How Do You Decompose a Complex Function into Real and Imaginary Parts?
In summary, the conversation discusses a question about complex analysis and finding the real and imaginary components of a complex function. The speaker is confused about how to break down a complex function into its real and imaginary parts and how to determine if the function is holomorphic, exact, or harmonic. They mention using a formula like ez=excos(y)+iexsin(y) to find the components, but are unsure how this formula was derived. The conversation also touches on parameterization and its effect on solving integrals and proving a function is holomorphic. Finally, they mention that they sometimes struggle to understand why certain functions are not holomorphic, such as the absolute value of z or the argument of z.
fleazo
81
One last simple question about complex analysis...
Hi, sorry again for having made so many threads. I have one remaining question about complex analysis that I keep get confused on.
Say that I have some complex function h(z). Sometimes I am really confused how to break that down into h(z) = u(x,y) + iv(x,y)
So for example say I want to take the integral ∫z2dz from 0 --> 1+i.
How do I know the u(x,y) and v(x,y) real functions that h(z) it is made up of? I mean... what if I want to see if the function is holomorphic? Or exact? Or harmonic? Or anything like that. I need the u and v components. For some functions, I just know it by a formula (like ez = excos(y)+iexsin(y) but I am really at a loss when I am just handed any arbitrary function. how do I find it? In fact, I'm not even sure how the formula for the complex exponential function was found. Was it just by converting to polar coordinates? I'm very confused on this point
Simply replace z by x+iy in h(z).
I guess what I mean is I need to find the actual functions of real variables that make up h(z).
For example ez like I mentioned. I can show that ez=u(x,y) + iv(x,y) where u(x,y)=excos(y) and v(x,y) = exsin(y). So then I can show ez is analytic, etc.
I'm just confused sometimes how to find thsi representation. I know about parameterizing but sometimes I don't entirely understand how it works. Like say I want to take ∫z2dz across the straight line from 0 to 1+i. Well I know I could paraterize that "curve" to be z(t)=t+it and then I can solve the integral. But sometimes I have a hard time understanding why the parameterization doesn't effect the integral. I mean... if I just had z2 by itself and the question was "is z2 holomorphic?" Then could I use that same parameterization and solve the Cauchy Reimann equations and get the answer? Is that valid?
Don't know whether it is allways possible for a holomorphic function to get an analytic expression for u and v? In case of z2 it is evident.
If you use a specific parametrisation to solve the Cauchy Reimann equations, then you do not prove that a function is holomorphic on the entire domain.
All polynomial functions in z with complex coefficients are holomorphic on C, and so are sine, cosine and the exponential function. (The trigonometric functions are in fact closely related to and can be defined via the exponential function using Euler's formula). The principal branch of the complex logarithm function is holomorphic on the set C \ {z ∈ R : z ≤ 0}. The square root function can be defined as e1/2.log(z) and is therefore holomorphic wherever the logarithm log(z) is. The function 1/z is holomorphic on {z : z ≠ 0}.
As a consequence of the Cauchy–Riemann equations, a real-valued holomorphic function must be constant. Therefore, the absolute value of z, the argument of z, the real part of z and the imaginary part of z are not holomorphic. Another typical example of a continuous function which is not holomorphic is complex conjugation.
Well, if you really want to find the real and imaginary parts of z2, just write z=x+iy, and multiply out: (x+iy)2 = x2 + 2xiy + y2 = (x2 + y2) + i(2xy), so u(x, y) = x2 + y2 and v(x, y) = 2xy
That said, you're getting way too caught up in the Cauchy-Riemann equations. For most functions, you want to work with z directly, rather than splitting it up into the real and imaginary parts. So the proof that z^2 is holomorphic becomes very simple:
[tex]\begin{align*} \frac{\mathrm{d}}{\mathrm{d}z}z^2 & = \lim_{w \rightarrow 0} \frac{(z+w)^2 - z^2}{w} \\ & = \lim_{w \rightarrow 0} \frac{z^2 + 2zw + w^2 - z^2}{w} \\ & = \lim_{w \rightarrow 0} \frac{2zw + w^2}{w} \\ & = \lim_{w \rightarrow 0} 2z + w \\ & = 2z \end{align*}[/tex]
Which, you will note, is exactly the same proof that x^2 is differentiable in the real case. All of the rational functions can be shown to be holomorphic in exactly the same way.
Well of course you know ex+iy = ex eiy, so the only difficulty is in showing that eiy = cos y + i sin y. And the way you do that is you just put z=iy into the Taylor series for ez and separate out the real and imaginary parts, and note that the real part is the Taylor series for cos y and the imaginary part is the Taylor series for sin y. A derivation can be found on the Wikipedia here: http://en.wikipedia.org/wiki/Euler's_formula#Using_power_series
First of all, it's affect. Now, the simplest reason the parameterization doesn't affect the integral is because z2 admits a complex antiderivative (namely z3/3), and the fundamental theorem of calculus holds. More generally, it can be shown that the parameterization of an integral doesn't affect the integral for any homomorphic function on a simply connected domain. This is basically a consequence of Cauchy's integral theorem -- if the parameterization did matter, then integrating along one path and then backwards across the other would yield a nonzero integral along a closed curve.
hi, i just wanted to thank you all for the responses and taking the time to write them. it has helped me very much
1. What is complex analysis?
Complex analysis is a branch of mathematics that deals with the study of complex numbers, which are numbers that can be expressed in the form a + bi, where a and b are real numbers and i is the imaginary unit (√-1). It involves the study of functions of complex variables and their properties.
2. Why is complex analysis important?
Complex analysis has numerous applications in fields such as physics, engineering, economics, and computer science. It provides powerful tools for solving problems that involve complex variables, and it also helps in understanding the behavior of real-life systems that can be modeled using complex numbers.
3. What are some key concepts in complex analysis?
Some key concepts in complex analysis include analytic functions, contour integration, Cauchy's theorem, and the Cauchy-Riemann equations. Other important topics include Laurent series, residues, and conformal mapping.
4. How is complex analysis different from real analysis?
Complex analysis deals with functions of complex variables, while real analysis deals with functions of real variables. Complex analysis also involves the study of properties specific to complex numbers, such as analyticity and holomorphicity.
5. What are some practical applications of complex analysis?
Complex analysis has many practical applications, such as in electrical engineering for analyzing AC circuits, in fluid dynamics for studying flow around objects, and in signal processing for filtering and modulating signals. It is also used in image processing, quantum mechanics, and many other fields.
