How Does the Pauli Exclusion Principle Limit Electron Spin Directions?
In summary, the discussion revolves around the concept of spin and its relation to the number of possible directions in which an electron can spin. It is deduced that there are only two possible spin directions for an electron, which is related to the fact that only two electrons can occupy a single orbital. The example of the Earth rotating around a different axis is used to illustrate the concept of classical rotation being non-quantized, while spin is quantized and limited to two possibilities.
Chemer
27
Hi,
Can someone please explain this to me?
"The axis of rotation for a non-quantum-mechanical object can point any way it likes. The Earth could rotate around an axis ninety degrees from the current one, so that the North Pole always faces the sun and the South Pole always faces away from it. (This actually happens on Uranus, which has an axial tilt of almost one hundred degrees off of the plane of the rest of the solar system.) However, spin can’t possibly behave like this. The number of possible directions in which an electron can spin must be equal to the number of electrons that can fit into an orbital. Otherwise, each new electron could spin in a different direction and the Pauli exclusion principle would allow any number of electrons in a single orbital. Therefore, electrons must have a limited number of possible spin directions. And since we know from Langmuir that only two electrons can occupy a given orbital, electrons must have precisely two possible spin directions."
That's a little confusing, the number of electrons determine the spin and the spin determine the number of electrons? Isn't that only two allowed directions for spin is the reason for only two electrons occupying the single orbital? Or the presence of two electrons make the spin to have just two directions? Please explain?
Also please explain the Earth example and its relation to the topic.
Thanks.
Yes.
That's simply a deduction from experiments, it was trying to give a practical evidence instead of focusing on just the theoretical principles (which the text you are reading doesn't seem to focus too much on). It does sound inadvertently confusing. The logic is that, for instance, in principle you know that the possibilities must be finite: then since they are shown to be two, the spin values must be two.
Classical rotation is not quantized i.e. it can have any direction, there are infinite possibilities that correspond to the infinite points on a sphere. Spin is quantized and has only two possibilities in the case of the electron, up or down (it's not literally like that, it's actually a general direction of a cone which can point upwards or downwards with respect to an interacting environment, but the uncertainty principle imposes such a consequence for spin 1/2 particles like the electron - the details can only be shown mathematically).
What is the Pauli Exclusion Principle?
The Pauli Exclusion Principle is a fundamental principle in quantum mechanics, which states that no two identical fermions (particles with half-integer spin) can occupy the same quantum state simultaneously.
Who discovered the Pauli Exclusion Principle?
The Pauli Exclusion Principle was first proposed by Austrian physicist Wolfgang Pauli in 1925.
What is the significance of the Pauli Exclusion Principle?
The Pauli Exclusion Principle is significant because it explains the stability of matter and the unique properties of elements in the periodic table. It also plays a crucial role in understanding the behavior of electrons in atoms and molecules.
How does the Pauli Exclusion Principle affect electron configurations?
The Pauli Exclusion Principle dictates that no two electrons in an atom can have the same set of quantum numbers. This leads to the organization of electrons in specific energy levels and sublevels, resulting in the familiar electron configurations of atoms.
Are there any exceptions to the Pauli Exclusion Principle?
There are a few exceptions to the Pauli Exclusion Principle, such as in the case of superconductivity, where electrons can pair up and occupy the same quantum state. Also, in atoms with more than one electron, the principle applies only to identical electrons, and electrons with different spins can occupy the same quantum state.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
