Normal force - object sliding with velocity
In summary, the problem involves a small rock being released from rest at the top edge of a large, hemispherical bowl. The rock slides down to the bottom of the bowl, and the absolute value of the work done by friction on the rock is 0.25 J. The question asks for the normal force on the rock as it reaches the bottom of the bowl. To solve this, the speed of the rock at the bottom is found and a free body diagram is drawn. The sum of the vertical forces is equal to the mass of the rock times the acceleration in the vertical direction. Since the rock is moving in a circle, the acceleration is found using a = v^2/R. Using this expression, the normal force can
mybrohshi5
365
A small rock with mass 0.22 kg is released from rest at point A, which is at the top edge of a large, hemispherical bowl with radius R = 0.60 m (the figure ). Assume that the size of the rock is small compared to R, so that the rock can be treated as a particle, and assume that the rock slides rather than rolls. The absolute value of the work done by friction on the rock, when it moves from point A to point B at the bottom of the bowl, is 0.25 J.
http://session.masteringphysics.com/problemAsset/1000053271/8/YF-07-25.jpg
Just as the rock reaches point B, what is the normal force on it due to the bottom of the bowl?
I know that its not just the mass times gravity like the normal force usually is because it has a velocity of 3.08 m/s.
I am just not sure how to use this and find the normal force :(
Any suggestions?
Thank you
Can you find the speed of the rock when it reaches bottom?
Once you have that, draw a free body diagram.
I found the speed at the bottom. it is 3.08 m/s
I drew a FBD when the rock is at the bottom of the bowl.
I have the normal force perpendicular to the surface.
I have the force of gravity perp. to the surface but in the downward direction
I have velocity to the right
i have the force of friction to the left
Does that sound right?
not sure what to do from here though
That sounds right. Now answer these two questions:
What is the sum of all the vertical forces?
What is the acceleration in the vertical direction?
OK i have two thoughts on those two questions. I am over thinking this and confusing myself :(
the sum of the vertical forces should equal zero.
OR
the sum of the vertical forces should equal mass times accelerationthe acceleration in the vertical direction is just the acceleration due to gravity
OR
the acceleration in the vertical direction is just zero
OR
OR
Instantaneously, the mass is moving in a circle at the bottom of the bowl. This means that its velocity is changing direction, therefore it is accelerating.
Therefore the sum of the vertical forces is mass times acceleration. Find an expression for the sum of the vertical forces and an expression for the acceleration (don't forget that the mass is going around in a circle) and set them equal.
Sorry, I have to sign off now.
So for my equation i have...
Normal force - force of gravity = m(a)
Can anyone help me from here? i am really lost :(
What is the acceleration a for an object that is going around in a circle? Put that in your expression and find the normal force.
acceleration for an object going around in a circle is a=(4pi^2R)/T^2 correct?
so then to find time would i use v = d/t ?
Just a quick question on top of this.
Since i am finding the sum of the vertical forces wouldn't I use the acceleration in the vertical direction?
And can you tell me how you knew the object was "Instantaneously, the mass is moving in a circle at the bottom of the bowl"?
Thanks for the help
Strictly speaking your expression for the acceleration is correct, but I would use a = v2/R because v is already known.
This expression is valid only when the acceleration is zero. Not the case here.
That is what you should use.
Look at the picture you posted. The mass is in a bowl that looks like the inside of a spherical shell cut in half. At any point along its path, the mass is going around a circle, the center of which is the center of the shell.
Thanks for the help
You are welcome.
Related to Normal force - object sliding with velocity
What is normal force?
The normal force is the force exerted by a surface on an object in contact with it, perpendicular to the surface. It is a reaction force that balances out the weight of the object, keeping it in equilibrium.
What happens to the normal force when an object is sliding with velocity?
When an object is sliding with velocity, the normal force decreases. This is because the frictional force between the object and the surface reduces the pressure exerted on the surface, resulting in a decrease in the normal force.
How does the normal force affect the motion of an object?
The normal force does not directly affect the motion of an object. However, it is an important factor in determining the net force acting on the object, which can affect its motion. For example, if the normal force is greater than the force of gravity, the object will accelerate upwards.
Can the normal force be greater than the weight of an object?
Yes, the normal force can be greater than the weight of an object. This can occur when an object is accelerating upwards, causing the normal force to be greater than the force of gravity. It can also occur in situations where there is an external force pushing down on the object, increasing the normal force.
Can the normal force ever be zero?
Yes, the normal force can be zero. This occurs when there is no contact between an object and a surface, such as an object in free fall. It can also occur when an object is on a frictionless surface, where the normal force is not needed to balance out the weight of the object.
