Open Entry Windsock Velocities
  • Thread starter Bob Shapiro
In summary, a Venturi tube with an open entry will act the same as one with a closed entry with a known pressure/velocity. The velocity at the entry point of a windsock in a 10 mph breeze will be 10 mph, and the velocity at the exit will be 5 mph. To calculate the exit velocity, you can use Bernoulli's equation and the ratio of the entry and exit diameters. A non-flexible tube may give slightly better results for creating a faster stream of air.
Bob Shapiro
Will a Venturi tube with the entry open to a moving fluid act the same as one that has a closed entry with a known pressure/velocity?
If I have a windsock in a 10 mph breeze, is the velocity inside the entry point (big diameter) 10 mph? Will the wind velocity at the small end (the exit) be the same, less, or greater than at the big end?
Let's put some numbers to it:
*Entry wind = 10 mph
*Entry diameter = 20 inches
*Exit diameter = 10 inches
*Windsock length = 50 inches
Where I'm going with this is that I have a couple of ideas which need a good stream of air (faster than a typical breeze) and I'd like to use a funnel setup rather than a fan to create it.
If it's possible, how can I calculate the output given the input wind speed and the windsock dimensions? (Would a non-flexible tube give better results?)
Thanks!
Yes, a Venturi tube with an open entry will act the same as one with a closed entry with a known pressure/velocity. The velocity at the entry point of your windsock in a 10 mph breeze will be 10 mph, and the velocity at the exit (small end) will be greater than at the entry point due to the Venturi effect. To calculate the exit velocity given the input wind speed and windsock dimensions, you can use Bernoulli's equation, which states that the sum of the pressure, kinetic energy, and potential energy in a system remains constant. The equation can be rearranged to calculate the velocity at the exit point of a Venturi tube, given the velocity at the entry point and the ratio of the diameters of the entry and exit points. In this case, the equation would be: V2 = V1 * ((D2/D1)^2)where V1 is the velocity at the entry point (10 mph), D1 is the entry diameter (20 inches), V2 is the velocity at the exit point, and D2 is the exit diameter (10 inches). Plugging these numbers into the equation, we get V2 = 10 mph * ((10/20)^2), or V2 = 5 mph. Therefore, the velocity at the exit point of your windsock will be 5 mph. A non-flexible tube may give slightly better results, as it will not be affected by any fluctuations in the wind speed.
What is an open entry windsock velocity?
An open entry windsock velocity refers to the speed of air that is entering an open area, such as a building or an outdoor space. It is typically measured in meters per second (m/s) or miles per hour (mph).
Why is it important to measure open entry windsock velocities?
Measuring open entry windsock velocities is important for several reasons. It can help determine the level of air flow and ventilation in a space, which can impact air quality and comfort levels for occupants. It can also be used to assess potential safety hazards, such as strong winds that could cause damage or affect the performance of equipment.
How is an open entry windsock velocity measured?
An open entry windsock velocity is typically measured using an anemometer, which is a device that measures wind speed. The anemometer can be handheld or installed in a fixed location, and it works by measuring the pressure of the moving air. The data collected can then be analyzed to determine the wind velocity.
What factors can affect open entry windsock velocities?
Several factors can affect open entry windsock velocities, including the size and shape of the opening, the surrounding terrain and buildings, and the direction and strength of the prevailing winds. Temperature and humidity can also play a role in the speed of the air entering an open space.
Are there any regulations or standards for open entry windsock velocities?
Some industries, such as aviation and construction, may have specific regulations or standards for open entry windsock velocities. These may vary depending on the location and type of space being measured. It is important to consult with relevant authorities or experts to determine any applicable regulations or standards for a specific situation.
  • Classical Physics
  • Mechanical Engineering
  • DIY Projects
  • DIY Projects
  • Other Physics Topics
