Orientation of Orbiting Planets
In summary, the conversation discusses the detection of exoplanets based on the orientation of their orbital plane with respect to our line of sight. It is easier to detect the wobble of a star when the plane is perpendicular to our line of sight. However, we have also been able to detect planets at other angles using a combination of proper motion wobble and spectroscopic red-blue shifting. The orientation of a planet's orbital plane is believed to be random, but it is more likely to be similar to the orientation of its parent star's galactic orientation. Finally, the conversation touches on the difficulty of detecting life-supporting exoplanets and the advancements in technology that may help us in the future.
Chris Russell
1. Is it true that when the orbital plane of planets about a star is perpendicular to our line of sight, that we will not detect the star wobble they may cause?
2. How many degrees from perpendicular is star wobble is detectible? For this question, I will accept an answer based on currently detected extrasolar planets but I’m really looking for a theoretical answer.
3. Is it believed that the orbital plane of planets about a star can take on any orientation with respect to our line of sight, and no one has detected a favored orientation in our galaxy?
I’m aware of research on other methods of detecting extrasolar planets which may favor a perpendicular orientation of orbiting planets. I’ve been keeping up with the current detection efforts and successes. I learned that we may soon (within the next 10 years) have the technology to detect Earth sized planets. I read a planet as small as 14 Earth masses has been found around Mu Arae and another of the same mass around 55 Cancri.
I’m trying to establish the likelihood of not detecting extrasolar planets that may support life about nearby sun like stars during the next 25 years. When would you guess that the first life supporting extrasolar planet will be found? I haven’t a clue!
Astronomy news on Phys.org
Actually, if the plane is perpendicular, that is when we would detect the most "wobble".
That would be 90 degrees, that is, anything from perpendicular to edge-on. At perpendicular, all motion would be "proper motion" and the wobble most apparent. At any other angle, all the way down to edge-on, we would (and have) see(n) either a combination of proper motion wobble and spectroscopic red-blue shifting in either the star or even the planet if it is also observable. At a pure edge-on view, we would detect only the red-blue shifting in the spectrum.
Yes. Any angle of orientation would depend on the original angular momentum of the collapsing protostar gaseous material which could be totally random on a galactic scale. That said, since the entire "protogalactic" material would probably have an overall angular momentum to determine the plane of the resulting galaxy, it is more likely that more protostars would also have that same orientation. So, it is more likely that more planets would form at or near edge-on to our line of sight.
The "favor factor" is only because this orientation would be easier to detect.
No clue here, either... :smile:
Hi, Labguy! With a perfect edge-on view wouldn't we see both the MOST red-blue shifting AND a perfect example of almost linear radial wobble?
At edge-on, we would see the most of red-blue shifting, but the star would not appear to wobble up/down, like a sign wave. At most the star and planet system would appear to move a bit faster then slower in proper motion (linear radial wobble) around the barycenter, but I think that this would be very hard to detect compared to an obvious up-down motion as seen from a perpendicular point of view. :confused:
Let's envision this as a classical xyz axis problem (with z pointing away from us). In a face-on orientation, we would see only xy wobble (an elliptical wobble in a 2-body solution). In an edge-on orientation, we would see the full excursion of xy wobble in a straight line AND the the red/blue shift of the deviation in the Z direction as the source recedes/advances in the Z direction. Cool?
This is why exosolar planets' masses are not known, so instead of being expressed in solar masses they are expressed in [tex]m sin(i)[/tex].
[tex]m_1 \sin i_{M\_Sun} =\left( {\frac{m_{2,solar\_mass} }{P_{years} }}
\right)^{2/3}\cdot {r}'_{2,AU}[/tex]
Turbo is right about the edge-on thing, but it turns out that one of the planned space missions (SIM) is expecting to detect the wobble in proper motion.
I too have recently read that star motion due to planets can only be detected by current methods when we are reasonably close (angularly speaking) to the orbital plane.
That's true, and it is all spectroscopic and based on the mass of the star only. Not knowing the angle of inclination is why the results you read about can only give a minimum mass estimate for the "planet".
System viewed in line, or perpendicular to the ecliptic plane, are the easiest to detect. The ones in between are the toughest.
I'm not sure what you mean by "in line".(?) Also, I don't know what the relationship would be to our ecliptic plane. I think it would be just (wherever located) whether we are looking edge-on, face-on (perpindicular) or somewhere in between.
At: http://physicsweb.org/articles/world/14/1/7/1 it states that:
The period and size of a star's wobble encode important information about the planet's mass. Usually it is only possible to determine a lower limit on the mass, because for most systems astronomers cannot measure the tilt of the orbit relative to the line of sight. Assuming that the orbit is edge-on to the line of sight gives the smallest possible value of the planet's mass. This is not as serious a problem as it might appear. If the orbital axes of the planetary systems are oriented randomly in space, there is a natural statistical tendency for us to see many more orbits edge-on rather than face-on.
