Ovalisation or a ring: diferential equations
  • Thread starter lalbatros
  • Tags
    Ring
In summary, there are six differential equations involved in the ovalisation of a ring, including equations for compression force, shear force, bending moment, radial displacement, and longitudinal displacement. These equations are similar to those for beams, but with some key differences. There are several resources, such as books and online materials, that can provide a more thorough understanding of shell deformations and the specific equations for the ovalisation of a ring. Good luck in your research!
lalbatros
1,256
Hello,
I am looking for a book or a website giving the differential equations for the ovalisation of a ring.
In principle these are six differential equations:
one for the compression force along the ring
one for the shear force
one for the bending moment
one for the radial displacementof the ring
one for the derivative of the radial displacement
one for the longitudinal displacement
these are similar to the equations of a beam, the difference is that it is a ring.
I tried to write these equations by myself, but I have some doubts about signs and how bending moment and displacements relate to each other.
I would also be interrested in the more general theory for shell deformations: where is there a good text on the web?
With such a reference I hope to be able to work out such a particular problem in a more systematical way.
Thank for your help !
Appendix: the equations I would like to check
[tex]\frac{dT}{d\Theta} = -F-R\ p_\bot[/tex]
[tex]\frac{dF}{d\Theta} = T-R\ p_\|[/tex]
[tex]\frac{dM}{d\Theta} = R\ T[/tex]
[tex]\frac{dp}{d\Theta} = -w-\frac{MR²}{EI_z}[/tex]
[tex]\frac{dw}{d\Theta} = p[/tex]
[tex]\frac{dv}{d\Theta} = w[/tex]
with the following meaning:
T: shear stress
F: compression stress
M: bending moment
w: radial displacement
v: longitudinal displacement
R: radius of the ring
E: elastic modulus
[tex]I_z[/tex]: moment of inertia of the material cross-section for the ring bending
[tex]\ p_\bot[/tex]: radial force acting of the ring (depends on the angle)
[tex]\ p_\|[/tex]: longitudinal force acting on the ring (depends on the angle)
Hello there,
Thank you for your interest in the ovalisation of a ring and for sharing your equations with us. I can recommend a few resources that may help you in your research.
Firstly, for a more general understanding of shell deformations, I would suggest looking into the book "Theory of Elasticity" by Timoshenko and Goodier. This book covers the theory of elasticity in detail and includes a chapter on shell deformations.
For a more specific focus on the ovalisation of a ring, I would recommend the book "Elasticity: Theory, Applications, and Numerics" by Martin H. Sadd. This book has a chapter specifically on the deformation of rings and includes the equations you have mentioned in your post.
If you prefer online resources, I would suggest looking into the "Theoretical and Applied Mechanics" section of the University of Oxford's Department of Engineering Science website. They have a section on shell theory which may be helpful for your research.
I hope these resources will be helpful to you in your research. Good luck!
Hello,
Thank you for your question. I am not an expert in this specific topic, but I can provide some general information about differential equations and their application to ovalisation or ring deformations.
Differential equations are mathematical equations that describe the relationship between a function and its derivatives. In the context of ovalisation or ring deformations, these equations can be used to model the behavior of the ring under different forces and stresses. The six equations you have listed are a good starting point, but it is important to note that they may not be the only equations needed to fully describe the behavior of the ring. Depending on the specific characteristics and conditions of the ring, additional equations may be necessary.
As for finding a book or website that specifically focuses on the differential equations for ovalisation or ring deformations, I would recommend searching for textbooks or research papers on structural mechanics or elasticity. These topics often cover the use of differential equations in modeling the behavior of various structures, including rings and shells. Additionally, you may find helpful resources on websites or forums dedicated to engineering and mechanics.
I would also suggest consulting with a professor or expert in this field to ensure the accuracy of your equations. They may also be able to provide additional resources or guidance for your specific problem.
I hope this helps and good luck with your research!
1. What is ovalisation or a ring in the context of differential equations?
Ovalisation or a ring refers to a specific type of solution to a differential equation where the solution curves form closed loops or ovals, rather than intersecting straight lines. This can occur when there are multiple roots to the equation, leading to multiple solutions that form a ring or oval shape.
2. How does ovalisation or a ring occur in differential equations?
Ovalisation or a ring can occur when there are multiple solutions to a differential equation, which can happen when there are multiple variables in the equation or when the equation is of a higher order. This results in a solution that forms a closed loop or oval shape instead of a straight line.
3. What are the implications of ovalisation or a ring in differential equations?
Ovalisation or a ring can have significant implications in the behavior of a system described by a differential equation. It can lead to multiple steady states or solutions, and the stability of these solutions can vary depending on the shape and orientation of the oval or ring.
4. How do you solve a differential equation that exhibits ovalisation or a ring?
The solution to a differential equation that exhibits ovalisation or a ring can be found using various methods, such as separation of variables, substitution, or using numerical methods. It is important to consider the behavior and stability of the solution when solving for it.
5. Can ovalisation or a ring occur in real-world applications?
Yes, ovalisation or a ring can occur in real-world applications, especially in systems with multiple variables or complex dynamics. Examples include population growth models, chemical reactions, and electrical circuits. Understanding ovalisation or a ring is crucial in accurately modeling and predicting the behavior of these systems.
  • Mechanical Engineering
