How Does Newton's Law of Cooling Relate to Temperature Differences in Iced Tea?
In summary: If we take the derivative of the temperature of the tea, it will be equal to -kCe-kt. This value is proportional to the difference between the temperature of the tea and the temperature of the room, since it contains the constant k. In summary, the rate of change of f(t) is proportional to the difference between the temperature of the tea and the temperature of the room at every time t.
phil ess
70
If you remove a glass of iced tea from the refrigerator, and leave it sitting on the table
in a room with temperature 25 C, then Newton’s Law of Temperature Change gives
the temperature of the tea after t minutes as
f(t) = 25 − Ce−kt
where C and k are constants. Show that the rate of change of f(t) is proportional to
the difference between the temperature of the tea, and that of the room, at every time t.
That one
OK I know the rate of change is the derivative. So f'(t) = Cke-kt right? But how am I supposed to show that f'(t) is proportional to the difference mathematically?
You need to show that this ratio is constant:
f'(t) / [(Temp of tea at time t) - (Temp of room)] = a constant
You know what the temperature of the tea at any time is, right?
You are given the room temperature.
For the constant, don't use something other than C or k, since you're already using them.
f(t) = 25 − Ce−kt
That one
The temperature of the tea is 25- Ce-kt and the temperature of the room is 25. What IS the difference in temperatures?
Related to How Does Newton's Law of Cooling Relate to Temperature Differences in Iced Tea?
1. What is Newton's law of cooling?
Newton's law of cooling is a physical law that describes the rate at which an object cools down when it is placed in a surrounding environment with a different temperature. This law states that the rate of cooling is proportional to the temperature difference between the object and its surroundings.
2. Who is credited with discovering Newton's law of cooling?
Sir Isaac Newton is credited with discovering Newton's law of cooling in the 17th century. However, it was later refined by mathematician and physicist Joseph Fourier in the 18th century.
3. What factors can affect the rate of cooling according to Newton's law of cooling?
The rate of cooling can be affected by various factors such as the temperature difference between the object and its surroundings, the surface area of the object, the type of material the object is made of, and the presence of any insulating materials.
4. How is Newton's law of cooling used in everyday life?
Newton's law of cooling has various applications in everyday life, such as in the cooling of food and beverages, the regulation of room temperature using air conditioning, and the cooling of electronic devices.
5. Is Newton's law of cooling only applicable to cooling processes?
No, Newton's law of cooling can also be applied to heating processes. In this case, the law states that the rate of heating is proportional to the temperature difference between the object and its surroundings.
14K
10K
  • Thermodynamics
18K