Also, http://hubblesite.org/newscenter/newsdesk/archive/releases/2002/27/text/ mentions the early (and best) uses of astrometry for more precise planet mass determinations because of the combined use of astrometry and spectroscopy can give the orbital inclination.
Not too specific, but: http://www.chron.com/cs/CDA/ssistory.mpl/space/3098228 was released just 2 hours ago as of this post.
EDIT: The second link (astrometry) does mention that it was (in 2002) as yet unproven, so that does imply that spectroscopy was all we had to rely on before that point, hence the "minimum mass" problem quoted in the first link.
Based on this discussion and what Michael Lyle describes in his “Extrasolar Planets: Methods of Detection” lecture, see http://brahms.phy.vanderbilt.edu/~rknop/classes/a250/fall2001/ExtSolPlanets/XSPlanets.html , I shall summarize what I’ve learned thus far.
In Michael Lyle’s lecture he says, “Three methods, astrometry, pulsar timing and Doppler spectroscopy, all rely on … stellar wobble.” Having this input, it is not surprising that some think of astrometry and others of Doppler spectroscopy. When I wrote questions 1 and 2, I was thinking of the current Doppler spectroscopy work that has detected most of the extrasolar planets we know about. Based on what I knew of Doppler spectroscopy, I knew that an edge-on orientation would give the best red-blue shifting and concluded this would yield a higher count of planet discoveries when this method is used. Thus my first question was rhetorical and assumed Doppler spectroscopy is the current method of planet detection.
Based on Michael Lyle’s lecture, astrometry has yet to make its first planetary discovery but may yield some important information about the planets discovered via the Doppler method. Using pulsar timing might discover planets but I suspect the chance of finding habitable planets about pulsars is remote. Maybe with advances in photometry and microlensing instrumentation will add to the discoveries. Currently, optical interferometry (SIM) appears to be the most promising new technology. Maybe in the 2006-2007 timeframe we’ll be having some exciting discoveries. Also maybe improvements in Doppler spectroscopy, such as the HARPS project, will bag a few more planets. By the way, we are now up to 136 planets outside our Solar System as of Feb 5, 2005.
I realized my second question was going to be difficult to answer. From what I’ve read, no orbital inclination data exits for the extrasolar planets. Assuming this was true, I wondered theoretically at what point away from an edge on orientation that red-blue shifting becomes to slight to be detectable and thus would make a star’s planets undetectable. Again I assumed Doppler spectroscopy. Anyone have any ideas?
With regard to question 3, Labguy made a few relevant statements: “…since the entire "protogalactic" material would probably have an overall angular momentum to determine the plane of the resulting galaxy, it is more likely that more protostars would also have that same orientation. So, it is more likely that more planets would form at or near edge-on to our line of sight.” Are there any others out there that support this conclusion? He also said, “If the orbital axes of the planetary systems are oriented randomly in space, there is a natural statistical tendency for us to see many more orbits edge-on rather than face-on “. I buy this. And finally, “…mentions the early (and best) uses of astrometry for more precise planet mass determinations because of the combined use of astrometry and spectroscopy can give the orbital inclination “. I would like to see someone accomplish this. Has it been done? Thanks for your input.
Concluding, it appears if SIM is successful by 2007 or so we may see our first Earth size extrasolar planet. That’s just 3 years from now. Maybe if we are lucky one or more of them will be in a habitable zone. But this still leaves a lot more work and a lot more to be discovered. I suspect during the next 25 years, based on what I know now, there will be a more than one undetected Earth like planet relatively close to us.
1. How do planets orbit around the sun?
Planets orbit around the sun due to the gravitational force between the two objects. The sun's mass creates a gravitational pull that keeps the planet in orbit, while the planet's forward motion creates a centrifugal force that balances out the pull of gravity.
2. What determines the orientation of a planet's orbit?
A planet's orbit is determined by its initial angular momentum, which is influenced by factors such as the planet's distance from the sun, its speed, and the angle at which it was formed. The orientation of a planet's orbit can also be affected by gravitational interactions with other planets in the solar system.
3. Why do some planets have more elliptical orbits?
The shape of a planet's orbit depends on its eccentricity, which is a measure of how much it deviates from a perfect circle. Planets with higher eccentricity have more elliptical orbits because they are influenced by gravitational forces from other planets and objects in the solar system, causing their orbits to become distorted over time.
4. Can a planet's orbit change over time?
Yes, a planet's orbit can change over time due to various factors such as gravitational interactions with other planets, the influence of external objects, and even the planet's own internal processes. These changes can cause a planet's orbit to become more or less elliptical, or even shift its orientation.
5. What is the significance of the tilt of a planet's orbit?
The tilt, or inclination, of a planet's orbit is important because it affects the planet's seasons and climate. A larger tilt can result in more extreme seasonal variations, while a smaller tilt can result in more consistent seasons. The tilt of a planet's orbit is also a factor in determining its habitability, as it can impact the amount of sunlight and heat received by the planet's surface.
  • Astronomy and Astrophysics
