How Is Torque Influenced by Magnetic Fields in a Rolling Cylinder?
In summary, to prevent the cylinder from rolling down the inclined plane, the minimum amount of current needed is given by I = (mgLsinθ)/(NΦB).
cliveroth
[SOLVED] magnetic fields and torque
so for this question, i have an inclined plane with a coil of wire wrapped longitudinally around a cylinder N turns. the plane of the coil is parallel to the inclined plane with a uniform magnetic field they want me to find the least amount of current necessary to prevent the cylinder from rolling down the plane.
im given mass of the cylinder, magnitude of the magnetic field, length of the L portion of the cylinder, & N number of turns.
I am not sure where to start, i have this equation, torque=Ntorque'=NiABsin(phi) where A equals area but I am only give the L part of the cylinder.
i need to have this done by tonight if anyone can help
feel free to lock this thread, i solved the problem
Ans: The torque caused by the magnetic field is equal to the force of gravity acting on the cylinder. The equation for torque from a magnetic field is NΦBAsinθ, where N is the number of turns, Φ is the flux, B is the magnetic field, A is the area of the coil and θ is the angle between the magnetic field and the normal to the coil.Therefore, we can solve for the current I required to prevent the cylinder from rolling down the plane as I = (mgLsinθ)/(NΦB).
Hello,
It seems like you have already solved the problem, but I can provide a response for future reference.
To start, we need to understand the relationship between magnetic fields and torque. Torque is a measure of the rotational force acting on an object. In this case, the torque is caused by the interaction between the magnetic field and the current in the coil.
The equation you mentioned, torque = N * torque' = NiABsin(phi), is correct. In this equation, N represents the number of turns in the coil, i is the current in the coil, A is the area of the coil, B is the magnitude of the magnetic field, and phi is the angle between the direction of the magnetic field and the plane of the coil.
Now, to find the minimum current necessary to prevent the cylinder from rolling down the plane, we need to set the torque equal to the torque caused by the gravitational force. This can be represented as follows:
N * torque' = Mgsin(theta) * L
where M is the mass of the cylinder, g is the acceleration due to gravity, and theta is the angle of inclination of the plane.
Solving for i, we get:
i = Mgsin(theta) * L / (NABsin(phi))
So, to prevent the cylinder from rolling down the plane, the minimum current required would be:
i = (mass of cylinder * acceleration due to gravity * sine of the angle of inclination * length of the L portion of the cylinder) / (number of turns * area of the coil * magnitude of the magnetic field * sine of the angle between the magnetic field and the plane of the coil)
I hope this helps. Let me know if you have any further questions. Good luck with your studies!
Related to How Is Torque Influenced by Magnetic Fields in a Rolling Cylinder?
1. What is a magnetic field?
A magnetic field is a region of space around a magnet or electric current where a magnetic force can be detected.
2. How are magnetic fields created?
Magnetic fields are created by electric currents and the movement of charged particles, such as electrons. They can also be created by permanent magnets.
3. What is torque in relation to magnetic fields?
Torque is the twisting force that a magnetic field applies to a magnetic object or a conductor carrying an electric current. It causes the object to rotate around its axis.
4. How do magnetic fields and torque affect electric motors?
Magnetic fields and torque play a crucial role in the functioning of electric motors. The interaction between the magnetic field and the electric current creates torque, which causes the motor to rotate and produce mechanical energy.
5. Can magnetic fields be shielded or controlled?
Yes, magnetic fields can be shielded or controlled using materials that are magnetically conductive or have high magnetic permeability. This is often done to protect sensitive electronic equipment or to manipulate magnetic fields for various purposes.
