What Is the Maximum Kinetic Energy of an Electron in the Photoelectric Effect?
In summary, the photoelectric effect threshold wavelength of silver is 2762A. It is the minimum wavelength of light that is needed to eject electrons from the metal surface.
INAM KHAN
The photo electric effect threshold wavelength of silver is 2762A(angstrum)
Calculate the maximum kinetic energy of electron?
since no work function then how can I slove this? Is this be sloved by E=hv-Φ?
What does "photoelectric effect threshold wavelength" mean?
threshold wavelength means minimum wavelength.
begging the question... minimum wavelength for what?
What does "photoelectric effect minimum wavelength" mean?
What is it about this wavelength that makes it the minimum for this (whatever "this" may be, you havn't said) to happen?
The question do not have enough information to answer the question . we need incident frequency or wavelength of light to calculate the kinetic energy .
Threshold wavelength means the maximum wavelength that should be in incident on the metal so that electron will eject. Threshold frequency is the minimum frequency that should be incident on the metal surface to eject electrons .
@Nikhil faraday : the idea was that the person whose homework it is should answer the question "what does threshold wavelength mean?" etc. Since understanding what that term means is basically what the homework is about, we shouldn't really say directly.
Clearly OP has not written the entire problem in the "problem statement" section of post #1... probably the entire question is not there.
However, the answer can still be expressed as an equation.
@INAM KHAN : can you relate the threshold wavelength to the work function? It should be in your notes - or look up "photoelectric effect".
(Aside: did you write the entire question in post #1)
I am really sorry for that.
No harm - let's see how OP responds.
What is the photoelectric effect?
The photoelectric effect is a phenomenon where electrons are emitted from the surface of a material when it is exposed to light. It was first discovered by Heinrich Hertz in 1887 and was later explained by Albert Einstein in 1905.
What causes the photoelectric effect?
The photoelectric effect is caused by the interaction between photons (particles of light) and electrons in a material. When a photon with enough energy strikes the surface of a material, it can transfer its energy to an electron, causing it to be emitted from the surface.
What is the significance of the photoelectric effect?
The photoelectric effect played a crucial role in the development of quantum mechanics and helped establish the idea of light as a particle rather than a wave. It also has practical applications, such as in solar panels, photodiodes, and photocells.
How does the intensity and frequency of light affect the photoelectric effect?
The intensity of light affects the number of electrons emitted, while the frequency of light affects their kinetic energy. Higher intensity light will cause more electrons to be emitted, while higher frequency light will cause the emitted electrons to have greater kinetic energy.
What is the work function in the context of the photoelectric effect?
The work function is the minimum amount of energy needed to remove an electron from the surface of a material. It is specific to each material and can be thought of as the "binding energy" that holds the electrons to the material's surface.
