Momentum, man running on flatbed
In summary, a man weighing 915 N stands on a flatcar weighing 2640 N as it rolls at 16.0 m/s in the positive x direction. The man then runs in the negative x direction at 53 m/s relative to the flatcar. Using conservation of momentum, the resulting increase in speed of the flatcar is 18.37 m/s. This takes into account the motion of the center of mass of the system and the ratio of masses between the man and flatcar. However, it is possible that the online homework system may require the answer to be rounded to only two significant digits, resulting in an answer of 18.37 m/s.
synchronous
Man who weighs 915 N stands on a flatcar that weighs 2640 N as it rolls at 16.0 m/s in positive x direction. No friction. Man runs in negative x direction at 53 m/s relative to the flatcar. What is the resulting increase in speed of flatcar?
Velocity(man, flatcar) = Velocity(man, ground) + velocity(ground, flatcar)
F(g) = ma(g)
m(1i)v(1i) + m(2i)v(2i) = m(1f)v(1f) + m(2f)v(2f)
I divided weight by 9.81 to arrive at mass(man) = 93.3 kg and mass(flatcar) = 269 kg. I then found the velocity of the man relative to the ground to be -37 m/s. Using conservation of momentum, I found that the final velocity of the flatbed to be 34.4 m/s. This led to an increase of 18.4 m/s for the flatbed.
93.3(16) + 269(16) = 93.3(-37) + 269v(flatbed, final)
More simply can't you just consider the motion of the center of mass of the system?
Won't it remain in motion undisturbed by an external force, so won't the ratio of the masses need to be inversely proportional to their velocities to maintain the constraint on the center of mass?
915/2640 = v/53 or v = 18.4 as you found.
Since he is running counter to the 16 m/s, the car must be moving faster by the 18.4.
Submitted that solution online, but feedback stated that I was incorrect. Huh?
A man (weighing 915 N) stands on a long railroad flatcar (weighing 2640 N) as it rolls at 16.0 m/s in the positive direction of an x axis, with negligible friction. Then the man runs along the flatcar in the negative x direction at 53.00 m/s relative to the flatcar. What is the resulting increase in the speed of the flatcar?
Here's a cut-n-paste of the problem from the website where it's posted.
Does your program want more significant digits perhaps?
I did the calculations without any rounding and came up with an answer of 18.369 or something like that. I have until 11pm tonight to figure this out. I can't see where I went wrong...
I get the same thing, so it seems like you did the problem correctly. Maybe they want only 2 significant digits, because of the 53 m/s? Did you make sure to submit the answer with the proper units? Or in the proper units?
I tend to think these online homework things are pretty stupid, because they're so inflexible - you not only have to come up with the right answer, but guess the "right" way to type it into get credit.
As soon as he stops of course it goes back to 16 m/s. And it has to be a pretty long car at that speed before he must stop.
His speed is given with 2 place after the decimal, so maybe they want 18.37 m/s as the increase.
Edit: As diazona has noted as well.
Related to Momentum, man running on flatbed
1. What is momentum?
Momentum is a measurement of an object's motion, taking into account its mass and velocity. It is often described as the "quantity of motion" that an object possesses.
2. How is momentum calculated?
Momentum is calculated by multiplying an object's mass by its velocity. The equation for momentum is: momentum = mass x velocity.
3. How does momentum relate to a man running on a flatbed?
As the man runs on the flatbed, he gains momentum due to his mass and velocity. The heavier the man and the faster he runs, the greater his momentum will be.
4. What happens to the man's momentum if he stops running on the flatbed?
If the man stops running on the flatbed, his momentum will decrease as he slows down. The momentum will eventually reach zero when he comes to a complete stop.
5. Why is momentum important in scientific studies?
Momentum is important in scientific studies because it helps us understand and predict the behavior of moving objects. It is also a fundamental concept in physics and is used in various equations and laws, such as Newton's Second Law of Motion.
