Nonlinear static polarization and impurity spectrum
In summary, the conversation discusses the use of a nonlinear polarization theory for calculating the energy spectrum of impurities, excitons, and other effects in crystals. This is due to the large field created by impurity atoms, which requires taking into account the quadratic term in the polarization vector. The conversation also mentions a colleague who included nonlinear terms in their calculations on solvated electrons and references to their work. Additionally, a short account of more complex continuum models for solvated electrons is provided.
reterty
29
As is known, when calculating localized states in a crystal
it is roughly considered that the point charge is “immersed” on medium with
static dielectric constant ε.
However, a simple estimate, for example, shows that an impurity atom
with charge modulo equal to the electron charge creates at distances of the order of
lattice constant field with a strength of about 10 ^ 7 V / m.
This is a very large field and, in my opinion, one needs to use a nonlinear
polarization theory for calculating the energy spectrum of impurities, excitons, etc.
That is, to take into account the quadratic in the field term in the decomposition of the polarization vector
by degrees of electric field strength.
Yes, a colleague of mine did calculations on solvated electrons and he also included nonlinear terms in the polarisation. Another effect is spatial dispersion.
Dear DrDu, сould you provide me the references to his work on solvated electrons. Thank you in advance for your help.
1. What is nonlinear static polarization?
Nonlinear static polarization refers to the phenomenon where the electric polarization of a material is not directly proportional to the applied electric field. In other words, the polarization response of the material is dependent on the strength of the electric field, making it a nonlinear process.
2. How is the nonlinear static polarization measured?
The nonlinear static polarization can be measured through techniques such as electric field-induced second harmonic generation (EFISH) or electric field-induced sum frequency generation (EFISFG). These techniques involve applying an electric field to the material and measuring the resulting nonlinear optical response.
3. What is the impurity spectrum in relation to nonlinear static polarization?
The impurity spectrum refers to the energy levels of impurity atoms or ions incorporated into a material. These impurities can have a significant impact on the nonlinear static polarization of the material, as they can introduce additional energy states and alter the material's response to an electric field.
4. How does impurity concentration affect the nonlinear static polarization?
The concentration of impurities within a material can have a significant influence on its nonlinear static polarization. Higher impurity concentrations can lead to a larger number of energy states and increased interactions between the impurities and the material, resulting in a stronger nonlinear response.
5. What are the applications of studying nonlinear static polarization and impurity spectrum?
The study of nonlinear static polarization and impurity spectrum has various applications, including in the development of advanced materials for optoelectronics, telecommunications, and data storage. It can also aid in understanding the fundamental properties of materials and their behavior under different electric fields.
  • Beyond the Standard Models
