Does Friction Affect Momentum in a Spring-Driven Spacecraft?
In summary: IF the small mass reached the opposite wall of the box and was captured by a similar spring-and latch assembly so force curve equal and opposite to the original spring-release event was applied to that opposite wall, and all the kinetic energy and momentum of the small mass was reconverted to elastic potential energy, then of course the small...The small mass would not reach the opposite wall. There is a chance that the small mass could escape from the box, but it is unlikely.
Leyzorek
Spacecraft, with vacuum inside, in free-fall, contains a small mass captured against a fully-compressed compression spring against one wall of the craft. Release the spring and mass. Mass is accelerated by recovering spring (elastic potential energy turning to kinetic), spacecraft is, of course, accelerated in opposite direction. Spring once fully extended also lifts off behind mass at its average velocity relative to the spacecraft , and while traveling oscillates in length about its unstressed length.
The kinetic energies of spring and mass on the one hand and the spacecraft on the other, must be equal and opposite.
Mass and spring eventually hit the opposite wall of the spacecraft . IF the collision is fully elastic, (and assuming axis of motion passes through center of gravity of system, nothing starts to spin) spacecraft should stop and accelerate in opposite direction while spring and mass return to their original position, repeat cycle..Correct so far?
What IF the collision of spring and mass with opposite wall is substantially inelastic, for instance into a sand-bag which converts significant portion of kinetic energy into frictional heat? Does the whole system end up with kinetic energy in direction opposite to the original spring-driven travel of the small mass?
None
Described above
No. Momentum is always conserved.
If the spacecraft was initially at rest it will end up at rest after the inelastic collision. The energy that was originally in the spring ends up as heat in the sand bag/mass.
If the system boundary only includes the KE of the spacecraft and mass (and doesn't include heat in the sand bag) then energy is not conserved
A description is not a solution unless there's math to back it up. The lack of relevant equations is worrisome. What conservation laws apply? Which one applies no matter if the collision is elastic or inelastic?
Kinetic energy is not a vector, it does not have a direction.
Of course energy is conserved, and if the collisions at each end of the craft are equally and perfectly elastic, then the center of mass will be stationary and the craft's hull will oscillate opposite to the sprung mass inside. But if some of that energy is converted to heat at one end how can that heat (RANDOM MOTION) reconvert to kinetic energy? IE , Orodruin, does the whole assembly (CG) end up in motion?
Thanks!
What makes you think that it does reconvert to kinetic energy?
I think it does not. So, does that mean that the CG of the whole system ends up in motion?
Is momentum conserved?
[Also, review @Orodruin's post #4 above]
If some of the momentum (kinetic energy) that would normally cancel the spacecraft s momentum in the other direction was converted to heat (with the sandbag) it would seem that energy would be conserved even though momentum would not be conserved.
that was the original question, is momentum conserved?
Kinetic energy and momentum are two different things. Please review post #2 by @CWatters.
I guess unfamiliarity with terms is preventing me from stating my question clearly. Let me try again.
Begin, box ( spacecraft ) stationary, in free fall. Inside box, against one wall is a precompressed spring with a small mass against the end of the spring opposite the wall.
Release spring. Its elastic potential energy turns to kinetic energy (and momentum), as it accelerates the box and the small mass in opposite directions.
IF the small mass reached the opposite wall of the box and was captured by a similar spring-and latch assembly so force curve equal and opposite to the original spring-release event was applied to that opposite wall, and all the kinetic energy and momentum of the small mass was reconverted to elastic potential energy, then of course the small mass and box would decelerate together (though in opposite directions) and all parts would return to their original resting state.
BUT if instead of being caught by a lossless perfectly elastic spring-and-latch, the small mass comes to rest in a sandbag which converts some of the energy to heat, then energy is not lost, but it seems that momentum is, and the box-and-small-mass would continue moving in the direction in which the box alone was originally accelerated by the energy released by the spring.
This does not FEEL right to me, I am eager to be told I am wrong but need to know why/where. The heat energy in the sand has to come out of the kinetic energy of the small mass, and will ( it seems) be unavailable to decelerate the box.
That's where your intuition is leading you astray. KE and momentum are separate things. In an isolated system momentum is always conserved independently of energy (KE, PE, heat,...).
1. What is momentum in spacecraft?
Momentum in spacecraft is a measure of the amount of motion that a spacecraft has. It is a product of the spacecraft's mass and velocity, and is described by the equation p = mv, where p is momentum, m is mass, and v is velocity.
2. Why is momentum important in spacecraft?
Momentum is important in spacecraft because it is what allows the spacecraft to move and change its direction. It is also crucial for spacecraft navigation and control, as well as for achieving orbit and making course corrections.
3. How is momentum conserved in spacecraft?
According to Newton's Third Law of Motion, for every action, there is an equal and opposite reaction. This means that the momentum of a spacecraft is conserved, as any change in momentum in one direction will be matched by an equal change in the opposite direction.
4. Can momentum be transferred between spacecraft?
Yes, momentum can be transferred between spacecraft through various methods such as docking and undocking, or by ejecting or absorbing mass. This transfer of momentum is essential for spacecraft maneuvers and can also be used to adjust the orbit of a spacecraft.
5. How is momentum affected by gravity in spacecraft?
Gravity plays a significant role in determining the momentum of a spacecraft. As the spacecraft orbits a larger body, such as a planet, its momentum is influenced by the gravitational force of that body. This can be used to the spacecraft's advantage, such as using gravitational slingshots to increase its velocity.
