- #36
apeiron
- 2
Q_Goest said:I’m not familiar with “holonomic” so I did a search:
It sounds like Pattee wants simply wants these macromolecules and genetics to have a stronger causal role in evolution but I'm not sure exactly what he's getting at. Perhaps you could start a new thread regarding Pattee and his contributions to philosophy and science.
Given that Pattee is an excellent cite for the systems view, this is certainly the right place to mention him .
What he is talking about here is the symbol grounding issue - how non-holonomic constraints can actually arise in the natural world. Genetic information has to make itself separate from what it controls to be able to stand as a level of top-down control.
Sure, Baranger's paper is pretty basic, but it clearly makes the point that chaotic systems are deterministic given precise initial conditions, which is relevant to the OP.
That was hardly the thrust of the paper. And the more correct statement is that chaotic systems (such as the weather) can be modelled using the mathematical tools of deterministic chaos. This is different from the claim that the weather, or any other system is deterministically chaotic in the ontic sense.
So sure, the models behave a certain way - unfold mechanistically from their initial conditions. And it certainly resembles the observables of real world systems like the weather. But we also know that the models depend on unrealistic assumptions (such as a real world ability to measure initial conditions with complete accuracy).
From a philosophical view, you just can't jump from "looks like" to "is". Especially when you know there are ways that "it isn't".
I think it’s important also to separate out chaotic systems that are classical (and separable) in a functional sense, such as Benard cells, from systems that are functionally dependant on quantum scale interactions. Our present day paradigm for neuron interactions is that they are dependent on quantum scale interactions, so it seems to me one needs to address the issue of how one is to model these “non-holomonic” properties (classical or quantum mechanical influences) and whether or not such a separation should make any difference.
Pardon me? Did you just suggest that a QM basis to neural function was mainstream?
This is a good example of what confuses me about everything you say about this "systems approach". Are you suggesting these "top-down constraints" are somehow influencing and subordinating local causation? That is, are you suggesting that causes found on the local level (such as individual neuron interactions) are somehow being influenced by the top down constraints such that the neurons are influenced not only by local interactions, but also by some kind of overall, global configuration?
What I've said is that global constraints act top-down to restrict local degrees of freedom. So that in a strong sense does create what is there are the local scale. Of course the logic is interactive. It is a systems approach. So the now focused degrees of freedom that remain must in turn construct the global scale (that is making them).
This is how brains work. A neuron has many degrees of freedom. A particular neuron (in a baby's brain, or other unconstrained state) will fire to just about anything. But when a global state of attention prevails, the firing of that neuron becomes highly constrained. It becomes vigorous only in response to much more specific inputs. This is a very basic fact of electrophysiology studies.
So it is not just a theory, it is an observed fact. And yes, this is not the way machines work in general.
After rereading his paper, I’d say that he does in fact try to separate mental states (phenomenal states) from the underlying physical states as you say, but that mental states are epiphenomenal isn’t an unusual position for computationalists. Frank Jackson for example (Epiphenomenal Qualia) is a much cited paper that contends exactly that. So I’d say Farkus is in line with many philosophers on this account. He's suggesting mental states ARE physical states, and it is the mental properties that are "causally irrelevant" and an epiphenomenon (using his words) which I’d say is not unusual in the philosophical community.
I'm not holding up the Farkus paper as a shining example of the systems view. As I made plain, it was just what I happened to be reading that day and my remark was here is another reinventing the wheel.
But I think you are also reading your own beliefs into the words here.
Not that there aren’t logical problems with that approach. He states for example:
That says to me, he accepts that neurons only interact locally with others but we can also examine interactions at higher levels, those that are defined by large groups of neurons.
I don't see the issue. This is the standard view of hierarchy theory. Except you introduced the word only here to suggest Farkus meant that there are not also the local~global interactions that make the brain a system.
There are some areas in his paper I’m not too sure about. Take for example:
If he’s suggesting that this “higher level” is not determined by the interactions of the lower level (their interactions) in a deterministic way based only on the local interactions of neurons, then that sounds like strong downward causation which is clearly false. Certainly, there are people who would contend that something like that would be required for “free will” or any theory of mental causation. But I’m not sure that’s really what he wants.
What he says is that you have two things going on. The higher level has a long-run memory which causes what we might call its persistent state. Then it is also responding to the input coming from below, so its state is also "caused" by that.
If you dig out Stephen Grossberg's neural net papers, or Friston's more recent Bayseian brain papers, you will get a much more elegant view. Yet one with the same essential logic.
In another questionable section he states:
In the part emphasized, I’d say he’s trying to suggest that a person is somehow “immediately” and “simultaneously” affected by a “global state” on entering this classroom which I picture as being a zone of influence of some sort per Farkus. Were the same person to enter the same room and was blind and deaf, would these same “global states” immediately and simultaneously also affect that person? Sounds like Farkus wants his readers to believe that also, but that sounds too much like magic to me.
Surely he is just using an analogy and not suggesting that psi is involved :rofl:. Why would his explicit claim that a person "senses" the atmosphere be read instead as a claim that a person who could not sense (being blind and deaf) would still sense?
All he is saying is that there is an ambient emotional state in the classroom - a generally shared state averaged across a connected set of people. Any newcomer then will respond to this globally constraining atmosphere.
I think this is a good lead into strong emergence and strong downward causation which, in one way or another, is necessary for mental causation and free will. The question really is, can the higher physical levels somehow subordinate the local interactions of neurons? And if so, how?
Excellent. But there are so many thousands of papers on the neuroscience of top-down attentional effects on neural receptive fields that it is hard to know where to start.
Here is a pop account with some useful illustrations.
http://www.sciencedaily.com/releases/2009/03/090325132326.htm
Here is a rather general review.
http://pbs.jhu.edu/bin/q/f/Yantis-CDPS-2008.pdf
