the wings generate lift force when the air above them travels 9.8 percent faster than the air below them.
bleedblue1234
109
A commercial airliner cruises at a speed of 284 meters per second. Each wing is 28.8 meters long and has an average width of 1.73 meters. The density of air at cruising altitude is 0.47 kilograms per cubic meter. How much lift force is generated by the wings if the air below the wings travels at the plane's cruising speed and the air above the wings travels 9.8 percent faster? Hint: Planes have two wings.
Bernoulli's?
No real clear idea where to start...
What is Bernoulli's equation?
p +1/2(rho)v^2 + (rho)gh = p + 1/2(rho)v^2 + (rho)gh
so the pressures should cancel since it atmospheric...
and so if the
air above: 311.832 m/s
air below: 284 m/s
1/2(.47)311.832 + I am not really sure what to do beyond this...
so somehow i should relate the force exerted by the air on wing above to the force exerted by the air on the wing below
so F/A = F/A?
im full of a lot of random thoughts
There's not a lot of pressure difference due to gravity on the top and the bottom of the wing, so we can leave out the rho*gh part.
p +1/2(rho)v^2 = constant
What happens to p when the the velocity, v is increased over the top of the wing?
I'm not completely sure about this, but i read something about NASA scientists deducing an equation for finding the force of lift on a wing:
Flift=1/2*density of air*(velocity of air in opposite direction)2*area
of wing*wing coeficcient
I barely think this is going to work, unless you know how to find out the wing coeficcient, which I don't know. I just read this on the net. Just trying to help.
BTW...you didn't get this equation from an engineering book, did you, 'cause if you did, I think you're supposed to have posted it in the engineering section, not in 'introductory physics!
This is an AP Physics B question... so it should be just involving Bournelli's... and i still can't quite get it...
so I have P + 1/2(rho)v^2 + (rho)gh = P + 1/2(rho)v^2 + (rho)gh
so I simplified to P + 1/2(rho)v^2 = P + 1/2(rho)v^2
so I know (rho),v,and I can get P because P=F/A and I know A and atmospheric pressure is at cruising altitude...
so then I just compare the two and the difference will be the force?
This is the flaw in your thinking. What comes out of Bernoulli's equation is the result that in order for the equality to be satisfied, the air pressures above and below the wings should be slightly different due to the different flow rates. That is why there *is* a lift force in the first place. So, obviously you should be getting the answer that p below the wings is slightly higher than p above them.
yes i figured that... so how can i calculate the pressure differential per each wing?
alright so i got it down to F/A = F/A + 3897.05 somethings...
Er...not really a question that makes any sense. The pressure below the wings has a certain value (period, no matter where exactly you are or what direction you look in). Same with the pressure above the wings. This pressure difference leads to a net force on the wings. The wing geometry comes into play because of the relationship between force and pressure. Pressure is the force per unit area. Does that help?
alright so i calculated my 1/2(rho)v^2 values...
then subtracted over..
so i got F/A = F/A + 3897.05 somethings...
and i can calculate the area under and above the wing (they will be equal) so
F = F/A + 3897.05 * A?
hrm still having trouble
I got it thank you...
Related to Lift Force Generated by a Wing
1. What is lift force generated by a wing?
Lift force is the upward force that is generated by a wing when it moves through the air. It is responsible for keeping the aircraft in the air and counteracting the force of gravity.
2. How is lift force created by a wing?
Lift force is created by the difference in air pressure on the upper and lower surfaces of the wing. The shape of the wing, known as an airfoil, is designed to create a pressure difference as air flows over it.
3. What factors affect the lift force of a wing?
The lift force of a wing is affected by several factors, including the shape and size of the wing, the speed and angle of attack of the aircraft, and the air density and viscosity.
4. Why is lift force important in aviation?
Lift force is crucial in aviation because it enables an aircraft to stay airborne and control its altitude and direction. Without lift, an aircraft would not be able to take off, maintain level flight, or perform maneuvers.
5. How can the lift force of a wing be increased?
The lift force of a wing can be increased by increasing the speed or angle of attack of the aircraft, or by changing the shape of the wing to create more lift. This can be achieved through the use of flaps, slats, or other aerodynamic devices.
  • Classical Physics
