Massless photon infinite speed?
In summary, a photon has zero mass but has relativistic mass because it has energy, so if you don't apply a force to it, it will move at the speed of light.
Saaam
massless photon...infinite speed?
ok here's the deal,
a photon is massless
its mass is 0
and f=ma
then why is the speed of light not infinite
Well, for one, what are you trying to connect with massless particles and F=ma?
well if m=0,
and if F=any value apart from 0 then acceleration must be infinite?
right?
and if F=0 then acceleration would also be 0?
therefore the speed of light must be either 0 or infinite
but this is not the case
and this is why i am confused...
Saaam said:
ok here's the deal,
its mass is 0
and f=ma
Two questions:
(1) What makes you think that F=ma applies relativistically? (It doesn't.)
(2) How are you exerting a force on the photon?
Another, IMO more general, way to formulate f=ma is f=dp/dt. A photon does not have mass, but it does have momentum.
F=ma isn't how the world works. It's a good approximation in certain cases. It has been superseded by more modern theories.
Saaam said:
ok here's the deal,
its mass is 0
and f=ma
I got what you must be thinking. A system does work to release a photon and since the mass is zero, it can accelerate the photon to infinite speed but 0*oo is not zero, it's indeterminate
{oo is infinity}
And BTW, the photon when released has mass
:confused:
The photon is massless, but it has the so-called relativistic mass, the m in the equation
[tex]E=mc^{2}[/tex]​
The photon must have relativistic mass because E=hf. It's this mass that form the moment p of the photon
Um, that m in the equation is the rest mass (please correct me if I'm wrong), which the photon doesn't have. You get the relativistic mass by considering the more fuller equation: E^2=(pc)^2 + (mc^2)^2=p^2c^2 + m^2c^4. The rest mass of the photon is just 0, it only has relativistic mass, so we set m=0, and we get E^2=p^2c^2 + 0 = p^2c^2.
E=[(p^2)(c^2)]^(1/2)=pc. Now, you could try to set pc = E = mc^2 to figure out what the 'mass' of the photon would be, but that's nonsensical for the following reason: to get this equation, we had to assume originally that m=0, and in our final result, pc=/=0 in general.
0 =/= pc = E = mc^2 = (0)c^2 = 0. Thus you would get the nonsensical result: 0=/=0. It's better to just say the photon has momentum.
E = hf = pc.
p = hf/c.
f = c/Lambda.
p = h/Lambda = Planck's constant/wavelength.
I believe relativistic mass enters the picture when you make the equation p = mv.
m=p/v. v=c. p=h/Lambda.
m=h/(lambda)c.
Can you provide a citation to a physics textbook or a research journal article that actually uses this "relativistic mass of the photon"?
In relativity, there are (at least) two different concepts of mass. To put it simply
  • "rest mass" which excludes kinetic energy
  • "relativistic mass" which includes kinetic energy
There are two schools of thought.
The vast majority of professional physicists call rest mass "mass" and don't talk about relativistic mass at all. They say photons are massless.
Some others call relativistic mass "mass" and rest mass "rest mass". They say photons do have mass, but no rest mass.
Hardly anyone routinely uses the phrase "relativistic mass"; it arises only in discussions like this comparing both definitions.
This is a great cause of confusion and it's a pity there isn't universal agreement over the terminology.
Unfortunately usage is not quite so black-and-white as some people think. Relativistic mass is used in the undergraduate-level textbook Relativity: Special, General and Cosmological (2nd ed 2006) written by the professional physicist Wolfgang Rindler after whom Rindler coordinates are named. Sorry.
By the way, I personally support the standard convention that most other physicists use, but we can't just pretend the other convention doesn't exist. Both views are technically valid, but use mutually incompatible terminology.
