Phobos and/or Deimos from Mars
  • Thread starter manofthehill@
  • Tags
    Mars
In summary, the conversation discusses the possibility of seeing the moons of Mars, Phobos and Deimos, from the surface of Mars during daylight. It is mentioned that the moons are quite small and would appear as tiny points in the sky, similar to stars. The HiRISE camera on the Mars Reconnaissance Orbiter has taken some nice images of Phobos and Deimos. The consensus is that Phobos would appear as a grain of rice held at arm's length and would be visible during dawn and dusk. There is also speculation about whether the Martian atmosphere is too hazy to see stars and the possibility of seeing a star-filled sky due to the planet's smaller diameter. The conversation also includes a visual reference of how Phob
manofthehill@
Hi.
I've been searching the internet for images that the Mars rovers may have taken of either Phobos or Deimos from the surface of Mars, preferable in the daylight. I'm just curious to see that. I would think that the astronomers would have tried to capture such a sight.
All I've found are time-lapsed images of those bodies passing "in front" of the sun.
Any information or links would be appreciated. Thanks!
-Chris H.
Space news on Phys.org
Phobos and Deimos are itty-bitty moons (less than 20mi in diameter). They will look like nothing more than stars in Mars' sky.
Thanks for the reply. Good to know!
-Chris H.
I need to hit refresh more often. I was thanking Dave C. But thanks "Touch" for the links. The consensus seems to be that there is no "naked" eye phenomenon with the Mars moons, as we (are fortunate to) have here on earth.
So, you can tell I'm not a scientist, but I guess I wondered if even though Phobos and Deimos were small, they might be close enough to see. I guess not! :)
I do appreciate the replies & links. This is very good information for me, nonetheless.
-Chris H.
No, Phobos has an angular diameter of up to 0,2°, as seen from Mars. Our moon -seen from earth- is merely 2.5 times bigger (0.5°) in one dimension. Phobos should be easily visible for LGM.
Yes but visible from the surface as little more than a point. Especially since I doubt any of the landing craft have telescopic equipment. It's likely more wide-angle.
Glad to hear additional comments, Ich & Dave.
So, Phobos would basically appear as a grain of rice held at arm's length? And that's if the atmosphere didn't obscure it too much, I suppose?
Good point about the camera equipment, too. I'm sure that those robots are using wide angle lenses to get all the geographic features.
I guess I'm just curious: can one stand on the Martian surface and see Phobos with the naked eye during the day?
Well, it's albedo is ~.06 which is somewhere between fresh ashphalt and charcoal so it wouldn't exactly shine like Venus.
OTOH, it makes an orbit three times a day, so it would almost move visibly (at least if you saw it against a background of stars).
I would guess it would be visible at dawn and dusk as a very dim star-like point. But I'm just guessing.
Phobos' magnitude (from the German Wikipedia) is given as ~-8, which should be pretty bright at dawn.
I don't think that the rover's angular resolution is a problem, the transit pictures show otherwise. Maybe they need a brighter source and/or the possibility to track phobos during exposure.
For a visual reference, here's how Phobos woud appear in size as seen from the surface of Mars, compared to a full Moon as seen from Earth.
http://home.earthlink.net/~parvey/sitebuildercontent/sitebuilderpictures/phobos_moon.jpg
Really? That's significant!
During "full moon" Phobos has a visual magnitude of about -9. Venus, at its brightest, has a magnitude of about 1/2 of that. Since Venus, at its brightest, can be seen during daylight hours on the Earth Phobos should be visible, at times, during Martian daylight even though it won't be full at those times.
I didn't realize until seeing this thread and googling: Phobos orbits Mars at ~9,400 km from the center of Mars, whereas our moon's is 384,000 km. So Phobos looks so big because it is so close.
Hi all.
Clearly, we've identified an item for the next Mars mission wish list.
I first thought about this when I was thinking about whether the Martian atmosphere was too "hazy" to see very good starscapes, etc. and how crazy that would be from its high altitudes to see many, many stars against a very curved horizon (due to its much smaller diameter than Earth).
Than I saw "Watchmen" which depicted some activities on Mars, and they showed a moon (it was Phobos) in the sky. I was then curious if you could actually see it that well, and if you could see it in the daytime.
Anyway, it's all very fascinating. Mars seems to be even cooler now than it did in the 70s!
Magnitude is the total flux of course - so Phobos might not be all that visible if it is the brightness of Venus spread over 1/5 of the area of the moon
Here is an image I found online. I'm not sure what it is. It doesn't appear in the forum I found it on though. It appears to be the Mars rover taking pictures of both demos and phobos on various times they are both in the same part of the sky. Then later someone came put them in together to make it look like a continuous video. But if that's the case you'd expect there to be more of these.
[PLAIN]http://www.muk.uni-hannover.de/~theusner/mars/2P_SOL585_Phobos_Deimos.gif
Here is the forum that google brought up with it even though i didn't see it on the page. There are other pics that are interesting. It's about astronomy from mars
http://www.space.com/common/forums/viewtopic.php?f=12&t=4673&start=80
:confused:
If it isn't where it is, where is it?
Related to Phobos and/or Deimos from Mars
1. What are Phobos and Deimos?
Phobos and Deimos are the two moons of Mars. They were discovered in 1877 by American astronomer Asaph Hall.
2. How big are Phobos and Deimos?
Phobos has a diameter of about 22.2 kilometers and Deimos has a diameter of about 12.4 kilometers. They are both irregularly shaped and much smaller than Earth's moon.
3. How far are Phobos and Deimos from Mars?
Phobos is about 9,300 kilometers away from the surface of Mars, while Deimos is about 23,460 kilometers away. This is relatively close compared to the distance between Earth and its moon.
4. What is the surface of Phobos and Deimos like?
The surface of Phobos is heavily cratered and has a lot of grooves and valleys. Deimos has a smoother surface with fewer craters. Both moons are covered in dust and rocky material.
5. Could Phobos and Deimos support life?
No, Phobos and Deimos are not considered habitable for humans or any other form of life. They are too small and do not have the necessary elements and conditions to sustain life.
  • General Discussion
  • Other Physics Topics
  • Thermodynamics