Sorry, I should have written [tex]E=m_{rel}c^2[/tex],
where
[tex]m_{rel}= \frac{m}{\sqrt{1-v^2/c^2}}[/tex]
I could be wrong, but this may be converted to [tex]E^{2}=(pc)^{2}+(mc^{2})^{2}[/tex]
Doc Al said:
Two questions:
this is my point
if no force is exerted how can it possibly move?
Saaam said:
this is my point
Do you think something that emits light never loses energy?
Better don't talk about the 'force' on the photon because you don't know how long it acts.
Saaam said:
this is my point
Since you skipped my earlier questions, here's another: Do you think a force is required for something to be moving?
Note that photons do not exist at any speed other than c. When created, they are already moving at full speed. It's not like they are sitting around at rest, then accelerated.
A force is required to throw out some mass of the body as a photon
It's certainly true that a body emitting a photon will experience an impulse (change in momentum) equal and opposite to the momentum of the photon. But that's not quite the same thing as exerting a force on a photon to accelerate it.
Why don't both mean the same?
Think how confusing it is from the photons point of view, it pops into existence and because it must travel at the speed of light it doesn’t experience any time and then it transfers its energy and pops out of existence in a different place. Another thing that intrigues me (and please correct me if I am wrong) is that a photon has no upper limit on the amount of relativistic mass it can carry. So conceivably the energy of the entire universe could have been contained in a single photon.
There is nothing called the photon's point of view, all energy it has is due to its kinetic energy so its velocity is definitely not indeterminate. A force is required to accelerate the photon or it wouldn't have energy.
A photon with all the mass of the universe is way out of the electromagnetic spectrum and I'm not sure it exists.
Photons aren't accelerated since they only exist at speed c.
Or you say due to uncertainity, you cannot accurately measure its energy at all times it is in contact with the system
I think the both of us are right in our own ways. Photons exist only at c, but the photon must be "formed" and in this process it must be "accelerated" with a force as long as it is in contact with the system but it is your inability to measure the correct value of the momentum when it being formed you define it to exist only at c, you say it is not a photon.
That the impulse on the body is not due to the force on the photon sounds stupid.
Why is there no discussion of electromagnetic waves in this thread, and the limits that permittivity and permeability place on the speed of light ?
Photons are only the quanta of such waves.
I have an idea which is probably going to make people cringe. Light is infinite. <C is the point at which energy transforms to mass, and mass converts to energy at v=c (Einstein mass gain). That point takes x amount of time to detect in a mass state, which is the same at any velocity. Light travels 0 distance, because at C, L*(1-((c^2)/(V^2)))=0. It's not really about the velocity of a photon, it's about the transfer of energy into mass. I don't see the photon as being created, rather destroyed in the conversion to a mass state at <C. How long it takes to destroy a potential photon depends on the separation of energy between the emission and destruction of the wave. One thing has been pretty well proven so far, in order to detect a photon, you have to destroy it.
It does. Please read the forum rules about overly speculative postings.
Related to Massless photon infinite speed?
1. What is a massless photon?
A massless photon is a particle of light that has no rest mass. It travels at the speed of light and has no physical size or shape.
2. What does it mean for a photon to have infinite speed?
Infinite speed means that the photon is able to travel at the maximum possible speed in the universe, which is the speed of light. This means that it can cover vast distances in a very short amount of time.
3. How is it possible for a particle to have no mass and infinite speed?
According to Einstein's theory of relativity, mass and energy are interchangeable. Photons have no rest mass because all of their energy is in the form of electromagnetic radiation. This allows them to travel at the speed of light.
4. What are some real-life applications of massless photons traveling at infinite speed?
Massless photons traveling at infinite speed are responsible for all forms of electromagnetic radiation, including visible light, radio waves, and X-rays. They are also used in a variety of technologies such as communication systems, medical imaging, and solar panels.
5. Is it possible for a photon to have a speed other than the speed of light?
No, according to the theory of relativity, the speed of light is the maximum possible speed in the universe. Therefore, a photon can only travel at the speed of light and cannot have a different speed.
  • Classical Physics
